Ceramic Spoon Rest & Utensil Holder
Published
Introduction: Ceramic Spoon Rest & Utensil Holder
About: I am an artist living and teaching ART in NYC for over 30 years, and I am a CZT, Certified Zentangle Teacher. I love to explore all sorts of art making both in my teaching and in my own work...check out my s...
This past year my daughter moved and I thought it would be fun to make her something for her new kitchen....so I made her a spoon rest and utensil holder using clay and leaves.
Step 1: Supplies
clay, I used red grog cone 06
clay cutter
rolling pin
leaves
slip
glazes
9Z
X15 cardboard template
leaves etching tool
glaze brush
Kiln
Step 2: Spoon Rest
choose leaf to use for spoon rest and roll clay large enough to fit shape.
Step 3:
press the leaf into the clay, run your fingernail gently along the veins of the leaf to indent them into the clay
Step 4:
using the etching pin cut away the excess clay from around the leaf.
Step 5:
Step 6:
Carefully remove the leaf
 from the clay
Step 7:
Step 8:
place the clay leaf shape on a drying board, roll small
pieces of clay and put them under the edges of the leaf to give it the shape of a fallen leaf.
Step 9:
Step 10:
when the clay is leathery or has begun to harden I smoothed the edges with a small sponge
Step 11: Utensil Holder
Roll large enough piece od clay to cut the 9X15 shape.
Step 12:
Step 13:
For clay into a cylinder shape, set aside
Step 14:
roll a large enough piece of clay to place the cylinder on to cut base.
Step 15:
use tool to cut clay for base, give about 1/2 inch around bottom.
Step 16:
reach inside cylinder and with finger tips apply pressure from the inside of the holder, then using a finger push the clay up on the outside edge to secure the base of the utensil holder.
Step 17:
roll more clay and begin to press more smaller leaf shapes into the clay, again use fingernail to apply pressure to get veins indented into clay.
Step 18:
Step 19:
cut the shapes from the clay, remove the leaf, if it rips or gets stuck it is okay it will burn off in the kiln
Step 20:
Using slip, (liquid form
of clay, it acts like glue on the wet clay.) smear the leaf shapes and attach to the cylinder
Step 21:
Step 22:
This is a fig leaf from my daughter's Great grandfathers' fig tree!
Step 23:
the leaves can overlap
Step 24:
I use a bit of water on my finger to smooth the rough edges of the leaf shapes.
Step 25:
If slip squishes out a paintbrush
 can be used to clean up the wet clay.
Step 26:
Step 27:
Step 28: Glaze
When pieces are thoroughly dry , fire to a bisque ware in the kiln, I used an o6 cone.
Step 29:
I used clear glaze
for the inside of the utensil holder. I poured it in and out. I like the clear glaze on the red
clay, it looks very earthy.
Step 30:
I chose an overglaze called speckled brown for the outside of the Utensil Holder
Step 31:
and the spoon rest
Step 32: Final Firing
The pieces are fired again in the kiln and ready to wrap for the holiday gift giving.
Step 33:
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    I have a very sick obsession with leaves. This is fantastic and I love the glaze you used it really looks awesome with the clay body you chose! As always fantastically done!
