3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Casting on a knitting loom
There are various methods to cast on a knitting loom, the method shown here is the Crochet Cast on. The Crochet Cast on provides a nice, non-loopy edge that works well for most of the loom knitted items: like socks, scarves, blankets--or any other item that has the first row showing.
If you are knitting a hat that doesn't have a brim/cuff, this would be an option to the e-wrap cast on method.
Items needed:
Knitting tool
Knitting loom
Yarn
Step 1Forming a slip knot
Forming a slip knot
With your working yarn, form a small circle--the short tail of the working yarn should be at the top.
42 comments
1-40 of 42next »
Jul 26, 2011. 4:12 PMMauigerbil says:
Use a latch hook instead,if you want to. Its much faster once you get the hang of it. Once, I made an anime cat ears hat! It was adorable!!
Sep 2, 2010. 9:33 AMBeaHoney says:
I have learned the knit and purl stitches on the loom and am wondering if it is possible to convert regular knit patterns into loom patterns? Can you provide some direction or instructable on this?
Aug 6, 2010. 11:45 AMa paperdoll gypsy says:
I love knitting with needles and crochet. It is another skill I love doing! You can do almost everything with the loom you can with the needles. Baby things, blankets, socks, hats of all shapes and style the list goes on and on. This is one of the best ways to start your loom knitting. Give the loom a chance and enjoy! Make yourself happy doing what you love doing! It is fast and portable. BTW... I haven't ever had my loom taken away from me when I fly. Bottom line, It is a fun craft. Great Job PurlingSprite!
Jun 24, 2010. 7:28 AMdojers says:
An easier way of doing this is to take the tail of the yarn and wrap it around your finger twice. Take the bottom loop on your finger and pull it over the top loop. Grab the now bottom loop (was the top) and pull it up and over your finger making sure the now top loop (that was the bottom) stays on your finger. Pull the string tight and slip off your finger. You now have the perfect slip-knot.
Mar 26, 2010. 2:56 PMcharchar2 says:
you can do it so much simpler........ maybe I'll make an instructable
Sep 15, 2009. 12:23 PMchi chi chippy says:
i get how to start it but how do i make this.... (i dont no if i did it right there should be a picture.)
Mar 13, 2010. 4:10 PMdrbill says:
Makes good tube sox and hats tied at the top.
Mar 13, 2010. 4:07 PMdrbill says:
I made one of these when I was a kid out of a bicycle wheel and bent spokes. It made really fine constricting tubular nets. We used them for lobster pot entrances. Held open with wood hoops, the lobsters could get in but not out.
Mar 13, 2010. 3:48 PMthepelton says:
I recall a knitting machine sold as a toy when I was a child that worked similarly to this.  You just wove the yarn around the posts, and some hooks moved back and forth on them to create rows of knitted wool as you turned a crank.
Jan 3, 2009. 5:45 PMjherr201 says:
I'm starting my first project. I am using a round loom and have made some progress toward I guess what would be a tubular scarf? Sort of like rigatoni, with a hole in it? Is it possible to cut it in half later on so it will be twice as long or would that cause it to unravel? Also, I dont understand what it means to crotchet the end. Do I just pass each single stick over the peg next to it? Yikes! :-)
Feb 11, 2008. 11:02 AMalvincredible says:
im curious as to how you would make a hat for this. how does it come together at the top? anyway... good instructable. very clear...even i get it!
Dec 11, 2008. 7:52 PMenders_girl says:
once you get the project to hat length, you cut yourself a long tail, then thread it through the needle that comes with the loom (all the looms I've ever seen come with a hook for making things and a large plastic needle for finishing things). Then you go around the loom, slipping each stitch off it's peg and onto the tail and basically just cinch the hat closed at the top, the weave in a bit of the end and tie it up. Loom knitting is really quick an easy. I totally recommend it.
Dec 7, 2008. 10:12 AMSunny124613 says:
oh well i JUST made a hat like an hour ago,and all I did was do a square knot at the top and put and cut off the ends.Also,you could turn it inside out so that the knot does NOT show
Oct 2, 2008. 11:15 AMgirlmacbeth says:
how do you bind off in mid piece though I just don't understand the term and can't find the answer anywhere thank you
Mar 16, 2008. 1:52 PMcloverbird27 says:
This is a great this love this product product you can you use it anywhere and I love it. Can Anybody send me insctutions on how to to make an easy scarf and fun projects maybe for single cohret that are not to hard and give me some locations that have low priced or braiagin yarn.
Feb 23, 2008. 3:12 PMidontcare says:
I made one of those but in a much easier way, I also used the hook that came with it and used a shade of yarn like the one in the first picture I made a hat
Feb 2, 2008. 1:57 PMDella57 says:
I've tried the rest and use the best. Isela's Crochet Cast-On method is the ONLY cast-on method I use for my round looms.
Feb 8, 2008. 7:14 AMGettinItPegged says:
Awesome job, as usual! Everyone...Just so you know: you can knit flat pieces on the round looms as well! It doesn't have to be round. :)
Feb 2, 2008. 1:19 PMdcarroll62 says:
As always, you are the bright light of looming. Dianne
Feb 2, 2008. 12:00 PMrrrstudio says:
Thank you very much for helping me.
Jan 6, 2008. 1:02 AMmorley227 says:
While I understand how to cast onto a knitting loom, I would like the specific instructions for that hot pink twisted scarf they show right below the instructions, that appears to be a scarf that can be done on that loom. Is that true or am i missing something?
Jan 22, 2008. 9:50 PMrrrstudio says:
when I am done with my project how do I get it off the loom?
Feb 1, 2008. 6:58 PMjpirkle says:
Great instructions Isela. Get everyone looming yet ;o)
Jan 5, 2008. 7:16 PMMaggieBelize says:
What a great alternative to the e-wrap cast-on! Thanks for the great instructions.
Jan 5, 2008. 1:27 PMcorozalblues says:
Looms are fun, especially for those of us who always admired knoting, but can't deal with sticks and string. Loom knitting is so easy and satisfying!
Apr 14, 2007. 1:37 AMShark500 says:
and this oes what exactly?
Apr 14, 2007. 11:28 PMShark500 says:
ohh so it makes round things. : )
Jan 3, 2008. 3:30 PMSunbanks says:
There are some that make rectangular things.
Jan 3, 2008. 3:28 PMSunbanks says:
I have some of those and I like making hats with them. I never knew you could do different stiches on them though. :)
Nov 27, 2007. 10:25 AMTraumaComet says:
Knitting looms rock!! They are, however, not new. People have been using these for hundreds of years. It used to be the women's job to card and spin yarn, and then the men would use knitting looms to create blankets, sheets, scarves and hats. It was called "knitting jenny" back then.
Oct 22, 2007. 11:24 AMloom_knitter says:
wow this cast on is awesome...thank you for sharing it and with photo's which help a lot.
Jun 29, 2007. 11:19 PMBatGrrl says:
This stitch is a way fancier one than the one I learned. Thanks! Also, they sell a loom that does straight panels, and is perfect for scarves, etc. I cranked out a scarf in two days. The next one I make, I can weave in this new stitch. Coolio! I'll post how to make one of these old-timey "spool knitters" and I'll show you the simple stitch too! Cheers!
Apr 25, 2007. 5:18 PMbookratt says:
These looms make seamless tubular items; using them is faster and easier than using 4 double pointed needles to do the same/similar thing. They rock!
Apr 14, 2007. 10:26 PMrimar2000 says:
Very interesting. Good task.
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:PurlingSprite
Isela aka Purling Sprite, loves to knit and loom knit. She is the author of the book Loom Knitting Primer, and maintains a few loom knitting websites, one of them, Loom Knitters Circle, a magazine for...
more »
