Cell Phone Night Vision - Under $10
 by iSteam
1-40 of 50Next »
dodo91 says: Jan 6, 2009. 8:15 PM
I was watching a video on youtube, and when the guy pushed a button on the remote, you could see it. my point: you don't have to rip your phone apart. instead, attach the IR LED to something in the phone, then tape it next to your lens OUTSIDE the camera (Duh)
static in reply to dodo91Nov 12, 2012. 5:50 PM
I posted such a video to youtube  after a forum discussion if an unmodified digital camera could be used to detect if a remote control was functioning. That video was up close and personal, but have seen cell phone cameras see the output up to 6 feet away.  Someone at you tube musta added the silly audio track I didn't
JP128 in reply to dodo91May 11, 2010. 4:07 AM
 Most/All cameras can see infrared light. In fact - most people can see in the dark. But just because you can see, or it can see doesn't mean that it can be seen well. The IR is a Filter, just as a coffee filter is a filter. With a coffee filter - it's purpose is to stop the grains from coming out, but what do you ALWAYS find at the bottom of the pot or your glass? Grains. Like the coffee filters, IR Filters aren't 100% IR Proof, meaning that you will still see it. Turning the remote away from the lens and trying to view it like say, on a white piece of paper, proves what I said. Without the IR filter alex is right - you can basically light a room with a remote.
Fluffyjimmy in reply to dodo91Sep 23, 2009. 4:42 PM
i just tried this using my remote and phone. Yeah you can see the IR light on the phone camera without modifying it but all i can do is point the light at the camera, it doesn't show up on any surfaces or anything because it's so weak.
dodo91 in reply to FluffyjimmyNov 19, 2009. 8:28 PM
thats because you need the black thing covering IR LED. you also might need a few.
Sandisk1duo in reply to FluffyjimmyNov 3, 2009. 6:49 AM
it's not that weak, your IR filter is just blocking it.
Fluffyjimmy in reply to Sandisk1duoNov 3, 2009. 5:21 PM
Ok good, I'm probably going to get rid of the filter then.
milsorgen in reply to FluffyjimmyJan 26, 2010. 7:19 PM
 low light and more watts if you dont want to rip open anything. ive been using 16-32mw and ~1sec exposure times in a dark with my digital camera and getting results
thelastonekills in reply to milsorgenApr 21, 2011. 4:34 AM
hold it, let me make sure i got this
in short ,
put filter on camera
put filter infront of realy bright light or ir led?
also could this be done some how more analoge, like just with the ir light and a
filter set up some how so you could see it?
this is cool 5/5
cbateman3 says: Feb 26, 2012. 8:28 AM
Dont screww up your cell phone. You can buy a real IR glass filter 850nm
that and holder that attaches to your cell phone or tablet at http://xrayeffect.com
jimmy dean says: Apr 6, 2010. 4:49 PM
How do you unscrew the lens from the camera module? There are no screwdriver slots anywhere on it.
cgosh in reply to jimmy deanDec 13, 2011. 3:37 PM
Imagine you're twisting off the twist-off cap on a bottle of soda pop and you'll get the idea. No screwdriver needed. Many times, this is also how you adjust the focus on the camera.
chubby8 says: Jul 15, 2011. 10:02 AM
if you didnt put the Congo Blue Film Gel in wouldent the camera see visible light in the day and infared in the dark although a slight mix. or would day time photos in visible light just mess up.
nwalsh says: Jun 5, 2011. 4:01 PM
Is there a way I can get a cellphone cam to work with regular video input? Im trying to do a spy cam project w/ night vision and don't feel like buying some expensive camera.
prokia789 says: Nov 24, 2010. 6:00 AM
there is a IR filter on my phone`s CCD...any way i can remove it?
madyicstik says: Jun 22, 2010. 7:35 AM
hi i have a question.. can i use this lens to raplce the original lens on the phone? this will give me a wide angle view. i will still put the congo blue film in between this lens and the semiconductor. ive also googled tha the regular negative film will work as good? can you please confirm?
madyicstik in reply to madyicstikJun 23, 2010. 8:26 AM
i guess it would help if i have the linl lol http://www.dealextreme.com/details.dx/sku.22880
msw100 says: Sep 7, 2008. 11:01 AM
A mobile phone can already see the IR from a remote control without going to all that trouble and breaking your phone. Why not mount a few low power IR diodes around the lens, and you will see just as far in the dark.
iSteam (author) in reply to msw100Sep 9, 2008. 6:07 PM
Not nearly as well as without an IR filter...
lunchboxslayer27 in reply to iSteamJan 19, 2009. 12:59 PM
pretty well actually
Sandisk1duo in reply to lunchboxslayer27May 23, 2009. 9:03 PM
without the filter, you can actually light up the room with a remote control
JP128 in reply to Sandisk1duoMay 11, 2010. 4:03 AM
Jehar21 says: Feb 9, 2010. 2:04 PM
This worked really well. I did it to one, about to do it to 3 other phones too.
Its gonna really help for our night paintball games.
Thanks
mossDboss says: Aug 18, 2008. 3:02 PM
Don't all digital cameras see infared without modification. That is, I can take any digital camera and put a remote in front of it and the camera will "see" the infared of the remote. So maybe I missed something, what is the point of this instructable?
iSteam (author) in reply to mossDbossAug 18, 2008. 6:33 PM
Lol, by removing the IR filter you can see much, much more IR light. If you add an external light source, such as an IR LED flashlight, it appears extremely bright bright to the camera without the IR filter. To the camera with one, it appears a dim glow. Removing the IR filter effectively creates a homebrewed Nightvision infrared viewing device.
imkwl12345 in reply to iSteamJul 14, 2009. 3:58 AM
ok i need some help here. what does the congo blue actually do? can you still see the IR as well without it?
Mitten in reply to mossDbossAug 18, 2008. 4:25 PM
The only reason you can see the remotes infrared is because its a high intensity source. Theres tons of radiant infrared energy bouncing all around that is blocked by the filter. Check out some of the other infrared lens modifications on digital cameras (they can see the remotes light too).
berky93 says: Jan 19, 2009. 3:13 PM
I wonder if theres an easy way to add a little lever to move the ir filter/ gel back and forth, to switch between normal and night vision. also add an IR led light onto the phone.
imkwl12345 in reply to berky93Jul 14, 2009. 3:56 AM
the way i see it, correct me if im wrong because i dont no much about the subject, but isnt the filter you put in meant to stop the light we can see? so if you just take out the filter already in it you can see IR at night, and normal in daytime?? help?
the "wow shammy" says: Jun 22, 2009. 11:43 AM
if you take off the filter will it make your pictures go dead forever?
Nexnaught says: Jun 2, 2009. 2:06 PM
Wouldn't u be able to see better in the dark if the camera could see visible AND IR light than just IR light?
mraspotcnc says: May 24, 2009. 1:01 PM
nice job ....thanks to share idea
Sandisk1duo says: May 23, 2009. 9:04 PM
does this ruin the quality of the camera (does everything get blurry?)
lunchboxslayer27 says: Jan 19, 2009. 12:59 PM
you can see the IR from the remote without doing this
Sandisk1duo in reply to lunchboxslayer27May 23, 2009. 1:50 PM
that little 'glow' that you can see with your eyes is not IR
EaglesNestOne says: Sep 7, 2008. 10:20 PM
Nice IBLE but aren't infrared blocking filters usually blue? And msw100 is right, in fact most cameras can see infrared light.
iSteam (author) in reply to EaglesNestOneSep 9, 2008. 6:06 PM
Depending on the manufacture and what products they order, it can either be blue or red. In the majority of cameras I've sacraficed to science, I believe only 1 I remember seeing a blue filter . It stood out, thats why I remember ;)
astro64 says: Sep 7, 2008. 2:30 PM
hi,got a razor v3 cellphone any idea how to mod this phone for night vision thanks.
A good name says: Sep 3, 2008. 8:08 PM
I can't see the inner yellow square... it always picks the first one.
iSteam (author) in reply to A good nameSep 5, 2008. 8:10 PM
It just says that it's a lens modification I did, not important in the context of this instructable
1-40 of 50Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
