loading
This Instructible is entered in the Category: 13 - 18of the National Robotics Week Robot Contest
MY URL-http://avadhutelectronics.blogspot.com/
MY Email-avadhut.deshmukh@gmail.com
Step 1: Component Required
Component Required:
IC1 - MT8870 DTMF decoder
IC2 - ATmega16 AVR microcontroller
IC3 - L293D motor driver
IC4 - 74LS04 NOT gate
D1 - 1N4007 rectifier diode
R1, R2 - 100-kilo-ohm
R3 - 330-kilo-ohm
R4-R8 - 10-kilo-ohm
C1 - 0.47μF ceramic disk
C2, C3, C5, C6 - 22pF ceramic disk
C4 - 0.1μF ceramic disk
XTAL1 - 3.57MHz crystal
XTAL2 - 12MHz crystal
S1 - Push-to-on switch
M1, M2 - 6V, 50-rpm geared DC motor
Batt. - 6V, 4.5Ah battery
Step 2: INTRODUCTION
INTRODUCTION
Conventionally, wireless-controlled robots use RF circuits,which have the drawbacks of limited working range, limited frequency range and limited control. Use of a mobile phone for robotic control can overcome these limitations. It provides the advantages of robust control, working range as large as the coverage area of the service provider,no interference with other controllers and up to twelve controls.Although the appearance and capabilities of robots vary vastly, all robots share the features of a mechanical, movable structure under some form of control. The control of robot involves three distinct phases: reception, processing and action. Generally, the preceptors are sensors mounted on the robot, processing is done by the on-board microcontroller or processor, and the task (action) is performed using motors or with some other actuators.
In this project, the robot is controlled by a mobile phone that makes a call to the mobile phone attached to the robot. In the course of a call, if any button is pressed,a tone corresponding to the button pressed is heard at the other end of the call. This tone is called ‘dual-tone multiple-frequency’ (DTMF) tone. The robot perceives this DTMF tone with the help of the phone stacked in the robot. The received tone is processed by the ATmega16 microcontroller with the help of DTMF decoder MT8870. The decoder decodes the DTMF tone into its equivalent binary digit and this binary number is sent to the microcontroller.The microcontroller is preprogrammed to take a decision for any given input and outputs its decision to motor drivers in order to drive the motors for forward or backward motion or a turn. The mobile that makes a call to the mobile phone stacked in the robot acts as a remote. So this simple robotic project does not require the construction of receiver and transmitter units. DTMF signaling is used fr telephone signaling over the line in the voice-frequency band to the call switching centre. The version of DTMF used for telephone tone dialing is known as ‘Touch-Tone.’DTMF assigns a specific frequency (consisting of two separatetones) to each key so that it can easily be identified by the electronic circuit. The signal generated by the DTMF encoder is a direct algebraic summation, in real time, of the amplitudes of two sine (cosine)waves of different frequencies, i.e., pressing ‘5’ will send a tone made by adding 1336 Hz and 770 Hz to the other end of the line. The tones and assignments in a DTMF system are shown in Table I.
Step 3: SCEMATIC OF CELLPHONE OPERATED LANDROVER
CIRCUIT DESCRIPTION
Fig. 1 shows the block diagram of the microcontroller-based mobile phoneoperated land rover. The important components of this rover are a DTMF decoder, microcontroller and motor driver. An MT8870 series DTMF decoder is used here. All types of the MT8870 series use digital counting techniques to detect and decode all the 16 DTMF tone pairs into a 4-bit code output. The built-in dial tone rejection circuit eliminates the need for pre-filtering. When the input signal given at pin 2 (IN-) in single-ended input configuration is recognised to be effective, the correct 4-bit decode signal of the DTMF tone is transferred to Q1 (pin 11) through Q4 (pin 14) outputs. Table II shows the DTMF data output table of MT8870. Q1 through Q4 outputs of the DTMF decoder (IC1) are connected to port pins PA0 through PA3 of ATmega16 microcontroller (IC2) after inversion by N1 through N4,respectively. The ATmega16 is a low-power, 8-bit, CMOS microcontroller based on the AVR enhanced RISC architecture. It provides the following features: 16 kB of in-system programmable Flash program memory with read-while-write capabilities, 512 bytes of EEPROM, 1kB SRAM, 32 general-purpose input/output (I/O) lines and 32 general-purpose working registers. All the 32 registers re directly connected to the arithmetic logic unit, allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architecture is more code-efficient. Outputs from port pins PD0 through PD3 and PD7 of the microcontroller are fed to inputs IN1 through IN4 and enable pins (EN1 and EN2) of motor driver L293D, espectively, to drive two geared DC motors. Switch S1 is used for manual reset. The microcontroller output is not sufficient to drive the DC motors, so current drivers are required for motor rotation. The L293D is a quad, high-current, half-H driver designed to provide bidirectional drive currents of up to 600 mA at voltages from 4.5V to 36V. It makes it easier to drive the DC motors. The L293D consists of four drivers. Pin IN1 through IN4 and OUT1 through OUT4 are input and output pins, respectively, of driver 1 through driver 4. Drivers 1 and 2, and drivers 3 and 4 are enabled by enable pin 1 (EN1) and pin 9 (EN2), respectively. When enable input EN1 (pin 1) is high, drivers 1 and 2 are enabled and the outputs corresponding to their inputs are active. Similarly, enable input EN2 (pin 9) enables drivers 3 and 4. An actual-size, single-side PCB for cellphone-operated land rover is shown in Fig. 4 and its component layout in Fig. 5.
Step 4: SOFTWARE DESCRIPTION AND WORKING
The software is written in ‘C’ language and compiled using CodeVision AVR ‘C’ compiler. The source program is ed into hex code by the compiler. Burn this hex code into ATmega16 AVR microcontroller.The source program is well commented and easy to understand. First include the register name defined specifically for ATmega16 and also declare the variable. Set port A as the input and port D as the output. The program
will run forever by using ‘while’ loop. Under ‘while’ loop, read port A and test the received input using ‘switch’ statement. The corresponding data will output at port D after testing of the received data.
WORKING
In order to control the robot, you need to make a call to the cell phone attached to the robot (through head phone) from any phone, which sends DTMF tunes on pressing the numeric buttons. The cell phone in the robot is kept in ‘auto answer’ mode. (If the mobile does not have the auto answering facility, receive the call by ‘OK’ key on the rover-connected mobile and then made it in hands-free mode.) So after a ring, the cellphone accepts the call. Now you may press any button on your mobile to perform actions as listed in Table III. The DTMF tones thus produced are received by the cellphone in the robot. These tones are fed to the circuit by the headset of the
cellphone. The MT8870 decodes the received tone and sends the equivalent binary number to the microcontroller. According to the program in the microcontroller, the robot starts moving.When you press key ‘2’ (binary equivalent 00000010) on your mobile phone, the microcontroller outputs ‘10001001’ binary equivalent. Port pins PD0, PD3 and PD7 are high. The high output at PD7 of the microcontroller drives the motor driver (L293D). Port pins PD0 and PD3 drive motors M1 and M2 in forward direction (as per Table III). Similarly, motors M1 and M2 move for left turn, right turn, backward motion and stop condition as per Table III.
Step 5: CONSTRUCTION
When constructing any robot, one major mechanical constraint is the number there a two-wheel drive or a four-wheel ive. Though four-wheel drive is more complex than two-wheel drive, it provides more torque and good control. Two-wheel drive, on the other hand, is very easy to construct. Top view of a four-wheel-driven land rover is shown in Fig. 3. The chassis used in this model is a 10×18cm2 sheet made up of parax. Motors are fixed to the bottom of this sheet and the circuit is affixed firmly on top of the sheet. A cellphone is also mounted on the sheet as shown in the picture. In the four-wheel drive system, the two motors on a side are controlled in parallel. So a single L293D driver IC can drive the rover. For this robot, beads affixed with glue act as support wheels.
Will this work with a 4*4 matrix keypad which produces same frequencies that mobile produces.
<p>no a 4*4 is multiplexed or at least normally and does not give high&amp;low outputs</p>
http://www.youtube.com/watch?v=TDVP-pXQmgU
<p>I&rsquo;m working on a project which is about making a rescue <br>robot . I have struggling with it for 4 months and now all the mechanical works <br>had been done . but I&rsquo;m facing difficulty in make the robot to work with rf <br>module can u plzz help me&hellip;</p><p>I want make transmitter and receiver that can control the <br>motion&hellip;I mean that receiver should have control 8 dc gear motor and each dc <br>motor should have a forward and backward botton to control the motion &hellip;&hellip;can u <br>kindly help me with this project &hellip;.if u can make the circuit board diagram for <br>the PCB &hellip;.or any other suggestion plz reply&hellip;&hellip;mail me at &ldquo;sunny1995gagan@gmail.com&rdquo;</p>
<p>google ht12d and ht12e. it will give you the basic knowledge about using rf easily but why rf??? it has a tiny (teeeny weeny) range of only 50-100 meters.</p>
<p>yaar any body has the program &amp; p.c.b layout of this project plz send me on abhibhadula1992@gmail.com plzz urgent help</p>
<p>you can make it without microcontroller if you donot wanna burden yourself with the program. connect outputs deirectly to the l293d inputs. it gives the outputs as a high or low so that your project would work</p>
<p>can an iPhone work as a receiver ?</p>
<p>yes i-phone is a phone is it not????</p><p>sry steve jobs</p>
Where i can buy Motor M1 and M2 in india . plz reply ...
<p>http://www.nex-robotics.com/</p>
how to connect ear phone with it???which wire we should give to the input dtmf decoder ... and which should be grounded????
tip=tone and ring=GND <br><br>tip to green wire from jack and black to GND from Jack to connect ear phone done :)
<p>do you have c language program for this project?</p>
<p>What are the components and circuit required to the this same project with atmega8 microcontroller??? </p>
<p>Was this Atmega 16 used SPI or Uart for communicatn with DTMF</p>
<p>WHY WE ARE USING NOT GATE AT THE OUTPUT OF 8870.</p><p>PLEESE REPLY ME ON MY EMAIL KIRAN.ENTC2@GMAIL.COM</p>
thanku for the project i question sir, will this microcontroller n devlopment board do it-<br> 1) http://www.ebay.in/itm/Buy-Atmega168-IC-Arduino-Duemilanove-Boot-loader-WDT-16Mhz-Version-/261240783294?pt=LH_DefaultDomain_203&amp;hash=item3cd32a01be#ht_1304wt_906<br> <br> 2)http://www.ebay.in/itm/New-Atmel-AVR-28-Development-Board-projects-Microcontroller-not-included-/261240967992?pt=LH_DefaultDomain_203&amp;hash=item3cd32cd338#ht_1129wt_906
hey buddy <br>well thanks <br>where did u got the wheels about 1/2&quot; thick??? <br>how should i increase it's speed???
http://thehobbyshop.in/index.php?main_page=index&amp;cPath=43_45 <br> <br>please suggest me the components required.
So it means it will work....
i want to make this robot, can u please guide me in detail.? <br>
can you tell me how to interface serial ttl gsm modem with dtmf decoder instant of cell phone
any one would be kind enough to help me with designing a obstacle detector with this cell phone operated robot would be a big help
can get the coding for my last project , please
https://www.instructables.com/id/Cellphone-Operated-Robot-1/step4/SOFTWARE-DESCRIPTION-AND-WORKING/ <br> <br>you can download <br>
WHERE CAN I PURCHAS ALREADY MADE DTMF DECODER $ HOW MUCH
which cell phone model i can use sir?.how to know a cell phone is working with DTMF or not?
only nokia old ! <br> <br>samsung not working !
Sir, Good day, I'm going to ask if where do i put the separate voltage for the MT8870 decoder IC? and can you please guide me in how to mount the earplug to the circuit?
are u use voltage regulator and why u use it......and where.....
only 6v !
can i use 80v51 RD2 OR 8051 MICROCONTROLLER ?????<br>withe same code???<br>
Same no !
dixitad88@gmail.com
sir how did u connect the mt8870 DTMF to not gate and to atmega 16?..
can u please tell me what would be total cost of project (cost of components) in rupees
Rs.500-1000/- low price ! ! :)
how to burn the atmega 16<br>
AVR ISP programmer burn !!!! Yes !
really nice project dude................
how to identify Ring &amp; Tip in Ear Phones???? and can v use any mobilephone @ robot end!!!<br>
interesting stuff
did you use ceramic capacitor of &quot;0.47micro farate&quot; ??. I have used electrolytic but circuit is not working.<br>plz rply soon..............
i dot think u would get a electrolyte capacitor of 0.47uf thats impossible<br>u can get a ceramic capacitor of 0.47uf
the motor is running as soon as i put da battery..da driver is not listening to the mc..wat to do??<br>
great job, but you should post some pictures of the actual building process and maybe a video of it operating
About This Instructable
93,152views
122favorites
License:
Bio: I like to build robots We make robots, computer ,rocket ,tech and hacking videos, and other robot build my youtube username --Avadhut1003 www.avadhutelectronics.blogspot ...
More by Avadhut.Deshmukh:NEJE DK - 5 Pro 500mW USB DIY Mini Laser Engraver - USER MANUAL  Google doodle Basketball hack full points ! ganapati papercraft template
Add instructable to:
