If you're interested in more of what my class has done, visit our blog www.theresponsiblestudio.tumblr.com !
Remove these ads by
Signing UpStep 1: Materials
.1/2"x6" double threaded galvanized steel pipe nipple (you will need 2)
.1/2" galvanized steel 90 degree elbow (you will need 2)
.1/2" galvanized steel floor flange (you will need 2)
.1"x30" PVC pipe (you will cut this in half)
.1" PVC coupling (you will cut this in half)
.1" PVC end cap (you will need 2)
.42"x22" of catch-tray material
.thread and sewing machine
.screws
.glue/thread lock (optional)
Visit Our Store »
Go Pro Today »
but.. why not just secure the bottom of a regular neck apron to the edge of the work surface? They make specialty "jewelers aprons" just for this purpose, and they are little more that just that.
I like the Idea, but, to me, it just seems a little over complicated for what you are trying to do
we did consider a design that would just tie around your waist like an apron and connect to the bench. however, we all do a lot of moving around in the studio whether it be to go to the hammer room, the machine room, or the soldering bench. it wouldn't make sense to be tied into the bench in our specific studio.
all of these concerns were a little specific to our situation, so i'm sure there are plenty of other ways to solve the problem. i love hearing all of the other solutions jewelers have beens sharing!
p.s. It might be time for a new bench pin :)
hahah..yeah the bench pins have taken a lot of abuse. that's what happens when you're sharing it with 50 other students, i guess.
(Just to give you an idea, during one year of my course I saved all my silver scrap, inlcuding the filings dust, took it all back to my supplier and received about AU$300.00 credit for it!)
This is a pretty cool design, although it does seem a little overcomplicated, with all those extra bits and bobs to put it all together. In the studio I shared last year the catch trays were of similar shape and material, only made with a deeper and attached directly to the base of the bench with velcro or press-studs. This made it SUPER easy to rip them off, empty, clean and slap back on again, (literally!) and you wouldn't then need the steel and PVC pipes.
Easier and cheaper and much more of a time saver in terms of construction. This also stopped material escaping back underneath, and they hung higher up (closer beneath the pin), in comparison to these, but this is also a personal preference of mine and perhaps not something all jewellers can work with.
Great 'ible, and thanks for sharing!!
The silver smith shop in Colonial Williamsburg (Va) they used leather for the skirts and they are mailed to the table , and they were fitted to thte artisan. like an apron around the waist. They did not have plastics obviously, but perhaps if available they would not build up static charge in a/c or winter hours, although this may not be an issue.
great instructable
congratulations
Unrelated curious: what are the wooden 'V's attached to the bench for?
In my case, I think it would be rather a bit annoying. I use many tools that produce fillings, and also the stick welder. Besides, I work almost always standing, changing position all the time.
