Chain Oiler V2 (2.0 Version)
3,241
10
7
Posted in OutsideBikes
Introduction: Chain Oiler V2 (2.0 Version)
About: i like to build stuff, mostly mechanical and some electronical. I study Aerospace engineer and i'm an electronical technician. I love to work with lathe and mill, and tool-machines in general. My native lang...
This is my second chain oiler, the 2.0 version. Chain oilers are used to lubricate mechanical pieces automatically, so I made one for my own bike. It has several advantages.
• Longer life of the chain.
• Constant lubrication, ideal for rain days.
• And the possibility of use a lighter oil, like SAE 5 or 10, ideal for dusty roads.
Step 1: Materials
You will need:
• Aluminum tube, of 22mm (7/8”) dia. 15cm (6”) long.
• A “Polper B12” vitamin flask.
• One silicon tube, like those used by doctors for serum.
• A cork.
• A needle 48/18, it’s the biggest I found, has 1mm dia.
• Seals
• A piece of rubber or Styrofoam.
Step 2: Cutting the Caps
Cut the polper flask in half, precision isn’t needed.
Step 3: Finishing the Oil Tank
Remove the threaded of the polper’s cap
and then add teflon tape in the ends of the aluminum tube
Step 4: Cork Seal
Cut a piece of cork as shown in the image.
Step 5: Prepairing the Tank
Make a 5mm hole in the cork and the polper’s cap and introduce the cork into the aluminum tube.
Step 6: Prepairing the Serum Tube
Carefully insert the needle in the extreme of the silicon tube, and introduce the other extreme in the aluminum tube with the polper’s cap.
Step 7: Test It
well, the pictures coming soon,
but you have to put the needle over the chain, and let it drip on the chain.
another day I'm gonna upload the photos explaining how to put on a bike with 18 speeds
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    7 Comments
    Pretty kool idea. I'll be really interested in seeing how you have managed the feed indexing with changing cogs. IMO, you should iron out many things and apply for a patent; there is some money to be made from this.
    I think i wanna do something like this on the old gs
    What about the valve? I only see it in the picture How much is the oil consumption anyway?
    well, the valve will not use this version because I do not keep the bike for a long time. valve is a hose to draw blood, and strangle the hose to cut off the supply. respect oil consumption depends on the viscosity, I use 5 and SAE use two tanks per month. The tank has 60 cm ³ Im sorry if you dont understand me, is because i dont speak english very well, i have to use what i now of english and the google translate.
    Nice.going to make one for my self in vacations.
    What a neat idea, looks great. Good thinking and thanks for sharing.
