Materials for a small dog:
2 - 4 sheets newspaper (for pattern)
1 YD yellow felt - this will be more then enough for a small dog and will leave extra in case your measurements are off
1 6X6 inch red felt
2 pipe cleaners
stuffing
sewing machine or hot glue
Remove these ads by
Signing UpStep 1Make the pattern
Measure the length of the animal from the neck to the tail end.
Measure the width of the animal by the neck from halfway on the side and by the tail end from halfway on the side.
Start by making this rectangle on your pattern paper.
Measure from each leg to where the neck starts and mark this number minus about 1/2 to 1 inch on the rectangle for each leg.
Make a half circle to form the neck.
Measure from the neck to the front leg the length and mark this on the rectangle.
Make a slightly slanted line from the end of the collar to the leg spot.
Measure the length of the shoulders on each side so that you can see how close the the tail end they are.
Mark this on the rectangle and make a half circle to connect the slanted line to the second mark.
Cut this shape out.
To make the underside of the costume:
This is almost the same as the top side except:
Measure the length of the anmal from the underside of the neck to a few inches before the privates so that it doesn't get wet from pee pee breaks.
Cut this shape out.
***These two pieces should have their half circles for the legs and neck meet up. The difference is the backside should be shorter then the front side.***
The face:
Since I have a puppy I made a cat shape which was an oblong rectangle with the top as two small triangles for the ears. I haven't tried making the dog side's head.
The head should be about a half inch bigger then the animals head to allow for a seam allowance and make it believable as a second head.
Cut this shape out.
I'll have to make a dog version for my cat!
