3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CatGenie: Solving the Disappearing Granule Problem
An unknown percentage of CatGenie owners, myself among them, have received a bowl (the part that holds the granules) that was not quite perfectly round. When the bowl isn't round the granules can get forced up under the rim of the upper housing (or "brim" in CatGenie terminology) at which point they travel around the lip of the bowl, get dislodged by the processing unit and collect in the base.
This may not seem like much of a problem to the unenlightened observer, but at twenty three bucks a box these granules are competitively priced with most illegal substances. Unnecessary waste of this precious commodity causes unneeded expense as well as wasting perfectly good granules.
The photos below will give you some idea of the scale of the problem - please keep in mind that this illustration represents an accumulation of about three days' running - or to put it another way, twelve cycles. Replenishing at this rate would be very cost prohibitive.
Anyway - I've solved the problem. One could, of course, call CatGenie and just get a new bowl sent out - but there's no guarantee the new bowl will be better - or one could implement my solution. Its cheap, easy and it works.
Step 1Disclaimer, Safety and Required Equipment
DISCLAIMER:
While I do not believe anything in this Instructable is warranty-voiding (no hole drilling, for example) you follow these instructions at your own risk. I am not liable for your death, loss of injury or income, spousal abuse or vague feelings of unrest you may feel because you did or did not follow the steps herein. Caveat Emptor, buyer beware, don't feed the tribbles and above all, be good humans.
SAFETY:
This Instructable requires the use of a cutting implement and chemical adhesives. Perform only in a well ventilated area, wear gloves and be careful. Use common sense and be careful. Seek medical attention if you are injured. Don't drink and drive.
REQUIRED EQUIPMENT
Everything you will need is shown in the photo below: a silicone baking sheet, your CatGenie upper housing ("brim"), some 3M Contact Adhesive, a boxcutter (or other cutting tool), a Sharpie (or other marking implement), a ruler and a foam brush or other similar applicator.
Feel free to make substitutions, although as to the adhesive I can state for the record that hot melt glue and carpet tape are poor choices - they don't stick to silicone well.
28 comments
Sep 14, 2009. 4:58 PMhandysmurf says:
hey all ... not sure if I should put this here or in the "hacking" thread ...
I have a unique problem .. I have 10 yo tom who I had declawed ... never ... NEVER ... again. So ... litter ... and the cat genie granuals irritate his paws and he won't have anything to do with it.
My carpet is long past ruined ... uhhhhg
Now ... I have tried a few things .. one successfully ... but its a huge pain...
I put shredded paper in an old plastic litterpan ... he used it .... so he clearly wants to dig and bury ... just not in litter.
So... having put the final replacement granuals in the CG and needing more anyway ... I got to thinking ...
I decided to try something .... I bought a jar of 10,000 - 0.12g Airsoft (c) pellets .... took out all the old granuals and replaced them with the AS pellets.
So far all is well with CG ... it makes a racket when one gets down in there but except for the shaft all the parts are rubber ... so I don't believe it will cause any damage..
As far as Larry ... I bought 30,000 rounds altogether ... put 1/3 in the CG ... put the other 2/3 in the old plastic litterbox ... we shall see if he takes to it. Hopefully he will as the pellets won't get into his clawless paws ... even if they do there are no sharp edges or anything ... then I can move it closer to the CG and get his $%& in it that way.
however, it appears those pellets dry in fraction of the time it apparently takes the granuales to dry .... now if I could hack the thing to cut the drying time....
this also does away with the problem of the houdini granuals.
Aug 16, 2010. 7:52 AMBronibee says:
OMG! You de-clawed your tom at the age of 10???
Aug 16, 2010. 1:05 PMhandysmurf says:
no he was declawed a long time ago ...
Aug 16, 2010. 7:41 PMBronibee says:
Ohh, thank God! I thought maybe that's why your kitty's paws are sensitive... I mean if done improperly as in butcher job, it could be disastrous... =( I have two rescues - declawed. They love the Catgenie, though. =) Cheers
Sep 15, 2009. 7:04 PMkittyluv says:
so did the pellets work? or is it jamming up the CG, my problem is I lose pounds of the stuff on the floor.I thought the dome and walls would help but it does not
Aug 16, 2010. 1:07 PMhandysmurf says:
yes the pellets work but you have to mod the grinder ... I need to make an instructable on it.
Sep 16, 2009. 10:16 PMhandysmurf says:
OK ... it worked ... I modded mine so the pellets have gaps to get through. I will be posting an instructable in the next few days.
Sep 16, 2009. 5:24 PMhandysmurf says:
Duh ... sorry ... they are tracking them out ... as far as that goes ... far less escape on the floor but there are still some that get out. I'm not sure at the moment if they are being tracked out or bucked out by the impeller. i will update on my "mod"
Sep 16, 2009. 5:13 PMhandysmurf says:
well yes but it will require some modification because it makes a racket and you will end up constantly taking the thing apart to get them out. I am going to try modifying mine ... the small pellets don't cause a problem because they fit through where they need to but not the larger balls. I have a spare hopper so I am going to drill some holes in the impeller so the few balls that make it in the hopper get out easily where they need to. If you are just looking for cheap replacement pellets you can find equivalents on that eauction site. look for item # 200298694401 ... I believe those will work and I will be buying them there if I need them ... you can get 10# for for $22.50 (shipping included). As for shopping elsewhere for equivalents anything that is close to 1/8 of an inch will work. I would also note ... since I'm posting ... while still leaving some residue in the toilet ... the simple green concentrate solution results in far less mess in the toilet than the real McCoy.
Nov 23, 2010. 5:57 PMJim Wolfe says:
Thanks for your information.
What is the full address of the ( eauction ) site for item # 200298694401
as my CatGenie seems to loose granules at a high rate. The price
is certainly right. at $22.50 w/free shipping.
Also have you tried useing them ?
Thanks jimwolfe2@hotmail.com
Dec 6, 2010. 9:48 AMhandysmurf says:
ebaydotcom
i have not used those ... I modded mine to use airsoft pellets ... works great and I can go buy more at wally world.
Dec 6, 2010. 10:51 AMJim Wolfe says:
Thanks. I will advise you if I decide to purchase some
Jim
Jun 25, 2010. 12:00 AMnelu57 says:
Thanks ScottSEA. Many thanks. Good idea. I put into practice. Nelu57
PS. Address your blog ( maddeningscientist.blogspot.com/2007/07/are-catgenie-granules-biodegradeable.html ) does not work !
Aug 24, 2009. 6:12 PMki4aoa says:
Step 5 is where I had to deviate from the plan. My granules where piling up further back than the instructables author, so I had to start the shield further back. I started mine about 4 inches before the "stalagmite."
Jul 24, 2009. 10:40 PMhandysmurf says:
Hey!! how did you get a picture of my cat?!? LOL I bet yours is a little less hefty than mine ... mine is 22# Oh and ... he has no use for the CG or any other litterbox (uuuhhhhggg) the front declaw was a bad experience for him ... as well as a round of being "blocked" so he wont have anything to do with anything that resembles litter .... I wonder how big of granuales the CG could handle.....
Apr 17, 2009. 8:02 AMBeeInPhx says:
Thanks ScottSea...I need this info today :( Earth Day is the 22nd, so all you Genie owners feel good for not adding to the ever-growing pile of litter on our world. Speaking of granules...right now if you order 4 boxes of Genie granules through Amazon.com...not only do you get the 4th one free, but you also get free shipping. I just bought 4 boxes for less than 72 bucks! Thanks again Scott, the information you have compiled on here is invaluable
Jan 4, 2009. 8:30 AMgks says:
Hey Scott, I don't think these are made of silicon, they are some kind of polypropylene. I got the same ones at Kmart. Also, thanks for doing the instruct able, this fix works great!
Oct 14, 2008. 4:07 PMFourLeggedHairy says:
Call Catgenie customer service, they have a fix for granules getting lost (they are a set of special Washers). Fix is free
Jan 4, 2009. 8:27 AMgks says:
I tried the washer "fix", in fact came up with the idea on my own, way before catgenie started pushing it. But it did not work for me at all. This method ScottSEA spells out here works great! I used polypropylene chopping mats found at Kmart rather then silicon (Scott might be talking about the same mats, not sure, but the one I used are not silicon)
Nov 10, 2008. 7:23 AMSpokehedz says:
Yeah, but who reads Instructables, and wants to do the manufacturer's fix? Not many, I assure you.
Apr 18, 2008. 6:14 AMsylvershade says:
I tried this and so far so good :) Thanks for the ingenious solution! I would like to add to make sure of the glue you get... I went to an autozone store and got some type of glue that they recommended, and then later read on the box not to use with polyethelene (or something) plastic.... sure enough, it started eating into the plastic fork I was using to apply the glue...luckily it didn't seem to affect the baking mat or cat genie. Also, my baking mat had a smooth side and a rough side. The first time I accidentally applied the smooth side to the machine and glue and it didnt stick very well. Luckily, the rough side stuck alot better.
Apr 4, 2008. 11:38 AMpaintandsoul says:
Oh orange male tabbies, no other cat like em for mischief and insane awesomeness. I do love him and my CatGenie though both can be trying at times!!
Feb 5, 2008. 5:00 PMcanida says:
Whoa. You've been on a pretty good roll!
And your cat is clearly up to no good. ;)
Jan 30, 2008. 3:06 PMGorillazMiko says:
Another great Instructable! Nice job, I like your cat too!
Jan 30, 2008. 11:34 AMadbak says:
Good instructable!
Have you tried World's Best Cat Litter (http://worldsbestcatlitter.com/)? It's probably less expensive than the pellets.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:ScottSEA
