3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cat Tree for Free!
Step 3Lincoln Logs Were Never This Difficult
So far you've gotten rid of the loose chunks and smoothed the edges. Now let's get this puppy put together! Using your reciprocating saw, cut the dowel rod (or rods if you're going the multiple route) to a length of 6-8 inches (15.25 - 20.32 cm). You can go longer if you have an elongated paddle bit, but the one I have is only about 4 inches (10.16cm) long. Using a paddle bit that is approximately the same size as your dowel drill a hole in the center of your base as deep as it will go. I used a 7/8 inch (2.22cm) paddle bit and dowel. Repeat this on the bottom of the tree (see note on picture #3 for a safety concern). Next up we'll need to insert the dowel into hole we just drilled into the base. This will be fairly difficult because the hole and the dowel are practically the same size so using a hammer or rubber mallet is going to be about the only to drive it home. Once the dowel is in place it's time to put the tree on the base. This is a little difficult due to the above mentioned reasons. Twist, shove and hammer down until it's almost flush with the base. When it's just a bit over the base you'll want to make your final adjustments to make sure the tree is facing the way you like and is leaning in a way that lends itself to stability. Once you're satisfied, push the rest of the way down and start decorating.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Sunkicked
I was born at a very early age...
