3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cellphone operated Robot
Step 2Circuit Description
Circuit Description
Figures shows the block diagram and cicuit diagram of the microcontroller- based robot. The important components of this robot are DTMF decoder, Microcontroller and motor driver.
An MT8870 series dtmf decoder is used here. All types of the mt8870 series use digital counting techniques to detect and decodeall the sixteen DTMF tone pairs in to a four bit code output. The built -in dila tone regection circuit eliminated the need for pre- filtering. When the input signal given at pin2 (IN-) single ended input configuration is recognized to be effective, the correct four bit decode signal of the DTMF tone is transferred to Q1 (pin11) through Q4(pin14) outputs.
The atmega 16 is a low power, 8 bit, cmos microcontroller based on the AVR enhanced RISC architecture. It provides the following feature: 16kb of in  system programmable flash memory with read write capabilities, 512bytes of EEPROM, 1KB SRAM, 32 general purpose input/output lines. 32 general purpose working registers. All the 32 registers are directly connected to the arithmetic logic unit, allowing two independent registers to be accessed in one signal instruction executed in one clock cycle. The resulting architecture is more code efficient. Outputs from port pins PD0 through PD3 and PD7 of the microcontroller are fed to inputs IN1 through IN4 and enable pins (EN1 and EN2) of motor driver L293d respectively, to drive geared motors. Switch S1 is used for manual reset.
the notations are :
ic1 - mt8870
ic2 - atmega16
ic3 - l293d
ic4 - cd7004
r1,r2 - 100k resistances
r3 - 330k resistances
r4-r8 - 10k resistances
c1- 0.47 micro farat capacitor
c2,c3,c5,c6 - 22pfarat capacitor
c4 - 0.1micro farat capacitor
xtal1 - 3.57 mhz crytal
xtal2 - 12mhz crystal
s1 - push to on switch
m1,m2 - 6v 50rpm motor
batt- 6v
18 comments
Jun 24, 2010. 3:42 AMvishal.venkatesh says:
Hi this is a wonderful experiment which I am having an idea of displaying it in my science fair. But I am using ONIDA G490 mobile. I don"t find any option such as auto answer. Please help me to solve this problem
Aug 4, 2011. 6:34 AMmshahzeb says:
if you have not find the autoanswer mode you can accept the call manually.
May 8, 2011. 3:40 AMvaggarwal says:
How to connect the Not gate between Dtmf decoder(mt8870) and atmega16??[N1 to N4] I have used the 74LS04 NOT gate(couldnt arrange for cd7004). cant figure out which connections are to be made. You havent specified how you used the same in the circuit diiagram
plz reply soon
(or mail me at littlegenius95@gmail.com)
May 8, 2011. 11:40 AMvaggarwal says:
ohhh i got it ....
couldnt see the numbers written before on the not gates
Feb 6, 2010. 7:13 AMrahugogo says:
sir,can we add wireless camera in the robot and control by mobile
Sep 16, 2010. 3:39 AMzealotzshams says:
my question is same as RAHUGOGO ASKED. IF THIS IS POSSIBLE THEN HOW WE CONNECT CAMERA WITH MOBILE PLEASE REPLY ME AS EARLY AS POSSIBLE
this is my id
zealotzshams@hotmail.com
Feb 27, 2011. 5:53 AMskumar-1 says:
Its better to use a 3-G phone...
Feb 27, 2010. 3:36 AMashwanikaushik92 says:
 please give me the connections of relay with the microcontroller so that it can be operated by the cellphone
Feb 25, 2011. 9:17 PMdeepak.j.prakash says:
its a superb project. any way could u add a small wireless camera modle too .
so we can locate the position using a computer
Feb 21, 2011. 7:13 AMNishan_Bajwa says:
very nice project nitin........ i'm ECE 2nd year student plz help me for making good projects nd circuits... any body can send me mail for related to circuits my mail id bnishan3529@yahoo.com
Nov 28, 2010. 6:48 PMsrirajpillai says:
hey every1...can anybody pls tell me if we can use a CM8870 instead of a MT8870....pls, its urgent.
Sep 27, 2010. 4:34 AMyogesh99 says:
Its Farad not farat
Aug 7, 2010. 7:20 AMrajrockee says:
hi can you please mail me the report and the complete details about the project.. i wanna use it as the reference.... rajfile2009@gmail.com plz,,,,,,,,,,,
Jun 24, 2010. 3:47 AMvishal.venkatesh says:
Hi. This is a wonderful experiment which I think that I could display it in my science fair. But I am using ONIDA G490 mobile. I can"t find any option such as auto answer. So please help in solving this problem.
Apr 18, 2010. 5:01 PMprakash123 says:
 hi can you please mail me the report and the complete details about the project.. i wanna use  it as the reference.... praks5biradar@gmail.com
Feb 6, 2010. 6:11 AMdedo21 says:
hi i was wondering what is the function of D1
Feb 22, 2010. 11:25 PMankit11 says:
 controller needs 5V as a supply.............
the diode is a silicon diode so a drop of 0.7V will be their and the controller gets around 5.3V,which is sufficient for it.........
Feb 2, 2010. 11:22 PMitsdigital18 says:
Sir can u plz send documentation at itsdigital18@gmail.com
Jan 30, 2010. 6:49 AMitsdigital18 says:
Sir can u plz send me documentation n reports .
Dec 15, 2009. 12:04 AMnatin.joshi says:
hello dear.
i saw your project at instructables.com,
its amaizing project i like it.
can u send me this project's report or documentation of this project ?
Jan 4, 2010. 6:30 AMnikhildvijapur says:
did u get the total info about this pro....
please mail to vijapurnikhil@yahoo.co.in
Nov 11, 2009. 5:43 PMsyaiful_26 says:
good
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:Nitin Sharma
i am a technology enthusiast. just trying hard to learn more and more abut technolgy
