Step 9Software Build Part 2 (Plugins)
Firefox
- Start PE Builder
- Select "Plugins" button
- Click "Add", and browse to your Firefox cab that was downloaded (firefox-1.5.0.1-en-US.cab as of this writing)
- Rename the suggested name to simply "firefox" and click OK
- You should now see Firefox enabled and listed in the menu of plugins (shown in image below)
PsTools
- While still in the "Plugins" screen, click "Add" again.
- Browse to your pstools.cab file that was downloaded.
- Leave the name of the folder called "pstools" and click OK
- You should now see PsTools enabled and listed in the menu of plugins
- Open a separate window in Explorer and extract the contents of the PsTools.zip file you downloaded earlier.
- Copy the following files into the root of your PsTools plugin directory (..\plugin\pstools\):
pdh.dll, psexec.exe, psfile.exe, psgetsid.exe, psinfo.exe, pskill.exe, pslist.exe, psloggedon.exe, psloglist.exe, pspasswd.exe, psservice.exe, psshutdown.exe, pssuspend.exe, pstools.chm
- Install the IrfanView program you downloaded (on to your PC). We will extract the stand alone executable files after installation.
- Go with the defaults except for the Google Toolbar checkbox, which you want to deselect
- Deselect the checkbox to Run IrfanView when install is complete and click Done
- Using explorer, browse to C:\Program Files\IrfanView\
- Copy i_view32.exe to ..\plugin\irfanview\files\
- Copy the attached file (i_view32.ini) to the ..\plugin\irfanview\files\ directory
- Create an empty text file called "pictureshow.txt", also within the ..\plugin\irfanview\files\ directory.
- Copy a dozen or so generic "backup" pictures to the ..\plugin\irfanview\files\ directory. These will be used for the slideshow if the frame has difficulty finding your network.
- Within PEBuilder, highlight IrfanView and click "Edit"
- Delete the line under [SourceDiskFiles] that says: files\i_view32.hlp=a,,1
- Add a line in the same location (under [SourceDiskFiles]) that says: files\i_view32.ini=a,,1
- For each photo you added, add another line using the same format: files\picturename.jpg=a,,1
- Finally, add one last line that says: files\pictureshow.txt=a,,1
- See photo below for an example of what your .inf file should now look like.
- Click File->Save, and then close the editor
- While still in the "Plugins" screen, select "IrfanView" and click the "Enable/Disable" button.
- Edit pictureshow.txt, and list the filename for every photo you just copied over (see example photo below)
- Each filename should be followed by a carriage return (Enter)
We've made quite a few changes. It's probably a good idea to click "build" now within PE Builder to test the three plug-ins you have added.
i_view32.ini2 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
