3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ceiling Mounted Wiimote Whiteboard
This Instructable will give you step by step instructions on making a very cheap ceiling mount for a wiimote for use with a ceiling mounted projector. This works great in class rooms or board rooms where the projector is permanently mounted on the ceiling.
Step 1Gathering Supplies
Gathering Supplies
First lets get everything together. Here's a run down of all the items you'll need:
1 - 12inch shelf bracket
1 - dollar store mini tripod
1 - 3v transformer
1- 1/4 flanged hex nut
1 - 8/32 X 1" machine screw
2 - 8/32 nuts
1- PC slot Blank
2 - standard wire ties
Some tools you will need:
Philips screw driver
Hacksaw
Drill
Wire cutters
Electrical Tape
The hardest thing to find will probably be the 3v transformer. I got mine from a bunch of wireless access points that are being powered over ethernet so we didn't need the transformers. You can most likely find one on eBay or at an electrical supply company.
20 comments
Jun 11, 2011. 2:03 AMvsingh9 says:
hi do you think it works well when its mounted with projector as i believe when using white board if your IR led is hidden it wont send signal to wii remote.
Or do you thinks its the best place to place it
thanks
vikas
Aug 5, 2010. 11:26 PMRonnieJi says:
I think the point of mounting a wiimote to a projector is to fix the position of the wiimote so you don't have to recalibate everytime.  In that case, you can use the software like iWiiBoard to run the calibrated wiimote whiteboard automately with the startup of your system.
Nov 12, 2009. 10:37 AMmastermayhem117 says:
I may be naive, but what precisely is the point of mounting a wii mote to a projector??
Dec 5, 2009. 9:16 PMmrkleing says:
 Create an interactive whiteboard
Nov 13, 2009. 8:44 PMjimtran93 says:
 I wasn't sure either! This might help explain more...
www.instructables.com/id/Low-Cost-Multi-touch-Whiteboard-using-the-Wii-Remo/
Dec 3, 2009. 8:19 PMartobot says:
This is great, I've been exploring options for wii mote deployment at our school for a while now. This is a perfect and cheap solution!
Thanks for posting this. :)
Nov 12, 2009. 2:07 PMthatoneguydavid says:
If you mount the Wii mote on the wall perpendicular to your "white board" instead of directly next to the projector you will not have to stand so far to the the right or left of your pointing device.  the calibration step in the set up of your white board will take care of the strange angles.
Oct 31, 2009. 7:09 PMRonnieJi says:
Very useful! I like the idea of the power supply and the way turns wiimote to discover mode.
Sep 2, 2009. 5:22 PMmatt ledding says:
Nice wiimote stand... it looks professional. what percentage of the screen do you cover? for the power supply I just hooked a usb charger to a usb charged battery... it is taking in 5 volts and using 3 so I am sure it is not good for the memory of the battery, but hey... seems to work.
Apr 13, 2009. 7:59 AMmunchman says:
Cool, however there is a flaw in your idea. Consider the way someone stands when writing on a whiteboard, typically, they stand in front of the text they are writing, so this would obscure the IR light coming from the back. The angle suggested by the original project eliminates this, you need to find a workaround (rear-projection maybe?)
Apr 15, 2009. 1:33 AMfrollard says:
but the whiteboarding they will do will be 'invisible' until the projector sees it - so they will be forced into a stance where they're drawing outside of their own shadow.
Apr 12, 2009. 12:19 PMjoejoerowley says:
How well does it work considering its not at an angle to the projector? I thought you needed it to be at decent angle to the projector if it isn't projecting straight down onto a table or something like that.
Apr 12, 2009. 5:45 PMfinfan7 says:
how well this works would depennd on ones hand position. If your hand blocks the IR LED then this won't work. Optimum positioning is on the left side of the board at a ~30 degree angle from the wall unless you are left handed.
Apr 11, 2009. 5:49 AMPhil B says:
I guess a wilmote is some sort of remote for controlling the projector, but I do not know. You can also adapt other power adaptors for 3 volts output. Just go to Radio Shack and get an LM317 variable voltage regulator chip. There are many sets of on-line instructions for how to configure it for any output you want. The one requirement is that the power supply you are adapting must have an output at least 1.2 volts higher than your desired final output of 3 volts.
Apr 11, 2009. 11:04 AMpoolshark162006 says:
no its like a smartboard which you can "write" on the screen. http://johnnylee.net/projects/wii/
Apr 11, 2009. 10:13 AMLinuxH4x0r says:
I think its used in some sort of tracking.
Apr 11, 2009. 12:40 PMcyrozap says:
The IR camera sensor is used to track up to four points of IR light.
Apr 11, 2009. 10:08 AMPhil B says:
I see it is not a wilmote, but a Wiimote, a remote for a Wii game.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:shaggymook
