3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cellphone operated Robot
Conventionally, Wireless-controlled robots use rf circuits, which have the drawbacks of limited working range, limited frequency range and the limited control. Use of a mobile phone for robotic control can overcome these limitations. It provides the advantage of robust control, working range as large as the coverage area of the service provider, no interference with other controllers and up to twelve controlles.
Although the appearance and the capabilities of robots vary vastly, all robots share the feature of a mechanical, movable structure under some form of control. The Control of robot involves three distinct phases: perception, processing and action. Generally, the preceptors are sensors mounted on the robot , processing is done by the on-board microcontroller or processor, and the task is perfomed using motors or with some other actuators.
i want to make it clear, if you face any problem i am dere for you
, you can write comments or you can mail me at nitin_spd@yahoo.co.in
Step 1PROJECT OVERVIEW
PROJECT OVERVIEW
In this project the robot, is controlled by a mobile phone that makes call to the mobile phone attached to the robot in the course of the call, if any button is pressed control corresponding to the button pressed is heard at the other end of the call. This tone is called  dual tone multi frequency tome (DTMF) robot receives this DTMF tone with the help of phone stacked in the robot
The received tone is processed by the atmega16 microcontroller with the help of DTMF decoder MT8870 the decoder decodes the DTMF tone in to its equivalent binary digit and this binary number is send to the microcontroller, the microcontroller is preprogrammed to take a decision for any give input and outputs its decision to motor drivers in order to drive the motors for forward or backward motion or a turn.
The mobile that makes a call to the mobile phone stacked in the robot acts as a remote. So this simple robotic project does not require the construction ofreceiver and transmitter units.
DTMF signaling is used for telephone signaling over the line in the voice  frequency band to the call switching center. The version of DTMF used for telephone dialing is known as touch tone.
DTMF assigns a specific frequency (consisting of two separate tones) to each key s that it can easily be identified by the electronic circuit. The signal generated by the DTMF encoder is the direct al-gebric submission, in real time of the amplitudes of two sine(cosine) waves of different frequencies, i.e. ,pressing 5 will send a tone made by adding 1336hz and 770hz to the other end of the mobile. The tones and assignments in a dtmf system shown below
229 comments
1-40 of 229next »
Apr 23, 2012. 10:26 PMabhisheknagar says:
pls help... i have made this cicuit the problem i am facing is i am not getting o\p from dtmf decoder IC i m stuck in this thing from past 1month previously it was working absolutely fine..pls help any1
Mar 20, 2012. 6:09 AMishanduraphe says:
thankyou for the detailed description. i'm obliged. thanks again
Mar 19, 2012. 7:39 AMasif59 says:
...I am very interested to launch this project.....I work with PIC 18f452....can I build it using this ? Plz help me with ur advice....mail me : saurov1159@yahoo.com
Feb 24, 2012. 8:18 PMfinalpro21b says:
Can u provide .hex file for Atmega32A & program That can buid in Avrstudio4 our emai is finalpro21b@gmail.com
can u provide ur email?
Feb 22, 2012. 3:12 AMthejeswarareddy789 says:
sir can u send me a soft copy to this mail
thejeswarareddy789@gmail.com
Jan 19, 2012. 8:54 AMyadav366366 says:
if i will use microcontroller 8051, instead of using ATMEGA16.is there any problem in programme or circuit?
Dec 18, 2011. 10:24 AMhans lal says:
if i will use microcontroller 8051, instead of using ATMEGA16.is there any problem because i have made the circuit using 8051 microcontroller of land rover project.?
Dec 17, 2011. 11:35 PMmanikantak136 says:
sir,
iam interested in making mobile controled robot,so can u please send
me the steps and the things to use in making robo.please se ti to my
email (manikantak136@gmail.com)
thankyou.....!
Nov 23, 2011. 1:22 AMlongjasp says:
HEllo sir.., thnx for this idea.. Can i use microcontroller P16f84a or any 16f with the same dtmf decoder? then can i use pic basic language for the programming the microcontrller?
Need ur reply.. thnx
Nov 19, 2011. 8:44 AMspratap says:
Hello sir,
Could u provide the full circuit description this circuit so i can work on it.My email id is surved18sep@yahoo.co.in .
Nov 13, 2011. 9:06 PMejimenez6 says:
sir my decoder ic is CM8870PI .. .can you give me the proper circuit diagram for this ic? thx
Nov 6, 2011. 1:42 AMkyagendra says:
sir!
i have an IC of ATMEGA32
can i use your hex code of atmega16 to burn into atmega32????
shoud it work properly???
or would we have to change something in hex program
plz...... tell me sir???
Nov 4, 2011. 8:30 PMashishggct says:
thanks instructables...for this awesome project discription.
Oct 31, 2011. 4:57 AMdevendrabande says:
Hii sir,
can u give me All the document of this projects
my mail id is dvndra.b87@gmail.com
Oct 27, 2011. 7:44 PMmnadeem says:
can you please forward all the documentation available related to the project
Aflaatoon_Masti@hotmail.com
Oct 11, 2011. 10:34 AMSawan30 says:
please send all data to sawan.maheshwari30@gmail.com
Oct 10, 2011. 12:18 AMroboguy22 says:
i need yor help,sir
Sep 29, 2011. 8:10 AMcganguly says:
to chiranjeet.ganguly@hotmail.com .Thanks for ur help
Sep 28, 2011. 12:09 PMsrajput3 says:
please send me the review for this project and the all required things on my mail please...
my email id is sagarjdhv5@gmail.com
Sep 24, 2011. 7:06 AMcomspec2600 says:
Please send the documentation for this project to comspec2600@gmail.com or ryan.clark.ctr@nsoc.med.osd.mil. Thank you very much for taking the time to do so.
Sep 23, 2011. 11:44 AMsshah17 says:
sanketshah_11@yahoo.co.in
Sep 21, 2011. 10:34 PMvarshneydevesh says:
can u plz forward me complete project report ASAP on varshneydevesh8@gmail.com ... m trying to make a GSM controlled landrover using 8051 !
Sep 15, 2011. 6:53 AMnaveen420 says:
hii im intrested in project plz send me the complete details to my mail....navinczy@rediffmail.om
May 17, 2010. 6:42 AMswati.mmmec says:
plz anybody send me complete documentation of this project.....
May 31, 2010. 8:57 AMprashant3 says:
pls. send your email Id by mentioning instructable member. Then I will immediately send pdf file of same project to you in one minute. And also if you need of full constructed same project then also say me dont hesitate.
Thank you!
Prashant Gurav
prashantgurav@ibibo.com
09420644061
Sep 4, 2011. 9:44 AMabesrocks says:
plz send me complete documentation of this project................ cutegrl03@gmail.com
Jun 16, 2011. 1:21 AMmshahzeb says:
this is a very good project i really like it
Aug 23, 2011. 7:22 AMtintin2432 says:
sir can you plz mail me the ckt dia and code for avr in c language......
m new in microcntrolers... plz help me out sir...
verma.nitin1991@gmail.com
Aug 17, 2011. 6:11 AMgramesh says:
Hi guys.....
i so much interested in this project..... please can you send the total information about the project...
this is my email id: ramzuniverse@gmail.com
Aug 5, 2011. 9:59 PMpakhton tesla says:
it looking cool. can we control different servos from mobiles for RC PLANES
Feb 19, 2010. 8:35 AMamrit0003 says:
which file is to be burn on the at mega 16,     is it .HEX
Aug 4, 2011. 6:50 AMmshahzeb says:
yes
Feb 21, 2010. 11:55 AMshaadmahmud says:
anyone can tell me plllzzzz do i have to upload just HEX file into atmega16 ro anything else plzzz let me know....plzzzzz help me anyone...
only hex file
Feb 22, 2010. 11:16 PMankit11 says:
 ur using a controller and u dont know that u have to up load the hex coad.......!!!!!!!!!!!!!
its easy
Jun 24, 2010. 3:42 AMvishal.venkatesh says:
Hi this is a wonderful experiment which I am having an idea of displaying it in my science fair. But I am using ONIDA G490 mobile. I don"t find any option such as auto answer. Please help me to solve this problem
Aug 4, 2011. 6:34 AMmshahzeb says:
if you have not find the autoanswer mode you can accept the call manually.
Apr 19, 2011. 6:19 AMp.arungoud says:
can any one tell me what is the software that is used to compile the source code and develop .HEX file.
Aug 4, 2011. 6:26 AMmshahzeb says:
codevision avr c compiler
Jun 16, 2011. 1:23 AMmshahzeb says:
can i make programmer in home for atmega16
1-40 of 229next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:Nitin Sharma
i am a technology enthusiast. just trying hard to learn more and more abut technolgy
