Introduction: Cd Cube Lights
About: someone is actualy reading this
About:
These are cheap and easy to make. And if you get a few of them just as cheaply you can put a candle or a few leds in them and hang them in your garden or at you party.
Parts:
X6 Cd's or DVD's
Tools:
Protractor
Ruler
Pencil or Pen
Dremel - with a cut off wheel
Any sort of light:
led
light bulb
even a candle if you leave a side off
Step 1: The Corners
The corners:
First of all line the protractor up with the middle of one of the cd's and use the pencil to mark a line every 90 degrees to the edge of the cd.
Step 2: The Lines
The lines:
Now simply use the ruler to make a square out of the four dot's in the corners
On each of the lines Measure and mark 5cm from the left corner.
Step 3: The Cut
The cut:
And finally cut the 5cm line out.
Repeat 6 times!
see pictures if you dont get it.
Step 4: Imposible to Easy
Impossible to easy:
It is extremely hard if not impossible to put the cube together like this with out breaking it so here is how to:
With 4 cds make a cube that is missing both it top and bottom.
Then with the 2 remaining cds complete 2 of the cuts opposite to each other.
Before you finish put the light's in the middle !!!!
And simply slide the last 2 cds on to the top and bottom of the cube and you are finished
Dead Computer Contest
