Introduction: Ceramic Capacitor Name Sign- Aka How to Waste 55,000 Ceramic Capacitors!
Picture of Ceramic Capacitor Name Sign-  Aka How to Waste 55,000 Ceramic Capacitors!
You probably just came to this Instructable wondering "What exactly is this? 55,000 capacitors? That's a lot!"
So here, I will be showing you how to make an awesome picture frame sign of your name, Using a, Well, Pretty big amount of ceramic capacitors
Fist of all, What are ceramic capacitors?
Ceramic capacitors a tiny SMD electronic components, The ones I am using are about the size of a grain of sand! If you don't have access to these ceramic capacitors, You can use any other electronic component, Such as: SMD or regular resistors, Diodes, LED's, Transistors/ IC's, And may more (This is a hint that if you don't get these for free, Buy cheaper components)
This might also be a nice project for a factory that make ceramic capacitors, 55,000 would probably count as a small "leftover amount". ***faint***
Step 1: What You'll Need:
Picture of What You'll Need:
Materials:
Blue Tape (Painters Tape)
Clear "School Glue"
Picture Frame
White Poster Board Paper (My picture frame came with it, But if yours didn't, You'll have to buy it separately)
And most important: Ceramic Capacitors (These, for example)
Note: I used different sized capacitors, It looks a lot better this way
Note #2: I had 55,000 capacitors but I ended up using a little less than that, Probably a bit more than 50,000. The amount you'll need depends on the size of the capacitors and the size of the picture frame
Tools:
Scissors
Tweezers
Small Plastic Cup/Container
A Nail and a Hammer if you want to hang this on a wall (like me)
Fingers that love having glue smeared all over them!
If you're wondering Why is there a block of wood in the picture?
When I started making this (and filming the 'Ible), I didn't think of making it this way.
I thought of just smearing some glue on wood and then spreading some capacitors on the glue (I thought that would be nice), And after that I thought of putting on poster board paper it in a picture frame, Right before starting to spread the gle, I thought of making it display my name. That is what you're seeing now!
Step 2: From Human, to Automatic Capacitor Dispenser
Picture of From Human, to Automatic Capacitor Dispenser
In this step, You might have been able to say that I turned in to a ceramic capacitor dispenser
Do you know how much time it takes to unravel 55,000 capacitors from strips of seven spools/reels? Long enough, It took me over an hour, And you can see how a cardboard box trash can* looks when I finished (It filled about half of it)
*I don't think I'm the only DIY'er that needs such a big trash can!
Step 3: Arrange & Stick the Tape (According to Your Name)
Picture of Arrange & Stick the Tape (According to Your Name)
This step requires quite a bit of time to do:
1. Use CAPITAL LETTERS. "YONATAN" will look better than "Yonatan" in the picture. This is because round letters are hard to do and won't look as good
2. If you're like me, And your blue tape is too wide, Do this. The narrower the strips are, The better it looks
3. Don't expect it to be perfect on the first try, You'll have to "play" with it a lot until you have it the way you want
4. If you have a long name (like me), Try to keep the letters as big as you can and "compress" them together (Look how much the ATA part in my name saves, The T doesn't take up any space)
5. Letters need to be spaced out by at least 0.5 cm (~0.2 inches) from each other and the edge
Step 4: Apply & Spread Glue on Your Poster Board Paper
Picture of Apply & Spread Glue on Your Poster Board Paper
Fill the WHOLE paper with glue, Use your finger to spread out the glue and make sure there aren't any places that don't have glue.
You want to spread the capacitors evenly (As shown in Picture #1) with your finger (A different one...). You can fix empty places by adding tiny specks of glue in places that you missed.
Step 5: Peel Off the Tape W/ Tweezers
Picture of Peel Off the Tape W/ Tweezers
After letting the glue dry, I peeled of the tape. I found out that the easiest ways to do this is with tweezers.
Do this slowly and carefully, I recommend starting with the easier letters such as T or Y
Now you can throw all of the leftover tape away, You won't be needing it anymore
Step 6: DONE!
Picture of DONE!
You are now done! Insert it in to the picture frame carefully (again) so the glass won't remove any capacitors that aren't held strong enough (there is probably no reason for this to happen anyway)
You can now hang it on a wall, Or put it or your desk if it has a stand, And admire you precious artwork!
ThomasK19 (author)2015-12-20
Why is it that I think this is like burning money? Since you took those the size of a sand grain you were probably better off using colored sand instead :-o
My distributor charges 0.04€ per piece. That's more than 2000€.
nqtronix (author)ThomasK192016-01-15
Just for your interest, you can get parts VERY cheap from china. The cheapest wheel of 10000 0402 ceramic capacitors costs about 8.40€ right now. 40€ total is still A LOT money for 'just' some art but it's ok if you absolutly want to.
Yonatan24 (author)nqtronix2016-10-08
9 Months later...
I've made myself another plaque. This time, for 1000 followers on Instructables!
I like it way more than this one, especially because... Well... That should be obvious ;)
You can see it here: https://www.instructables.com/id/DIY-Wood-Electroni...
nqtronix (author)Yonatan242016-10-08
Guess what, I've seen it already, it's pretty cool :D
ThomasK19 (author)nqtronix2016-01-15
Wow. Means my distributor earns a lot when selling them xD
Yonatan24 (author)ThomasK192016-01-16
The ones from chine might have a lower accuracy = cheaper
But it probably doesn't matter for most projects
nqtronix (author)Yonatan242016-01-16
I can assure you, they are perfectly suited for this project ;)
Yonatan24 (author)Yonatan242016-01-16
*China
Yonatan24 (author)ThomasK192015-12-21
I have a relative that works in electronics company, He gave me these old capacitors that they had no need for them (I guess they might have upgraded to a higher quality ones, I don't know why)
I agree with you that it would have been burning money, But I got them for free :)
When I compared them to sand, I thought of plain sand, But colored sand could look really cool!
ThomasK19 (author)Yonatan242015-12-21
Especially if you create a mandala on top :-)
Next time you sell the capacitors on eBay and buy some sand instead ;-)
Hmmm,
GENIUS!
I believe the shipping would cost too much from where I live, I don't feel really comfortable with selling something that I got, I don't know
ilovekoalas (author)2015-12-20
Nice, but where did you get 55,000 capacities?
Yonatan24 (author)ilovekoalas2015-12-21
Look at my reply to ThomasK19
About This Instructable
1,703views
9favorites
License:
Bio: 15 year old, sick with a deadly disease called DIY-itis!
More by Yonatan24:60+ Unusual Uses for Workshop Tools & Materials! the Ultimate Collection!Workshop Tips, Tricks, & Hacks to Save You Time & Money!My Top Instructables of 2017 - Yonatan24
Add instructable to:
