This cube was truly a work of frustration and love. The following is a VERY condensed description of how I got to the end result.
The whole project took about 80 hours hands on time, but over 2 months to complete because I had to put it down or I would have thrown the thing at a wall out of frustration.
The first thing I did was try to explain to friends and family what I planned to do. Which in a nut shell was to carve a block within a block of wood. I got a lot of "Yeah right"s, and "There is NO way!"s. But that only fueled the fire in me to prove 'em wrong..
I started with a solid block of wood.
Then carved four of the sides into the Triquetra. The two other ends were carved into the Tree of Life. All of the sides were carved to the thickness that I wanted all of the walls to be. Then the frustrating carving on the inside of the block began. I kept one side attached so I didn't have to chase the inside block around getting it to the size I wanted. When I was pretty close, I carved the last side of the inner block away from the last wall. Then I chased the inner block around carving it trying to make the inner cube even on all sides.
Then I put a natural finish on the inner cube and stained the outside.
The end result was a small inner cube inside a larger cube. It rattles around freely inside. (And they said it couldn't be done...)
Visit Our Store »
Go Pro Today »
Pfarmkid
I just learned the art form that this is similar to is "Netsuke" (Pronounced: Net ski) everything there is measured in mm's and cm's.
It originates in Japan and the pieces were carved to cinch cords on kimono's...
I personally don't think this comes even close. If you would like to see something really impressive and something I would love to aspire to in my carvings check out this website. http://www.cornelschneider.ch/
I was blown away and really humbled!
Again Thank you! - Tina
By the way, was that Gaelic for "Thank you"? I am interested in learning the language and am curious! P.S. I'm working on another Celtic themed piece I will post when I'm done!
The wood was Bass wood. And the tools were many.The bulk of the carving was done with a Foredom Micromotor handpiece which is like a Dremel but lighter and quieter. (I LOVE that thing!) I also used very small wood rasps and micro files.
Then a whole lot of sanding. I shopped around trying to find things that would work as I went and found a company that specializes in hobby model trains. They have a lot of specialized small/miniature tools. The Company is MicroMark. I recommend them highly.
I didn't really convey the size in the write up but the whole thing is approximately 2x2x2 inches square, so I had to use very small tools.
Thanks again for the kind words! I'm off to look at your 'ibles.
