Cedar Succulent Planter
2,937
158
5
Posted
Introduction: Cedar Succulent Planter
Make this lovely succulent planter out of 3x3 cedar plank.
Step 1: Cut Your Stock to Length
I had 1000mm (40'') long piece of 3x3 cedar so I cut in in half to make two of these.
You can make it any length you need/like.
Preferably use rot resistant wood for this project.
If you can't find or buy it you can do this project with any wood, even a driftwood would be great.
Step 2: Drill Planting Holes
Find the middle of your piece and drill a 2'' (50mm) hole but NOT all the way through!
If your drill has speed control set it on the lowest setting (highest torque) and hold the drill securely.
I used 2'' Forstner bit but you can use any type of bit that will give you this hole diameter.
Please, use safety glasses/googles!
PS. This drilling will make a lot of chips :)
Step 3: Drainage Holes
Use 1/4'' (6mm) drill bit to drill the drainage holes.
The hole goes through, please see the images.
Step 4: Plane & Sand
Use a hand plane to take off the sharp corners and then sand with 120 and 220 grit sandpaper.
Step 5: Sign Your Project
Signature Transfer:
I sign my work with ink transfer onto wood.
I use laser printed mirror image of my design and pass it
with thinner onto the wood (it is very easy but takes a bit of practice).
Try it first with something you have laser printed on a normal paper (gloss and ink-jet print won't work).
Step 6: Finish It
I used beeswax-oil finish but you can use any finish you like.
I recommend using non-glossy finishes as they ruin the natural beauty of the wood.
Then again, if you like the sparkle and bling - all the power to you!
Step 7: Plant It!
Use any type of plants to plant your planter (that is a lot of word plant in one sentence).
I like succulents because they are very resistant plants and don't need much water (good for the wood) and confess it, they look beautiful.
Step 8: Enjoy It!
Did you like my Instructable?
Let me know in the comments (I love those), like it and follow me on Instructables.
Click HERE and subscribe to my YT channel for more cool projects and videos.
PS If you really liked it please share it with your friends and family...it means a lot and I really appreciate it!
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
5 Comments
Hi,
it's called the font you use for your signature ? that the product uses to transfer the ' image on the wood ? thanks a lot...
Andrea
Hi, I really don't know. I made them over a year ago and I made vector image so I don't have the font. Sorry.
