loading
Step 4: Solder in the LEDs
Place the LEDs into the PCB making sure to put them in the same way round as the existing LEDs (they only work one way round). Then solder them in place. I find it easiest to solder one leg in place, then bend the LED into the correct position and then solder the other leg.
I was hesitant to mod my tail light because I wasn't sure which LEDs to use. The 5000mCd ones are spot-on! I can't tell the difference from the stock ones. Thanks for posting this, mate!
You're welcome!
 >  I did this mod a while ago.  I'm glad someone posted an 'ible on how to.
same here
Hrrmmm looks good! I'm wondering a couple of things, however... 1) Is the power coming straight from batteries with no current-limiting anywhere? Just wondering if all LEDs remain as bright as they should once two extra have been added. 2) Do the light patterns still flash in the same way? I.e. does the knightrider-esque pattern not skip the two new ones? Cheers! Always thought it was pretty poor not to fill in the remaining two holes, but found the PCB sat pretty tight and didn't want to break the thing...
thanx :) 1) the new LEDs are just as bright as the old ones. 2) you know the pause you see when there's no LED illuminated when it's in that pattern mode? that's when these other two LEDs light up! i thought that too. be confident and only pull on the battery clips, not the PCB. use long nose pliers and 'walk' the PCB out pulling on the top connectors, then the bottom, then the top, etc. if you do bent the battery connectors whilst pulling them out, you can always re-bend them. have fun :)
About This Instructable
11,346views
11favorites
License:
Bio: I enjoy cycling and photography, and especially photography whilst cycling. :)
More by zzpza:Fixing a Broken Film Transport on a Bronica SQ-A Film Back Polaroid Land Camera Fujifilm and Battery Mod Intelligent Solar Garden Light - Part 2
Add instructable to:
