Cen-Tech Infrared Thermometer Mount
2,519
6
Published
Introduction: Cen-Tech Infrared Thermometer Mount
About: Founder of Powerhouse Electronics. For more info goto: www.ph-elec.com
Got thermometer? Gotta have a mount.
This instructable shows how to mount a Cen-Tech Infrared Thermometer on a camera mount. Mounting the thermometer is very handy if you want to watch temperature change over time.
After I started playing with my new thermometer it became clear that a way to mount the unit was really needed. Holding the thermometer steady for any amount of time is a major pain the the @#$%&*().
Step 1: Prep for Nut Mounting
Every camera mount I have ever seen uses a 1/4" x 20 thread. Finding a 1/4 x 20 nut was easy enough. Finding a way to mount the nut on the thremometer is another mater.
I decided to mount the nut just inside the battery compartment. However, there is a plastic rib in the compartment that is in the way. I used a small chisel to remove just enough of the rib to make room for the nut.
Step 2: Gluing the Nut
Next came my attempt to epoxy the nut into the handle.
Turns out that epoxy does not stick to this kind of plastic very well. Not sure what kind of glue would work well. The plastic has a rubber feel to it so I suspect nothing is going to stick well.
Oh well, it's not that important to have the nut glued in solid. Once the thermometer is attached to the mount, the nut is not going anywhere. The glue only comes into play when the thermometer is off the camera mount.
Step 3: Screw Hole Comes Next
More carving to open up a hole on the bottom of the handle.
Step 4: Opening for Nut Clearance
Just a bit more carving to make clearance for the nut to slide by.
Be real careful not to cut into the slots that mate with the tabs on the battery cover.
Step 5: All Finished
Works Great.
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    2 Comments
    I want to use the thermometer to control the temperature of a hot plate for soldering purposes. Therefore, I need a probe that outputs temperature reading. Inside the Cen-Tech thermometer there is a four pin header. One of the pins is labeled "Tx". After a little probing, looks like the thermometer sends a packet of data at 3Hz. I'm working on decoding the packet now. I'll publish a follow-up inscrutable once I get it all sorted out. Thanks, Jim
    Nice - what are you using it for? L
