Ceiling Fan Blade Book Shelf
Introduction: Ceiling Fan Blade Book Shelf
Hi this is my first Instructable I had some fan blades from an burnt out ceiling fan i was saving for a project lying around and decided to use them to make an book shelf.
Step 1: Step 1: Tools and Materials
The tools you will need is:
1X bench Vice
1X paint can
1x can of machine fluid
1X grinder with flaper disk
1X hack saw
1X water level
2X files
1X phillips screw driver
1X marking pencil
1X dial caliper
1X hand drill with hammer action and concrete drill bit
1X press drill with a clamp and metal drill bit
1X welding machine
and safety equipment
The materials:
3X Fan blades
4X screws and wall plugs
1X 160cm flat bar.
Step 2: Step 2: Measure and Cut Flat Bar.
Measure two 55cm lengths of the flat bar and clamp it into the bench vice. Cut the bar with the hack saw I used some machine fluid to make it easier.Cut six 8cm lengths from the remaining flat bar.
Step 3: Step 3: Weld the Pieces Together.
I took the old trustee arc welder and welded three of the 8cm flat bar lengths to the 55cm length. the first one is 5 cm the next one at 30 cm and the last one at 50 cm. This was my first attempt at welding so please excuse my bad welds. I had watched a welding course by a you tuber called ChuckE 009 which helped a lot.
After I was done with both I used the grinder and flaper disk to clean up my welds and then the files to smooth the whole project of any sharp edges.
Step 4: Step 4: Drill the Holes.
Next I marked where the holes should be to fasten it to the wall and used the press drill and clamp to drill them.
Step 5: Step 5: Paint
Next I painted them with some rustolem paint aas the has primer built in which just saves time. If you are going to paint it with normal paint you will need to put on a good primer to stop it from rusting.
Step 6: Step 6: Measure and Drill the Holes in the Wall.
I had some existing holes from a old shelf that was removed a long time ago which i used as a starting point. I screwed the bottom of the mounting bracket i had made in and used the the water level to make sure i had it strait. Once I was happy with the location I used the marking pencil i marked where I wanted to drill. Just as a word of warning the old adage of measure twice drill once came up as I had drilled in the wrong location.
Step 7: Step 7: Putting It Together.
Take the srews and wall plugs and screw the brackets on to the wall and just lay the blades down on the brackets.
Step 8: Step 8: Finnish It Up.
Now all that is left is put your favorite books on the shelf and admire your work.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    This is great work . . . the shelves, and the documentation! I'd love to see more of your projects on here. Great first instructable!
    Thank you, hope my English was understandable it is not my first langue.
    Must have been pretty good... everything made perfect sense to me!
