I had to find a solution. I checked into an external antenna for my cell phone but found they cost nearly $50.00 and there was some question about whether they actually work. I knew there had to be a better way. While working in my yard one afternoon I noticed an old satellite TV dish on top of a pole in my backyard. It had been left there by the previous residents. Suddenly a light bulb came on. I grabbed some wrenches, took down the dish and held my cell phone next to the antenna's horn and pointed the dish in various directions. I was amazed to find that I got full signal in one direction. I could not believe my eyes. I went from no signal to full signal and had not spent a dime or changed anything on my cell phone. Just to make sure I made a call using speaker phone and found that this thing truly did work.
The next test came when I took the assembly inside the house to try it. With aluminum siding on the house I have problems even getting a television signal using a rabbit ear antenna. To my surprise, I got two bars inside so long as I pointed the dish at a double window in my living room. I no longer miss calls and I don't have to leave home to talk on my cell phone. Using a blue tooth headset really worked well. It isn't an ideal setup but it works and did not cost me anything. It is also a great way to recycle that old dish antenna that would have ended up in the trash otherwise.
I had a friend give me another old dish that I used for wi-fi. I mounted it on the pole the other dish came off of. After some tweaking I found several really strong wi-fi signals that I could not get without the dish.
Remove these ads by
Signing UpStep 1Setting Up The Antenna Booster
To get cellular and wi-fi signals is not an option I tought possible ... I have to see to believe ... be sure I'll make some test soon !
Don't we have to line-up with a tower ?
Use the shortest cable run that you can - certainly not more than several yards, unless you are prepared to spring for something like "Andrews Heliax", which is
E X P E N S I V E !
Otherwise, all that signal that you got by using the dish will just vanish coming down the cable!
Here is the exact antenna I was referring to-
http://www.wilsonelectronics.com////ViewProductB.php?ID=1
P.S., it is mounted above the roof line of my house and works great.
Amazing to get such awesome tech at a truck stop.
The antenna has great claimed gain for its size (but remember that "dBi" is not "gain over a dipole" - the figures would be lower in dBd)
Even for a short tail, RG58 really is too lossy at 800MHz or 1600MHz, and the 3 yds extension cable advertised would double the loss! (plus the extra loss from 2 more connectors)
Having said that - it's still going to be better than the standard cell antenna, inside the cab! But a better solution would be an antenna with something like RG8 low-loss cable, and it should plug into an antenna socket on the phone (not "couple" by a few turns of wire around the phone antenna, or through a plate stuck to the phone)
Good luck, and happy phoning!
On Topic: My wife now lives in a rabbitbox or as some refer to them, a tornado magnet (mobile home). Forget getting a wireless signal in there; but by going outside she receives marginal one. I will be trying this out, probably this weekend. Thanks for the tip, and, again, welcome. Will advise about reception. RR
I've had success before getting wifi signals far away...but my problem was always trasmitting data on my side back to the routers.
Does this solve that?
