This may not seem like much of a problem to the unenlightened observer, but at twenty three bucks a box these granules are competitively priced with most illegal substances. Unnecessary waste of this precious commodity causes unneeded expense as well as wasting perfectly good granules.
The photos below will give you some idea of the scale of the problem - please keep in mind that this illustration represents an accumulation of about three days' running - or to put it another way, twelve cycles. Replenishing at this rate would be very cost prohibitive.
Anyway - I've solved the problem. One could, of course, call CatGenie and just get a new bowl sent out - but there's no guarantee the new bowl will be better - or one could implement my solution. Its cheap, easy and it works.
Remove these ads by
Signing UpStep 1Disclaimer, Safety and Required Equipment
While I do not believe anything in this Instructable is warranty-voiding (no hole drilling, for example) you follow these instructions at your own risk. I am not liable for your death, loss of injury or income, spousal abuse or vague feelings of unrest you may feel because you did or did not follow the steps herein. Caveat Emptor, buyer beware, don't feed the tribbles and above all, be good humans.
SAFETY:
This Instructable requires the use of a cutting implement and chemical adhesives. Perform only in a well ventilated area, wear gloves and be careful. Use common sense and be careful. Seek medical attention if you are injured. Don't drink and drive.
REQUIRED EQUIPMENT
Everything you will need is shown in the photo below: a silicone baking sheet, your CatGenie upper housing ("brim"), some 3M Contact Adhesive, a boxcutter (or other cutting tool), a Sharpie (or other marking implement), a ruler and a foam brush or other similar applicator.
Feel free to make substitutions, although as to the adhesive I can state for the record that hot melt glue and carpet tape are poor choices - they don't stick to silicone well.
I have a unique problem .. I have 10 yo tom who I had declawed ... never ... NEVER ... again. So ... litter ... and the cat genie granuals irritate his paws and he won't have anything to do with it.
My carpet is long past ruined ... uhhhhg
Now ... I have tried a few things .. one successfully ... but its a huge pain...
I put shredded paper in an old plastic litterpan ... he used it .... so he clearly wants to dig and bury ... just not in litter.
So... having put the final replacement granuals in the CG and needing more anyway ... I got to thinking ...
I decided to try something .... I bought a jar of 10,000 - 0.12g Airsoft (c) pellets .... took out all the old granuals and replaced them with the AS pellets.
So far all is well with CG ... it makes a racket when one gets down in there but except for the shaft all the parts are rubber ... so I don't believe it will cause any damage..
As far as Larry ... I bought 30,000 rounds altogether ... put 1/3 in the CG ... put the other 2/3 in the old plastic litterbox ... we shall see if he takes to it. Hopefully he will as the pellets won't get into his clawless paws ... even if they do there are no sharp edges or anything ... then I can move it closer to the CG and get his $%& in it that way.
however, it appears those pellets dry in fraction of the time it apparently takes the granuales to dry .... now if I could hack the thing to cut the drying time....
this also does away with the problem of the houdini granuals.
What is the full address of the ( eauction ) site for item # 200298694401
as my CatGenie seems to loose granules at a high rate. The price
is certainly right. at $22.50 w/free shipping.
Also have you tried useing them ?
Thanks jimwolfe2@hotmail.com
i have not used those ... I modded mine to use airsoft pellets ... works great and I can go buy more at wally world.
Jim
PS. Address your blog ( maddeningscientist.blogspot.com/2007/07/are-catgenie-granules-biodegradeable.html ) does not work !
And your cat is clearly up to no good. ;)
Have you tried World's Best Cat Litter (http://worldsbestcatlitter.com/)? It's probably less expensive than the pellets.
The CatGenie is a unique product that washes, rinses, and dries the granules in the bowl with water from a water line then flushes the water and macerated feces down the drain line.
Therefore, the granules must be completely non-absorbent. The granules are a "biodegradable" (I have issues with this word - see my blog post) plastic pellet composed of 30% talc-filled polypropylene.
