Cayenne, Python and MQTT Tutorials-1 - Digital Input
2,052
12
5
Posted in TechnologyRaspberry-pi
Introduction: Cayenne, Python and MQTT Tutorials-1 - Digital Input
This guide is part of a series of guides that cover the basics of using Cayenne with Raspberry Pi, Python and MQTT.
This tutorial show you how to send momentary button press digital data to Cayenne IO Dashboard by using Python and MQTT.
Step 1: Wiring
You will need the following parts for this tutorial:
  • 1x Raspberry Pi
  • 1x momentary button
  • 2x male-female jumper wires
You need to connect these pins:
  • Rpi ground to one side of the momentary button
  • Rpi pin 2 to other side of the momentary button
Step 2: Sign Up!
To use Cayenne IOT Dashboard, you need to sign up Cayenne from the website.
Step 3: Selecting Device
After log in, Select "Bring Your Own Thing".
A window will pop up with MQTT and your Client details. You will use these informations in Python script. When you connect Cayenne MQTT Broker by running Python script, you will direct to Dashboard.
Step 4: Adding Widget
To add 2-State widget, click on:
  1. Add new
  2. Custom widgets
  3. 2-State Display Widget
Then fill widget infos and click on Add Widget. You can change widget infos later on widget.
Note: Channnel number must be same as in Python script.
Step 5: Python Code
You need to install this library for Python script. It is MQTT library to communicate RPİ and Cayenne IOT Broker.
  • cayenne-mqtt
This library can be installed using pip and pip3:
pip install cayenne-mqtt (for Python2)
pip3 install cayenne-mqtt (for Python3) >>>for this tutorial.
Note: In the script, you must modify your MQTT credentials and widget channel.
import cayenne.client #Cayenne MQTT Client
from time import sleep from gpiozero import Button button=Button(2) # Declaring button pin 2
# Cayenne authentication info. This should be obtained from the Cayenne Dashboard. MQTT_USERNAME = "YOUR MQTT USERNAME" MQTT_PASSWORD = "YOUR MQTT PASSWORD " MQTT_CLIENT_ID = "YOUR CLİENT ID"
client = cayenne.client.CayenneMQTTClient()
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID)
def send_on(): client.virtualWrite(3, 1) #Publish "1" to Cayenne MQTT Broker Channel 3 print("Button pressed\n")
def send_off(): client.virtualWrite(3, 0) #Publish "0" to Cayenne MQTT Broker Channel 3 print("Button released\n")
button.when_pressed=send_on #When button pressed run send_on function button.when_released=send_off #When button released run send_off function while True: client.loop()
After run the script, you will connect to Cayenne MQTT Broker.
Press and release the button. Button state widget changes the value.
Step 6: IFTT Integration
If you want to take notification by e-mail or SMS
To use IFTT in Cayenne:
  • Create new trigger from "Add new" then give it a name
  • Drag device to first space and select Button State.
  • Choose "1" ( if you want to take notification when button pressed)
  • Click on "add custom recipent" and "send e-mail".
  • Finally "Save it"
Press the momentary button and check your e-mail.
Step 7:
This video shows final stage.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    5 Comments
    I giive this error:
    Connecting to mqtt.mydevices.com...
    Traceback (most recent call last):
    File "Example-01-SendData.py", line 19, in <module>
    client.loop()
    File "/usr/local/lib/python3.6/site-packages/cayenne/client.py", line 150, in loop
    self.client.loop()
    File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 995, in loop
    rc = self.loop_read(max_packets)
    File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 1273, in loop_read
    rc = self._packet_read()
    File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 1838, in _packet_read
    rc = self._packet_handle()
    File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 2291, in _packet_handle
    return self._handle_connack()
    File "/usr/local/lib/python3.6/site-packages/paho/mqtt/client.py", line 2349, in _handle_connack
    self.on_connect(self, self._userdata, flags_dict, result)
    TypeError: on_connect() takes 3 positional arguments but 4 were given
    ı dont know why it happened. this works for me.
    Did you use this script or modify it?
    I use the example code
    I ran into this on one of my Pi's last week. It turned out to be that Cayenne uses a package called paho-mqtt, and they're expecting version 1.2.3 with that example code. When version 1.3.0 is installed, it left that error message. While they need to adjust their code so it will play nice with 1.3.0, in the meantime this can be worked around by simply installing v1.2.3 of the paho-mqtt package.
    You can first check to make sure that it is the same thing, if you have paho-mqtt 1.3.0 running:
    pip show paho-mqtt
    Assuming you are, to change it to version 1.2.3:
    sudo pip install paho-mqtt==1.2.3
    Again you could run pip show paho-mqtt to verify the change was made correctly. At this point you should be able to run the example code without that error message about the number of arguments.
    Nice tutorial. You should enter this into the Microcontroller contest.
