3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cat Condo
Cat Condo
  • last photo ←
My cousin and I were looking at cat condos for his cat, and we found out that even the cheap ones were still kind of expensive. None of them were really what he was looking for either, they were all really complex. So we decided to look to instructables to see if anyone had built one. We looked around, and we didn't find anything, so we decided to make one our selves, and share it with everyone. So, this instructable will help to guide you in building your very own cat condo, one that will provide your feline with endless entertainment.
Materials Used:
Carpet (amount depends on size of condo)
Flooring Adhesive
Cardboard Masonry Tube
"L" Brackets
Wood Screws
Bolts
Nuts
Plywood
Staples
Nails
Elastic
Cat Toys
Tools Used:
Radial Arm Saw (a Table Saw or Circular Saw will work just fine)
Jigsaw
Drill
Staple Gun
Paint Brush
Scissors
Utility Knife
Black Marker
Measuring Tape
Square
Yard Stick
Hammer
Step 1Cutting and Marking
Cutting and Marking
Once you have your tools and materials gathered, the first thing you want to do, is cut the plywood for the base and the top of the cat condo.
The cardboard tube that we used was 12 inches wide, so we decided to make the base 20 inches square. We measured it off and marked it with the black marker. We then used the radial arm saw to cut the square. We also marked off the top part of the cat condo, ours was 18 inches by 13 inches. You can make the top part the same as the base if you want, we were using left over wood, and needed to adjust the size a little bit, to make it fit.
Once you have the base and top cut, you need to center your cardboard tube on each of them, and trace around it with the black marker. You can then use the drill, and drill a hole inside of the circle you just traced on both pieces of wood. This will give you a place to start the jigsaw, so that you can cut the circles out, remember to cut the holes a little bit bigger than the tube, because you will have the added thickness of the carpet to go inside of the holes also. The amount of extra you need to cut, will all depend on the thickness of your carpet.
26 comments
Jul 25, 2011. 11:07 AMchloebell1 says:
What size tube did you use? The largest tube I have been able to find at the home improvement store is 12" diameter. I really think I need something larger, perhaps 16" diameter. I am unable to find anything larger locally. Please let me know. Thanks.
May 12, 2010. 9:57 PMsuperMacaroni says:
Where did you get your carpet?
May 12, 2010. 11:12 PMsuperMacaroni says:
Thanks!
May 4, 2010. 4:38 PMflaggerboy says:
Excellent instructable.  I was planning to make a condo for our 2 cats and you've inspired me with this approach.
I have a couple of questions:
- How big is your cat?   Ours is about 10lbs, 12" tall excluding the tail, and I think I should enlarge the shelves.
- How thick is the plywood?  It looks 3/4" but I can't really tell.
Thanks!
Feb 25, 2010. 11:57 AMsam12587 says:
How cute - I love them when they are younge & playful.
Great instructable - think I 'll make a varsion of this for mine with larger shelves & then put it near the window so they have a perch to look out (where our dog can't get at them).
Jan 27, 2010. 11:43 PMsuperMacaroni says:
Aww! How cute! :3
Jan 8, 2010. 11:34 PMrlawrence says:
 does he ever use the top coz im looking at making one for a friends cat
Jan 9, 2010. 1:45 AMrlawrence says:
 haha cool, could you please tell me how high your tube was it will make it so much easier for me too make :)
Oct 11, 2009. 6:23 AMZaphod Beeblebrox says:
ill sell them!
Sep 30, 2009. 10:55 AMcopperblue says:
Well done! I really want to make this since pre-made is so expensive. I can already see adding another one to the side with ladders and curved places for my teen kitty "Ninja" to play and curl up. She is so active that she is driving us crazy!
Jul 30, 2009. 8:51 AMki10 says:
Very nice! Did you have any trouble with the adhesive being smelly? I remember when my dad last put down flooring adhesive, and I think my cat might reject it. Oh well, I'll just have to figure out a different method and post my own!
Jul 30, 2009. 12:06 PMki10 says:
I'll have to give it a shot on one of his smaller perches. Thanks!
Jun 18, 2009. 4:09 PMjethro04 says:
kitty loves it. I was able to get carpet remnants at discount store for 5.00 dollars
Feb 12, 2009. 7:25 PMrhino says:
I am glad I found this. My cats will be grateful to you.
Jan 6, 2009. 12:53 PMDoctor What says:
Your cat condo is amazing. It looks just as good, if not better, than the ones sold in the store.
Jan 6, 2009. 8:02 AMtweeder82o says:
so what was the cost at the end? I often contemplate making one of my own, but is always hendered by the fact that all the materials are going to add up to the same as buying one from the store
Jan 6, 2009. 12:43 PMtweeder82o says:
that's still a good deal then. thanks for the info. Now only if my indecisiveness can allow me to settle on a design.
Jan 5, 2009. 4:25 PMChrysN says:
Nice condo! It looks like you kitty is really enjoying it too, well done.
Jan 5, 2009. 2:17 PMred882007 says:
Kudos, very nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kylboy06
