I finished a lab early once and decided that the most efficient use of my time was to make a program that simulated the Cat proximity XKCD, it being one of my favorites. The program prompts the user for a distance to a cat in feet, and then give the adjusted intelligence and statement inanity level (x% of normal intelligence, statement is y% inane) as well as plotting the point of both on a graph based on the one in the comic. There is also a built in limit for both extremely close and far distances.
This Instructable will show step-by-step what the program does as well as giving the code in full with my original comments. It also gives the output given by the computer for some example inputs.
Programming experience is not necessary to run the program, since I give it to you. It will help understand what's happening, however. The best source for clearing up confusion concerning what a function does or how to use it is the MATLAB website. So grab a cat and get started!
Remove these ads by
Signing UpStep 1: Intro and "easy" answers
Here is the code we will be using for this part (in italics):
d = abs(input('Enter proximity to cat in feet: '));
if d < 1
fprintf('\nThis close to a cat, your intelligence is negligible\nand the inanity of your statements is at a high.\n')
disp('(YOU''RE A KITTY!)')
elseif d >= 20
fprintf('\nThis far from a cat, your intelligence is not adversely affected\nand the inanity of your statements is at a minimum.\n')
else...(continued)
And here is the line-by-line explanation:
Two things are being done here. The first is that, using the input function, a number is being entered. Then, the absolute value is taken using the abs function and this changed number is saved as d. The absolute value is taken because -5 feet from a cat is still 5 feet.
In most programming languages, you must always end a line of a statement (like x = 5) with a semicolon. In MATLAB, you do not but if you don't, the result will be shown. Semicolons suppress the result. So:
1) x = 5
x =
5
2) x = 5;
(nothing)
if d < 1
If the distance is less than one foot, It displays the message "This close to a cat, your intelligence is negligible and the inanity of your statements is at a high." and then afterward "(You're a kitty!)", referencing the alt-text of the XKCD comic. The fprintf function is used first because the sentence is too long for one line and fprintf allows you to add newline characters easily with \n. Putting in \n anywhere will make the rest of the sentence go to the next line. There are three in this statement. Notice how there is no space in between 'negligible' '\n' and 'and'. It also doesn't matter how long the line runs in the code. Unless you go to the next line, MATLAB treats it as one statement. But without the newline characters, hen you run the function, some text will be cut off.
Next the disp function is used for the "(You're a kitty!)" because is is simpler to use and the sentence fits on one line.
Please note:
- There are two sets of parentheses because the disp function uses one set to work and the meesage itself is in parentheses, i.e. the message is (YOU'RE A KITTY) not YOU'RE A KITTY.
- Because the disp function works by displaying all text in between the two 'single quotes', you can't use a single wuote in the word "you're", as that will end the function. For this reason, you must use two single quotes (NOT a double quote) to display a single quote when the program is run.
elseif d >= 20
elseif is a variation of else. Whereas else works in an if statement to include anything not already tried by the if statement, elseif is more particular and still has requirements.
Put more simply: if asks a question. If the situation applies, the inside of the if statement is done and the program leaves the if statement. If it does not apply, the program goes to the next option in the if statement. This can either be else or elseif. If it's else, then the program runs what's inside no matter what, and then leaves. If it's elseif (a combination of else and if), the the program checks the new condition. Using elseif is the same as using else, and then inside that else statement putting a new if statement. elseif is just faster.
Anyhoo, the elseif asks if d is greater than or equal to (>=) 20. If it is, it displays a new message similar to how it did before, again using fprintf.
else...
This part of the program runs if the distance is between the two bounds of 1 and 20. It contains the bulk of the code and involves "real" work by the computer, not "easy answers".
We ride!
Visit Our Store »
Go Pro Today »
Disclaimer: MATLAB is the primary analysis tool used in the CDMS experiment, which I joined recently. I've been a C++ physicist for the past 15 years, and new stuff is hard :-/
