To skip to the videos of the nightlight in action, click here!
Update: I received many complaints about the aesthetic quality of the pull chain nightlight's installation and several suggestions that I should place the circuit in the diffuser bowl. Well I'm pleased to announce that I've reworked this project to keep the circuitry out-of-sight and make the pull chain wiring look better. Steps 1 through 5 describe the rework as if I started from scratch, and steps 7 through 10 are the original instructable.
The primary source of illumination for my bedroom is a ceiling fan lamp. Most of the time I use the wall switch to turn the light on and off, but sometimes I'm closer to the pull chain switch so I'll use it instead. The trouble is the pull chain can be impossible to find in the dark; sometimes I'll find it right away but other times I'll flail my whole arm around feeling like an idiot trying to locate it. So I decided to hack apart a solar powered garden light and use its LED to make the pull chain's handle glow. When the garden light circuit detects the ceiling fan lamp is off it powers the LED with a battery. The circuit also recharges the battery when the lamp is on via a solar cell.
Step 1: Disassemble the Garden Light
Solar Garden Light -- Portfolio Stainless Steel Solar-Powered LED Path Light (Item #: 329346 | Model #: 00942)
Pull Chain with a Translucent Handle -- Harbor Breeze Brushed Nickel Ceiling Fan Pull Chain (Item #: 101858 | Model #: FP5)
Enclosed 2x AA Battery Holder -- Radio Shack 278-502
~30 in (~75 cm) of Wire Wrap Wire (30 AWG) -- Radio Shack 270-408
A piece of Scrap Copper Sheet Metal (about the size of a battery contact)
Heat shrink insulation or Sewing Thread
Soldering Iron
Solder
JB Weld
Hot Glue Gun
Hot Glue
Drill
Phillips Screwdriver
Pliers
Diagonal Cutters
Wire Stripper
For this instructable I used this garden light. First I separated the end that held the globe and electronics from the metal tube and removed the battery. Then I removed several sets of screws to separate the electronics from its housing. Next, I gently pried the hot glued photoresistor from it's mounting hole, and then removed the excess hot glue. I used diagonal cutters to snip the battery leads where they met the battery contacts. Then I cut the LED's wires so I could insert it into the pull chain's handle in step 4. Finally I desoldered the solar cell so it could be taken out of its plastic holder.
Step 2: Prepping for the New Enclosure
Step 3: Putting the Circuit in the Battery Holder
Step 4: Modifying the Pull Chain
Step 5: Installation
Step 6: Interstitial
To skip to the demonstration click here.
Step 7: Disassemble the Garden Light
Clear Battery Storage Case
Hooks taken from a Plate Hanger
Barrel Plug
Barrel Jack
Soldering Iron
Solder
JB Weld
Hot Glue Gun
Hot Glue
Drill
Pliers
Diagonal Cutters
Wire Stripper
For this instructable I used this garden light. First I separated the end that held the globe and electronics from the metal tube and removed the battery. Set aside the battery, but don't discarded it because you'll need it later. Then I removed several sets of screws to separate the electronics from its housing. Next, I gently pried the hot glued photoresistor from it's mounting hole, and then removed the excess hot glue. I used pliers and diagonal cutters to remove and reshape the battery contacts. Finally I desoldered the solar cell so it could be taken out of its plastic holder.
Step 8: Placing the Circuit in a New Enclosure
Step 9: Modifying the Pull Chain
Step 10: Installation
You may have noticed this build doesn't exactly have the nice finished look of a consumer off-the-shelf product. This project was originally a hack, one-off proof of concept. However, I have since reworked it to make the pull chain modification look better and hide the circuit board (see steps 1-5). I still think hanging the board outside of the diffuser bowl is the best approach. It could be made to look much better by designing a custom, hanging enclosure that looked decorative. Perhaps something that looked like a stained glass flower where the LED's wires follow the stem down to a pull chain which integrate the wires seamlessly.
Step 11: Demonstration
Here's a close-up video of the light-up handle in action.
Here's a video showing how easy the handle is to find in a dark room.
Final Thoughts
I was afraid that putting the circuit board in the diffuser bowl so close to the hot lamps would create a fire hazard, but after replacing the lamps with CFLs and measuring the temperature in the bowl I concluded that it was probably safe. I was also worried about some part of the circuit accidentally contacting mains and electrifying the pull chain or starting a fire. However, there seems to be enough room in the bowl and the pull switch is constructed such that accidentally contacting mains appears unlikely. However, these risks are real possibilities and you follow this instructable at your own peril. You are responsible for your own safety. The reason I've left the original instructable intact is because I feel it is much safer and its installation step is both easier and depends less on having a specific type of lighting fixture.
If I were to redesign this as a product to be sold, I would look into making a new pull chain switch that has an integrated AC to DC converter and a new pull cord that can deliver power to the LED in the pull handle while standing up to the wear of being pulled on many times a day for years. The idea of a lighted pull chain handle has been patented since at least 2001. Maybe the engineering challenges of designing it to be safe while still being economical aren't realizable.
Oddly, after a period of time the LED cuts off even if the battery still holds a good charge. Since the intent of the original garden light was for decorative purposes and not providing illumination, I'm guessing that there is a timer that controls how long the LED stays on so that it doesn't shine late at night when no one is around to appreciate it, but this is only a guess. Additionally, given that the LED puts out more light than needed and changes colors constantly it may disrupt sleep. A solar garden light meant to provide illumination throughout the night paired with a high efficiency red LED, which will help preserve night vision, may be a better solution.
Bonus Hack: In the planning stages of this project I considered using the pull chain as part of the return leg of the LED's circuit. So I connected the pull chain to a multimeter and selected the continuity test; it showed an open circuit. However, when I pulled the chain tight the resistance drop to only a few ohms. Therefore, if you need a simple on/off stretch sensor, then using a pull chain might not be a bad option.
Links
How a Solar Garden Light Works
Visit Our Store »
Go Pro Today »
I'm currently working on an updated version where I put the circuitry in the diffuser bowl. So look out for it!
Nonetheless, I agree with the other posters. This is a fantastic idea.
Coat hanger + hot glue maybe?
