So, we decided to build him a cat house for him to hang out in and give him some shelter. With the weather we had this year, this was one of the better projects we built.
Remove these ads by
Signing UpStep 1Building box
Our cat house ended up 18" by 26" by 18" tall. Any size would do according to your cat's preference. We used exterior plywood left over from other projects and sealed the wood with waterproof paint. The roof/lid was attached with hinges to allow us to clean the inside. A strip of weather stripping around the lid helped seal out drafts. We had some plastic left over from a storm window repair, so added a small window to give some natural light.
A piece of leftover carpet (which can be easily removed for washing) added comfort A cat blanket from the local dollar store added some extra warmth and gives it that homey feeling.
thanks.
For the window I grabbed a piece of 10x11 acrylic and drilled holes into it so I could screw it into the inside. Then sealed it around the window on the outside with some silicone caulk. Also caulked the seams on the inside.
The door is a piece of indoor/outdoor carpet Home Depot had next to the astroturf and stuff. It is screwed into the wall on the top and just cut down the middle. The thick bed is interfering with it but I will eventually replace the bed with a wool blanket. My roof does hinge as well, and I plan on covering the underside of it with the same carpet to help insulate it. The minimum you can buy is enough for this.
I used particle board for the walls, but double coated it with exterior paint. Hopefully that will keep the water out well enough.
I should have kept the list of measurements, sorry guys! The front, back, and bottom are all 18x26 on mine. The sides are 18x18, but for one of the measurements make sure to subtract the thickness of the wood twice, so it will fit between the front and back. I made the top something like 20x28 to help keep the rain out. It has 1.25x1.25's supporting the corners and top on the inside. I asked for 2x2's and they gave me the wrong wood, but it just left some gaps on the top and it's still very sturdy. I can sit on it with no worry.
I'd only add 4 things:
1. a flap of some sort for the door way
2. insulation (ie:styrofoam on all 4 corners). This helps keep the cat house much warmer
3. face the door of the cat house towards the human house, etc.. This keeps the cat house sheltered from the wind
4. They say hay is better to keep the cats warm then a blanket. B/C the blanket gets wet and cold.
Just one addendum to these good ideas, regarding #4: use straw rather than hay. Because hay is a feed product, it has some moisture and can become moldy. Straw is an end product, contains little if any moisture, and is an excellent material for insulation and bedding.
Suzanne in Orting, WA
I made a "cat house" by putting old quilts and blankets over a card table and using one of those space blankets inside a fake fur pillowcase for the flooring. There's also a heading pad inside a thick pillowcase for really cold nights that I have hooked up to my porch outlet, so I can just reach out the back door and switch it on and off. It works well for Atlanta weather. The cats figured out how to get inside by nosing between and under the blankets hanging down. Only problem is possums trying to take over and other cats spraying it, pew! Thank heaven everything's washable!
Anyways, beautiful job and I like the mat on the roof, as my kitty would definitely love the texture while sunning.
Thanks for sharing.
