My wife and I live in a 3-level townhome. We have a cat and two dogs. The cat has run of the house- and in fact needs to have access to the 3rd floor. However the dogs should not be up there! My challenge: take a baby gate that we already own, and make a cat flap so the cat can go up and down the stairs without letting the dogs through.
We already had the extra-tall walk-thru baby gate that you can get at Babies 'R' Us. We had it at our old home, where we used it for the same purpose - but there, the cat was able to get around the gate by going through the railing bars. Here in our new home, the bars are too close together, and the cat can't fit through.
Ready... Go!
Remove these ads by
Signing UpStep 1Supplies (and a comment on Safety)
Copper pipe holders (1/2 inch) -- not sure if that's the official name, they're u-shaped with tabs on either side, and holes for screws or bolts to pass thru.
Four Round-head bolts, four washers, and four nuts for the bolts. I used #10 coarse thread bolts.
1x2 wood. This wood is poplar, inexpensive at Home Depot or Lowes. I used 20 inches (2 x 10" lengths).
Screen material (I already had this from repairing window screens)
Packing tape (you can use any durable tape, ie. Gaffer's, Electrical, Duct...)
Tape measure or ruler
Needle nose pliers
Regular pliers
Flat-head screwdriver
Staple gun
Drill and drill bits
Dremel tool with jigsaw attachment, or reciprocal saw, or hacksaw
Dremel tool with barrel sander bit, or sandpaper and lots of patience
Metal blade for the saw of choice above
Clamps (I use quick-clamps)
Razor, scissors or box cutter
White semi-gloss or gloss enamel spraypaint
Probably more stuff I'm forgetting.
Ah, well. I'll add them in later if I remember more.
A Note About Shop Safety, aka I Am Not Responsible If You Sever A Limb Or Injure Yourself In Some Other Grievous Manner:
Saws are loud, sharp, and create sawdust. They can cut off body parts, and cut holes in bodies. The dust that a saw makes can fly around in the air getting into eyes, mouths, ears, and skin. Saws are also loud and can damage your hearing. Electricity can also kill you.
Please wear EYE and EAR protection at all times. You may consider wearing a dustmask and work gloves, to prevent any metal shavings from becoming splinters or being inhaled into your lungs. Also please keep electric cords out of the path of saw blades.
Thank you.
I tend to agree with the earlier comment about not completely trusting this with small children, unless they are supervised, and especially with stairs involved. However, I never saw a baby gate I really trusted anyhow, and built my own. I never took any pictures of them, but they're similar to what I built to separate the 24 house dogs here (mostly rescue dogs being fostered) into compatible groups. No baby gate will keep in a determined, medium-size dog, even our Goldens. If they really want to go over or through it, they can. And considering the price of baby gates, anyone can build a better one MUCH cheaper.
I am a bit puzzled about the need for a cat door -- even our antique, obese cats have no trouble jumping up onto, and then over, our 37-inch tall gates, even the one going to the basement stairs, which is a much longer drop on the other side. It's hard to believe anyone has cats any fatter, or older, than ours ... but maybe it's just a matter of what they've gotten used to.
Our dog gates, made out of scrap plywood and replacement mesh floors from dog crates, are probably overkill for most people, and the mesh is only necessary because we heat with a wood stove and need lots of air circulation. The dogs also like to look out through the mesh, too, it seems. Probably other, cheaper mesh would work, but we wanted something that an angry Great Dane couldnt get through, and something a dog couldn't get his paw caught in. This strong mesh also adds some structure and stiffness to a thin plywood gate.
Personally, I wouldn't trust any gate that wasn't securely hinged to the wall with long screws. The way we mounted ours also doesn't interfere with the regular door, since we mounted to the outside of the door jamb, past the "stop" trim that the door closes against.
Anyway, for whatever it's worth, I posted a couple of photos of the dog gates we built. I'm also working on a "slider" gate, like a pocket door, for an unusually wide opening (38"). Hint: if anyone tries a similar gate, use a lot more hinge than you think you need, or eventually it'll sag and your lockbolts won't line up anymore. Remember that dogs WILL lean on the thing, even if you don't.
Link to dog gate photos:
Dog Gate
Even horses, who are a long way from being the Einstein of the animal world, often learn to manipulate gate latches. Their lips & tongue are nearly as "prehensile" as fingers. One guy that boarded some of our horses kept finding them out taking a stroll down the road, having opened several types of latches he tried. Finally he went to a combination lock on the chain, and wouldn't let the horses see the combination when he opened it. He was only about half-joking there ....
Since we do dog rescue, most of my life often seems to revolve around proving that I can outsmart the critters. At best, I am only slightly ahead most of the time.
One thing I have learned about child or animal "gates" -- there is not one on the market that isn't mostly worthless. Even those that are secure at first will, eventually, get sloppy or wear to the point that a kid or dog can push against them and get through. Only if you make your own can you be certain it's foolproof. Those that aren't willing to invest in hinges or some slider-frame like in this Instructable, firmly attached to the frame, apparently don't value their children very much.
Knowing how inefficient the government always is, why would a rational person rely on some plastic piece of cr** just because it's approved by the Consumer Product Safety Commision?
A Better Baby Gate
