Cedar (Cigar?) Box Speaker Box by crowdsourced
Featured
Inspired by the Munny speakers, but not willing to spend more than $10, here's my instructable using old computer speakers, a wood box from the thrift store, and lots of hot glue.
Step 1: Salvaged parts
-Ugly old speakers. One with circuit board, control knobs/buttons.
-Cedar box. I got this one at a thrift store for $.50. I've seen various kinds of pine(?) boxes at Michael's craft stores.
-A couple small hinges.
-A set of feet (adhesive or screw-in).
karen dora says: May 29, 2012. 7:22 AM
Thanks so much for the great instructions! I'm working on a speaker of my own right now, thanks to you.
karen dora says: May 29, 2012. 7:24 AM
Would you recommend getting a deeper box for a better sound? Your box looks pretty narrow, and mine is definitely almost touching the back of the speakers.
moisture says: Jan 5, 2009. 8:48 PM
A coping saw might work too..hah, I'm amazed how round the holes are given your tools. How does it sound?
thomasporter says: Jul 14, 2011. 12:55 PM
agree. i wish i had a coping saw..... is there an instructable for that? heh
crowdsourced (author) says: Jan 6, 2009. 4:54 AM
The sound might not please audiophiles, but it's no worse than the plastic boxes they were in. You're right. A coping saw might have worked. But the hole saw would have been a dream.
karrykitch says: Jun 8, 2011. 6:09 PM
really nice idea :B!!! i'll make one :D
Sandisk1duo says: Jan 6, 2009. 8:38 PM
Very cool, take it one step further, cut the power cable off and power it by a battery!
crowdsourced (author) says: Jan 10, 2009. 7:26 AM
That would be cool. Though it would take some actual skill to do. Not like this project! ;)
Sandisk1duo says: Jan 10, 2009. 8:43 AM
it's possible to do it, i've done it before all you need to do is cut the wires going to the speaker, then strip the wires and connect them to a battery, polarity does not matter
crowdsourced (author) says: Jan 10, 2009. 11:55 AM
Got it. So you might be able to take the battery compartment from some old device and splice its wires to the speaker's, so you have something for the battery to sit in. Then just mount the compartment. With hot glue, of course! I'd also like to look around for a way to convert it to usb power since it's used with a computer all the time.
Sandisk1duo says: Jan 10, 2009. 12:34 PM
usb it can only put out 2.5W - 5v 500ma i usually use RC car batteries
cornflaker says: Mar 26, 2009. 4:01 AM
I did this, only if you have better speakers (I think mine were about $30 so still cheap) then polarity does matter, but Yeah you can just depending on the speakers splice the cable with a (in my case 9v battery clip) and it works. The speakers might clip a bit at the highest volume though depending on how much power is left in the battery.
cornflaker says: Mar 26, 2009. 4:03 AM
Oh and for better sound you should have made a 3rd much smaller hole in between the two speakers (well anywhere but that would look the best) probably about a centimeter in diameter. Yes thats right more hole cutting :P
Sandisk1duo says: Mar 26, 2009. 6:54 AM
if the speakers have low Xmax (move in/out only a little) it is better to have a sealed enclosure, and not a ported one
cornflaker says: Mar 30, 2009. 4:58 AM
Yeah I guess these ones probably wouldn't have a whole of of excursion going on... I made a set of ipod speakers using some old cheap computer speakers of mine and converted them to run off 2 9v batteries and they sounded much better with a fairly small hole (bit less than 1.5cm) but they admittedly would have a fair bit more excursion than these ones as these are pretty small even for computer speakers...
cornflaker says: Mar 30, 2009. 5:01 AM
Damn it I wish you could edit comments on here lol, I just noticed that the original cases for these actually have a fairly large port for their size... could be fake thought just to make them look better
ambientvoid says: Apr 30, 2009. 2:17 PM
iv been trawling around for a means to convert some old pc speakers into a battery powered portable Boombox to mount on the back of my longboard. Is there any way to tell if stripping the power cables and mounting a battery as described above is viable without actually dismantling the speakers? oh and how long would 2 9v batteries give power for, as i need them to run at near full volume for about 3hrs?
cornflaker says: May 1, 2009. 3:28 AM
Well I haven't actually done a proper test to see how long the batteries last but I have 2 9v's in parallel powering a 10w system, and it has lasted for ages so I'm sure they will last for 3 hours, but it really depends on what speakers you are using and how much power they draw. What you can do to test is find a plug pack that you don't need any more that has the same power connector as your speakers one and use that.
polop says: Apr 14, 2011. 2:55 PM
as far as choosing some speakers for one of these box conversions whilst using a battery, find a speaker that uses an external power-supply (a wall wart i think some people call them) then use a battery that matches the voltage of the output of the original supply. Really you should only consider a box change like the one above if you prioritise form over function, any reputable computer speakers will have been designed to maximise the performance of the very cheap components. If the original speakers are sealed, try to keep to the original internal volume, if ported try to match as many of the dimensions as possible.
If sound quality is important avoid cheap computer speakers, and go for a diy design that uses cheap bare drivers, this will always sound better.
With batteries, avoid 9v bock batteries - they are expensive - they have abysmal capacity. If two 9v block batteries lasts over 2 hours, your speakers are not loud enough :p go with series AA batteries for a small efficient system, and more substantial lead or lithium batteries for a more serious performer.
p0g068 says: Dec 28, 2010. 5:53 AM
dude ! nice choice for the box ... hope you will post more instructables
etm71 says: Nov 18, 2010. 4:03 AM
Kind of looks like a chess clock. Cool. :~}
matbh says: Mar 17, 2009. 5:30 PM
nice job, but is time to buy a dremel...
SenhorLampada says: Jan 24, 2010. 7:12 PM
Hope it doesn't cost too much! Here in Brazil a nice dremel tool cost around US$ 100...
:D
matbh says: Feb 22, 2010. 3:49 PM
para muitos brasileiros 100 dolares é muito caro.
eu que gosto muito de trabalhos manuais acabei comprano minha dremel 300 por 180 reais na cofermeta em belo horizonte
ThaNorwegianDude says: Jan 22, 2010. 8:59 AM
 thats cool imma make something like that (btw u can look at the power supply and check what the output are and use a batery that does the same output so u dont need wall outlet! :D )
Mako-chan4 says: Jul 23, 2009. 10:47 PM
This was AWESOME!!! I'm gonna make one now!!!
but the hinges do have a funtion if I'm not mistaken... If that thing opens up the way it did in all of the other pictures, then if it was shaken it would flap open like a book. I think those hinges are what's keeping it closed and therefore more balanced/stable.
joejoerowley says: Jan 8, 2009. 3:02 PM
Nice! Very Cool!
LinuxH4x0r says: Jan 5, 2009. 8:39 PM
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
