loading
Step 9: Arduino Extension and a Bathroom Vent Version
Some cats can be extremely finicky about changes or slight noise in the cat-box, and may start crapping all over the place as a result.  If this ends up being the case, you might consider tweaking this design to put the fan on the window-end of the system.   If you want a further challenge, try rigging up two PIR sensors with an Arduino and a relay switch for the fan like I did for my Mom.  The fan shuts off whenever the cat comes near the litter box, and stays off for 30 seconds after the last detected motion.  Problem solved! Lot's of fun.
If you prefer to have the litter box in a bathroom, you can build a homemade hose coupling that fits over the bathroom exhaust fan / vent.  Because 4" duct is a bit unsightly snaking up to the ceiling, it's probably worth using a design with smaller diameter hose, like 2.5" sump pump hose.  Smaller cans, like those used for tomato paste, could provide the way here...
<p>As soon as my wife and I buy a house I will be making a couple of more permanent versions of these for our two cats.</p>
<p>Aweome! Very clever! I need to make this! And get a cat ...</p>
<p>Can I assume that this solution will work with my version of a cat litter box, which is a 30 gallon plastic storage container with lid? I could mount the fan either on the lid or at the end of the container. Looks like attached picture. </p>
<p>What a DIFFERENCE!!! We love it and our cat loves it! Only thing i did different was filled some gaps with Great Stuff. Thanks for a great and easy idea!</p>
This is first time i've ever left comments in instructables. It's just AMAZING! this is the most eficient instructables ever!! awesome
<p>my cats just go put the dog door and do their business outdoors. I have a box for them but they never use it unless it rains for several days (which is extremely rare in this part of Texas) and our yard, as well as neighbors yards are well patrolled and kept virtually free of vermin! <br></p>
Astilly, <br> <br>Thanks very much for the great design. I followed it closely and am very pleased with the outcome. The project also introduced me to hot glue, which is fantastic. Our litter box is in the basement and the odor was coming up the stairs into our living space, in addition to the unpleasantness of going into the basement. I had to modify the window attachment scheme because of my particular circumstances but I stuck to your general principles. My only comment is that, due to the airflow in our house we might need more fan power to overcome the expected draft when we run our wood stove upstairs in the winter. If necessary I will install a second fan at the window side. What do you think? Again, many thanks for posting. I'm so much happier with the fresh air!
Would you mind making a DIY for your Arduino system? I'm not very familiar with them and would love to learn how to make PIR system for my litter box. Great DIY by the way.
Excellent instructable. Just an opinion on the filter that fits into the top of the cat box: I actually find that it works VERY well. I can definitely smell when it's time to change the filter - when I do I have to put it in a ziplock and secure it well because it REEKS. New filter = no stink.
A helpful tip for those who do like the filters on the top of the litter box: a dryer softener sheet and a piece of tape work wonders to absorb litter box odors, and are much cheaper than the filters they sell at the store. :)
LOVE this -- thanks!<br><br>Tiny idea / improvement: When drilling the holes in the back of litter box, take lid off and drill from inside the lid. That way, most rough edges will be outside the box and you won't have to worry as much about tail or body getting injured by jagged edges. Also, could probably just use a power sander to lightly smooth over holes all at once.<br><br>For really long-haired kitties, glue a piece of window screen over the area where holes are! Or, if you've got really curious cats, do this to keep their noses and whiskers from intruding through holes, along with any stray bits of litter that get kicked up.
you can run it with a 3 watt solar panel all day for free.
Very cool suggestion. I could imagine the solar panel being mounted outside on the window divider or on the outside of the rain hood. Seems like you'd need a rechargeable battery to keep things moving at night, which starts to become complicated, expensive, and higher impact...do you know of a simple solution here?
you can find some easy setup stuff try <a href="http://adafruit.com/ ">adafruit</a> and <a href="http://www.sparkfun.com/ ">sparkfun</a> they both have a good amount of solar parts.<br> <br> Thanks for posting the code below. I have started writing up code for both 2 and 4 wire fans. (2 or 3 wire fans take V+ Ground, 3 wire also out puts speed of fan. 4 wire fans also have PWM input for speed.)<br> <br> One of my cats has a problem with trying to attack the fan when its spinning at high speeds so I had to come up with a way to have it spin at around 30% of top speed. the newest fan in question is off of a <a href="http://www.techpowerup.com/gpudb/images/196.jpg ">nvida 8800 video card</a> thats long been dead. The 4 wire fan from it has really saved me on speed control but I still made it for both types of fans just in case.<br> <br> Along with the solar idea My code would most likely be easy on the power consumption as its not running all the time but starts slow when the cat enters the box waits till it leaves then turns it on full to make sure no air born smells get back in to the room.<br> <br> I will try to get pics of the box and fan setup soon to show how I made it. Who knows you might even change yours to run like this if the cats dont mind.
My friend and I thought of this and tried it over 10 years ago... the results were astounding...<br>The cat entered the catbox and proceeded to commence it's business, the fan turned on, literally scaring the poop out of the cat and caused the cat to go ballistic! The cover was thrown off the catbox, cat litter and poop spread all over and the cat departed at high speed for the closest convenient hiding place.<br>We nearly died laughing!<br>So this ought to be good for a laugh anyway... but beware, you may permanently traumatize your cat!<br>
I've found now, with three of these in operation in different households, that an &quot;always on&quot; quiet CPU fan doesn't seem to bother most cats. My mom's cat was the only exception, but then again I used a 120V model that was slightly louder than the rest, so it was hard to tell. See the Arduino extension for the sensitive cat owner's version.
Really good idea. I have started working on this for my cats. Do you mind posting your arduino code. I would really like to look at it and improve on mine.
The Arduino add-on is truly optional. I wouldn't bother unless your cats prove unable to handle the noise. Here's the code nonetheless. Note that I used an inverter chip to take every &quot;HIGH&quot; to &quot;LOW&quot; and vice versa. This is probably possible by altering the code to give the inverse behavior, though I wasn't successful in figuring this out.<br><br>/* <br> * //////////////////////////////////////////////////<br> * //making sense of the Parallax PIR sensor's output<br> * //////////////////////////////////////////////////<br> *<br> * Switches a LED according to the state of the sensors output pin.<br> * Determines the beginning and end of continuous motion sequences.<br> *<br> * @author: Kristian Gohlke / krigoo (_) gmail (_) com / http://krx.at<br> * @date: 3. September 2006 <br> *<br> * kr1 (cleft) 2006 <br> * released under a creative commons &quot;Attribution-NonCommercial-ShareAlike 2.0&quot; license<br> * http://creativecommons.org/licenses/by-nc-sa/2.0/de/<br> *<br> *<br> * The Parallax PIR Sensor is an easy to use digital infrared motion sensor module. <br> * (http://www.parallax.com/detail.asp?product_id=555-28027)<br> *<br> * The sensor's output pin goes to HIGH if motion is present.<br> * However, even if motion is present it goes to LOW from time to time, <br> * which might give the impression no motion is present. <br> * This program deals with this issue by ignoring LOW-phases shorter than a given time, <br> * assuming continuous motion is present during these phases.<br> * <br> */<br><br>/////////////////////////////<br>//VARS<br>//the time we give the sensor to calibrate (10-60 secs according to the datasheet)<br>int calibrationTime = 10; <br><br>//the time when the sensor outputs a low impulse<br>long unsigned int lowIn; <br><br>//the amount of milliseconds the sensor has to be low <br>//before we assume all motion has stopped<br>long unsigned int pause = 25000; <br><br>boolean lockLow = true;<br>boolean takeLowTime; <br><br>int pirPin = 3; //the digital pin connected to the PIR sensor's output<br>int ledPin = 13;<br>int outPin = 12;<br><br>/////////////////////////////<br>//SETUP<br>void setup(){<br> Serial.begin(9600);<br> pinMode(pirPin, INPUT);<br> pinMode(ledPin, OUTPUT);<br> pinMode(outPin, OUTPUT);<br> digitalWrite(pirPin, LOW);<br> digitalWrite(outPin, LOW);<br><br> //give the sensor some time to calibrate<br> Serial.print(&quot;calibrating sensor &quot;);<br> for(int i = 0; i &lt; calibrationTime; i++){<br> Serial.print(&quot;.&quot;);<br> delay(1000);<br> }<br> Serial.println(&quot; done&quot;);<br> Serial.println(&quot;SENSOR ACTIVE&quot;);<br> delay(50);<br> }<br><br>////////////////////////////<br>//LOOP<br>void loop(){<br><br> if(digitalRead(pirPin) == HIGH){<br> digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state<br> if(lockLow){ <br> //makes sure we wait for a transition to LOW before any further output is made:<br> lockLow = false; <br> Serial.println(&quot;---&quot;);<br> Serial.print(&quot;motion detected at &quot;);<br> Serial.print(millis()/1000);<br> Serial.println(&quot; sec&quot;); <br> digitalWrite(outPin, HIGH);<br> delay(50);<br> } <br> takeLowTime = true;<br> }<br><br> if(digitalRead(pirPin) == LOW){ <br> digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state<br><br> if(takeLowTime){<br> lowIn = millis(); //save the time of the transition from high to LOW<br> takeLowTime = false; //make sure this is only done at the start of a LOW phase<br> }<br> //if the sensor is low for more than the given pause, <br> //we assume that no more motion is going to happen<br> if(!lockLow &amp;&amp; millis() - lowIn &gt; pause){ <br> //makes sure this block of code is only executed again after <br> //a new motion sequence has been detected<br> lockLow = true; <br> Serial.print(&quot;motion ended at &quot;); //output<br> Serial.print((millis() - pause)/1000);<br> Serial.println(&quot; sec&quot;);<br> digitalWrite(outPin, LOW);<br> delay(50);<br> }<br> }<br> }
I like the idea, effort and creativity here. Did you try adjusting your cat's diet too? Sometimes changing brands is all it takes. The other is the litter. We use one of the bargain brands that comes in a big yellow 35 lb. bucket with blue or red top. No smell, even if we miss the cleaning schedule. That's the other thing, clean it more often. Now, if your cat is regularly going out on stewed mackerel &amp; chorizo binges, none of the above may help.<br><br>;-)
Cat boxes don't smell if you change the litter frequently and clean the litter box. Also depends what you're feeding the cat. Cheap ash-packed cat food will make their poo smell.<br><br>Or you could just toilet train like I have! :)
Yes they do! But you don't notice it because you're used to it. I couldn't smell anything but my moms face went from :D -&gt; D: when she visited. And we clean it often, use quality &quot;sand&quot; and food :)
Actually, I'd have to agree with PinUpRetro. I'm in and out of my apartment constantly with school and work. So I'm always having multiple chances to get used to the smell outside of my apt before coming back in. Never once have I ever come in, when I regularly clean the box, and thought &quot;gee, that actually smells&quot;. <br>For the most part I clean it every single day and use a scented clay-based littler, for multiple cats, that I change every 2 weeks. I have 2 cats who use it a LOT and both are fed a natural diet.<br>I've NEVER had a problem with smelly littler boxes, and it's not because I'm &quot;used to the smell&quot; since I frequently am not home and have visiters over as well. My mother-in-law is a real clean freak and even she never smells it when she visits. She'd tell me too, trust me...<br>The only time I do smell it is when I forget to clean it for a day or 2.<br>So yeah. Maybe it depends on the cat, but it's certainly not all litter boxes since mine and PinUpRetro haven't had that problem.
Cheers bud - same here.<br><br>I'm out all day at work and would have noticed a smell when I came through the door (I'm like a bloodhound for smell). <br><br>We have three cats so emptied poo out twice a day and changed the (clumping smell absorbing) litter every 5-7days depending on usage (in the summer they tended to addnutrients to the flowers). <br><br>My mum has all the subtley of a sledgehammer to the face and would say if it smelt too. <br><br>Diet isimportant too (just like with humans) - eat a bad fatty diet and your/their poo will smell. <br><br>
rtanner and PinUpRetro: No offense, but my mom said she never smelled her cat's litterbox either, and the subject was a laughingstock amongst my friends and wife whenever we visited. It was less about the poop and more about the ammonia / urea stench: made by a stronger cocktail of the same chemical compounds that make up human body odor. Given the relatively recent advent of indoor plumbing, something tells me the human olfactory centers have a way of adjusting to compensate. At least you two have each other;)
Well, since your mom never smelled hers either I doubt that she got used to the smell as well. It might actually be the litter you're using. <br>A while back I actually tried a different litter called &quot;World's Best Cat Litter&quot;, hoping to move from the clay based brand I had. Turns out I got rid of the stuff the very next day because I came home from being out for just half a day and was able to smell the stench. The litter did nothing to mask the smell. <br>After going back to the clay based stuff I again don't smell anything when I come home. So I definitely know the difference which would mean my nose didn't get used to anything. I bet the type of litter has a lot more to do with masking the smell than people realize.<br>Why don't you try switching out and see if that makes a difference? I use Fresh Step, if you were wondering. :)
Ah ha. My brother reminded me that cats who don't bury will ALWAYS have a smelly litter box, like his cat. The ones that bury, if you use a scented litter like I do, can keep the smell at bay for a day or 2. This is likely why I don't have problems, since my cats bury religiously and I'm still scooping it every day.
how hard is it do toilet train? can old cats learn? do you have any good links or tips and tricks?<br>
We tried the &quot;City Kitty&quot; system of toilet training prior to this ventilation system, with the careful cycle of adjusting them to get comfortable with perching atop the bowl, and all hell eventually broke loose.<br><br>We have friends who had success with it, so perhaps we just didn't have the right touch. Nevertheless, the potty training device blocks the toilet from normal human use for months on end, which is no fun for small apartment dwellers.
The one we used 'Litter Kwitter' is easy to pick back up off the toilet when you want to to use. We only have one loo in our house and had no issues. It's worth not having to change litter ever again to have a few weeks disruption
Depends on the cat. One of our cats picked it up straight away - lady (her daughter) is a dunderhead and took a bit longer. <br><br>Age is irrelevant unless it's a cat too old to balance on the seat. Pregnant cats shouldn't be toilet trained either (nursing either - just in case on of the kittens is attached to a nipple!) obviously kittens shouldn't be toilet trained for obvious reasons. <br><br>I used the Litter Quitter. But I guess you could try and make something similar.<br><br>Tips: move their litter tray into the bathroom - make sure they see it and the door is always open. <br><br>When they've gone a few times (all cats have to have reached this stage - as with each stage) you can exchange their tray for the quitter (red stage) on the floor. Then when they've successfully gone in the put it on the loo. Sookie got this first time, lady took a little longer - we had to go back a stage with her. <br><br>Then change to Amber (see the pattern emerging): which still has room for litter but has a small hole in the middle - encouraging them to aim for the hole and sit more on the seat and not in the litter. <br><br>The green stage is similar to Amber except the hole is bigger. <br><br>It can take a few weeks if you have a lot if cats or some stooooopid ones. If we just had sookie it would have taken a few days to go though the stages. <br><br>Great thing about this is they love it - their poo disappears ANC they don't have to bury it, you don't gave to empty a tray - just flush, don't have to buy litter any more snd when I have a baby I don't need to worry about handling litter. <br><br>The litter quitter fits over the loo, but it's best to
I switched to shredded paper for kitty litter and it works great, I can clean my litter box everyday. I simply sprinkle baking soda on the bottom of the box and put the shredded paper in. At first I was hauling paper home from our coop but the bags were flimsy and would break, creating a big mess. I finally invested in a good shredder and the bulk mail and newspapers provide me all I need. I didn't like using clay litter as it doesn't break down, much like baby diapers in the landfill, and the biodegradable litter was pretty expensive. I'm solving two problems with one solution. About once a month, I wash the litter box.
I am so confused about why you glued the bottom of the food container to the lid. Don't you want air to be able to escape through the flap?
skybondsor: You are right, I wasn't clear about this in write-up. Will add some more detail. I cut a rectangle out of the downward-facing side of the container for the air exhaust. The closed top and sides of the container keep rain from possibly coming in through the duct. Gravity prevents rain from getting into the open bottom side. Will add some text details to the photos.
Ahhhh that makes sense. Thanks for responding!
Air does escape. It's just a flap. It prevents small animals and most larger bugs from entering the whole system. She basically duplicated what you would see in the kits she refers to.<br><br>Awesome Idea I think!
I understand the flap cut-out on the lid, using the zip-ties as a hinge of sorts. But why then cover that apparatus with the bottom of the food container? Wouldn't that prevent air from escaping?
Assumably that glued on &quot;bubble-cap&quot; kind of thing has a hole cut out on the bottom to allow the air to escape.
Yes, exactly!
As Humans, We tend to forget how Sensitive an Animal like a Cat or Dog can be to Sounds We don't Hear or Vibrations We don't Feel. <br>Consider how you'd feel if you started Hearing the Whirl of a fan or feel your Hair move in a wind where none existed before, Each time you used the Potty, Now Amplify that a hundred times, That's what your Cat is going through. You might try Switching the Fan from the Box to the Window, To Quiet things down a bit, As well as making a Diffuser at the Box-End to tone-down the Suction under the Hose outlet.
Yes, I definitely want to try the fan on the window side of the apparatus. It would be interesting to test how a CPU fan performs when it is drawing from the far end of a tube rather than a relatively open space.<br><br>As for cat sensitivity to noise, my two tomcats are completely fine with sharing the same box on my first prototype and don't mind the fan noise a bit. On my 2nd build, my mom's older, female Calico started crapping all over the apartment, which is what pushed me to use the Arduino / PIR sensor solution (see last step) to shut off the fan whenever she approached the box. An LED on the top of the box turns off to provide her a visual to confirm the fan is off as she approaches.
I was with you up until this point. For those out there that need Portability, Don't Cut the Jumper/ Connector off, Instead, find an old Female Plug, Soldier it to the wires ( Check for polarity first ) then Glue plug to fan housing. Now if the Transformer ever quits, just simply unplug jumper &amp; replace as needed.<br>This will help If &amp; When you ever move to another house.
Nice suggestion! I totally agree this should be part of the idealized version of this project.
This is a great idea and would work fantastically.! My husband made something similar back in the 1980s and we have been using it ever since. What we did was cut a &quot;mouse hole&quot; shaped opening (cat size) through a wall of our house to the outdoors. Then we built and attached an enclosed plywood box to the house, over the mouse hole. It has a a piano-hinged side, kept tightly closed with a sliding bolt gate latch, that allows easy OUTDOOR access to the standard size cat box pan inside. We put weather stripping in and around everything to secure it against bugs and weather. For exterior venting, we cut a hole in the plywood and placed a Rotron &quot;whisper&quot; fan (used in computers and electronic devices) in the hole and covered it with screening. We covered the fan with an elbow and then a 10' piece of pvc pipe that goes straight up the side of the house. The fan draws the stinky air out of the box and up the pvc &quot;chimney,&quot; and his type of fan is quiet so that it doesn't disturb our kitties. Nobody has EVER smelled cat box at our house, and if you keep the mouse hole small, no bigger than kitty bodies, it doesn't affect your utility bill. It's a one-day job that saves you so much time and frustration! Paint a couple of mice at the hole and, voila!
...another project ...<br>dang my list is really long
Like it, +1 for the contest.<br>I no longer keep cats like I used to when I was a kid (they have the nasty habit to die after a while) but one of the things i remember is the litter-box smell, huh!<br>Alessandro
Yeah, strange thing that. Cats seem to last about 20 years and then it's all down hill from there.
Until the commercial release of the &quot;recycled glass&quot; litter, I certainly was never acclimatized to the stink. I never used pet-shop litter trays because they're too small and shallow. What are those scratch marks on the wall? Oh, that's where the cat was attempting to bury something...<br><br>I did a ventilation job as well, with water-pipe that hung just above the height of the tray edge and went to the ceiling, through a small fan, and then out the root-top. Pity I didn't know about Instructables at the time! <br><br>This definitely gets a vote from me.
wow hope 3 cats can use this
About This Instructable
164,121views
339favorites
License:
Bio: teaching and learning enthusiast, physics teacher, urban STEM educator, school leader, ed tech developer, maker of things
More by astilly:DIY Pentakis Dodecahedron With Your Kids Odorless Cat Litter Box
Add instructable to:
