3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Centrally Controlled Digital Picture Frame
Step 10Software Build Part 3 (Custom Scripts)
This is the final piece for creating our CD...almost there!
Creating AutoRun9MySlideshow.cmd
You could call this file the "heart" of the slideshow program, on the disc anyway.
In a nutshell, it does this following:
  • Silently connect to local network
  • Confirm network connection successful
  • If successful, load slideshow batch file from remote share
  • If network can't be found, load slideshow with locally stored photos
  • Continually poll network share for remote reload, reboot, or shutdown commands (more on this later)
Creating the file
  • Browse to the existing directory called "..\plugin\autorun\"
  • Create a file named AutoRun9MySlideshow.cmd in this directory
    (We'll edit and add to this file in the next step after our nextwork share is in place)
  • Go back into PEBuilder->Plugins, and find "Startup Group"
  • Click Edit
  • Add the line: AutoRun9MySlideshow.cmd=2,,1 under [SourceDisksFiles]
    • This line of code tells it to include this file and copy it to the System32 directory
  • Click File->Save, and then exit your text editor
  • Click Done
Auto-Network Config
The next piece is adding a couple files so that our network connection is automatically setup upon boot-up without user interaction.
  • Browse to the existing directory called "..\plugin\penetcfg\"
  • Rename autorun0penetcfg.cmd to autorun8penetcfg.cmd
  • Edit autorun8penetcfg.cmd using a text editor
Change the source from:
@echo off
title Starting Network Support
call %SystemRoot%\system32\penetcfg.exe /UseProfile
rem call mstcp.cmd
exit
To:
@echo off
call %SystemRoot%\system32\penetcfg.exe /UseProfile:penetcfg-auto.ini
rem call mstcp.cmd
exit
  • Create a second file (also in ..\plugin\penetcfg\) called: PENETCFG-AUTO.INI
  • Edit the file using your text editor, and add the following source:
[General]
AutoStartNet=Yes
PromptForProfile=No
ShowGUI=No
[NetProfiles]
Dynamic IP Address (DHCP)= penetcfg-dhcp.ini
Static IP Address (Manual)= penetcfg-static.ini
Custom from A:\= a:\penetcfg.ini
Custom from C:\= c:\penetcfg.ini
[NetAdapter1]
EnableDHCP=Yes
UseStaticGateway=No
DefaultGateway=
UseStaticDNS=No
DNSServer=
UseStaticWINS=No
WINSServer=
[NetID]
Workgroup=WORKGROUP
ComputerName=PICFRAME
[FileSharing]
Note that you will have to edit the above section to suite your network if you're not connecting to an open WiFi network (or physical cable connection).  I opted to show a simple config, but if you're connecting to a secure network you'll have to add more parameters (search Google for PENETCFG-AUTO.INI).
  • Finally, go back into PEBuilder
  • Click Plugins
  • Select "PENETCFG: Automatically start PE Network configurator" and click Edit
  • Edit the [SourceDisksFiles] section so it includes just these two lines:
autorun8penetcfg.cmd=2,,1
PENETCFG-AUTO.INI=2,,1
  • Click Done and Exit PE Builder for now (or conduct another quick Build Test before exiting)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:siliconghost
Jack of all trades. I love combining software, electrical, and mechanical engineering to come up with unique and fun projects. Follow me on http://manganlabs.com and http://twitter.com/@siliconghost...
more »
