Chain Maille used to be worn by soldiers in the middle ages. It was used as protection from swords and arrows, and kept objects from entering the body. Although it stopped most weapons from cutting and stabbing, it did not how ever keep the force from effecting the body, and breaking bones, or giving nasty bruises. I tell you this because I want you to know that this chain maille is not strong enough to stop bullets. It might stop a knife, but if you decide to test it, I will not be held responsible for any injuries, deaths or anger because you ruined your project. :P Chain maille is a very time consuming thing to make, so if you do not have alot of patience or a large attention span, this might not be the project for you.
Chain maille has a few different spellings, such as Chainmail, chain mail, chain-mail, chain-maille, chainmaille, and chain maille.
Remove these ads by
Signing UpStep 1Tools and Materials
Two pairs of needle nose pliers,
one pair of wire cutters,
a thick needle,
scissors
wire strippers
a metal rod of some sort.
Materials:
Thick fabric, I used some military canvas I had laying around.
coat thread. You can also use normal thread, but you will have to use more stitches to keep the chain maille on.
masking tape
wire of some sort.
A T-shirt
The metal rod is is what you will be using to make the chain links. Bigger links are easier to work with, but are pulled apart easier. Smaller links are harder to work with, but also stronger. I got the rod from an old printer I had laying around.
I stripped the insulation off some electrical wire, and used the copper wire inside. You can buy steel wire from a hardware store.
12
comments
Add Comment
Add Comment
