Introduction: Chain Mail Trilobite Paracord Bracelet
Hey everyone, today I present to you... The Chain Mail Trilobite Paracord bracelet.
Step 1: Gather Materials
The things you'll need are:
-Paracord
-Stainless steel open jump rings (10mm diameter)
-Snap shackle
You can get the jump rings here: https://www.amazon.com/HOUSWEETY-50PCs-Stainless-Steel-Findings/dp/B015R10C9U/ref=sr_1_1?ie=UTF8&qid=1471229765&sr=8-1&keywords=HOUSWEETY+50PCs+Stainless+Steel+Open+Jump+Rings+10mm+Dia.+Findings
You can get the snap shackle here: https://www.amazon.com/Bracelet-Sailboat-Stainless-Five-Oceans/dp/B00EFEXN4M
Step 2: Making the Setup
Step 1: Cut two pieces of cord, each about 10 feet long
Step 2: Find the middle and make a loop with one of them, then twist the loop
Step 3: Find the middle and make a loop with the other cord
Step 4: Thread the loop into the twisted loop
Step 5: Bring the loop you just pulled down
Step 6: Thread the other side of the cord into the loop, creating a cow hitch
Step 7: Now you'll need the metal jump rings
Step 8: Thread the middle cords through 20-25 rings, you can always add more when your working, and if you have to many you can take them off when you end the bracelet
Step 3: Making the Bracelet
To anyone who read my instructable on the Paracord snake, this should feel familiar because it is the same style of knots.
Step 1: Take the right cord and place it over the middle cords, but under the left cord
Step 2: Bring the left cord under the middle cords and upwards through the loop created by the right cord
Step 3: Slide a jump ring down
Step 4: Make a loop with the right cord around the rightmost middle cord
Step 5: Bring the left cord over-under-over to the right side
Step 6: Bring the right cord over under to the left side
Step 7: Repeat steps 1 through 6 until you reach the end of your cordage
Step 4: Jump Rings
So, I ran out of jump rings because I did not put on enough initially. I will show you how to put them on a different way.
Step 1: Take a jump ring and two pairs of pliers
Step 2: Grab the jump ring with both pliers and give it a little twist
Step 3: Push the ring onto the middle cords from the side
Step 4: Close the ring by using the pliers
Step 5: Ending the Bracelet
Step 1: Take your needle nosed pliers and pull the excess cord through four rows on the side of the bracelet
Step 2: Do the same thing with the other cord
Step 3: Cut off the excess and melt the ends
Step 4: Do the same thing with the other cord
Step 6: Snap Shackle
So you're done and probably thinking "Wait, what about the shackle," so I saved this part for last because it will be easier if we already have the bracelet made.
Step 1: Thread the shackle onto to the two strands
Step 2: Take your needle nosed pliers and pull the cord through four rows on the side of the bracelet
Step 3: Do the same thing on the opposite side of the bracelet
Step 4: Cut and melt both ends
Step 7: Finished!
Congratulations! You've made the Chain Mail Trilobite Paracord bracelet. I hope you enjoyed my instructable and I hope that you will vote for me in the Outside contest!
Thank you for the positive feedback on my other instructables!
Metal Contest 2016
Maker Olympics Contest 2016
Outside Contest 2016
