Chainmail(le) Primer: Making Jewelry-Size Rings for Weaving Chainmail
With very few tools, you can begin weaving jewelry-sized chainmail.
If you're a beader, or do wirework, then you probably have most of these items already.
Items needed:
- Wire: 20 to 24 gauge wire (preferably half-hard if you intend on wearing the items you make, but full-soft is okay if you're just teaching yourself some weaves
- Mandrel: 1/2" to 1/16" (I recommend 3/16"), preferably metal, but in a pinch, you can get away with wood. (Please see step 4 for some additional information on aspect ratios and selecting a mandrel.)
- Nail clippers, unless you have specialty wire cutters ( ~Stained-Glass~ says that Fiskars Micro Tip Pruning Shears work well for wire thicknesses up to 18 gauge.)
- Vise-grip (you don't have to use lockable pliers, but they make life much easier)
Note: If you have a power drill, you could use that to power your winding. I generally don't power-wind wire unless I have a hole drilled (or notch cut into one end) through my mandrel to secure the wire, and for most of my small diameter mandrels, I don't have such a hole.
Power-winding will be discussed in an upcoming instructable on making armor-sized rings.
A clever wire winding jig was constructed by mum, and is explained on step 6. Go on and take a look at the alternative method for coiling.
To actually weave your rings into chainmail, you'll need Pliers: two pairs to start with. Teeth will mark the rings*, but that's okay if you're just practicing weaves. However, weaving is not within the purview of this instructable. Please see instructables on European 4-in-1, and Byzantine chain for weaves.
  • Not entirely true, but if you're good enough at weaving chainmail that you can avoid marking the rings with toothed pliers, then you probably don't need this instructable, eh?
Step 1Starting your coil
Starting your coil
You may wish to file/cut a small notch near one end of the mandrel--it helps hold the wire. I just filed a perpendicular line half an inch from one end of my mandrel.
Cut approximately 1 yard of wire (begin with 3', you can increase the length later)
Find one end of your wire, and line it up perpendicularly with the mandrel.
Clamp wire down with Vise-Grip, also perpendicular to the mandrel.
Note that the clamped down portion of the wire will be wasted. Adjust this length according to frugal you need to be with your wire.
42 comments
1-40 of 42next »
Aug 2, 2007. 9:18 PMKayjay says:
i was just wondering does anyone know if rings and things is a well knowen store in other places, i know we have one here but i was wondering where sone of the other ones are, plus our store isnt very big
Aug 3, 2007. 11:35 AMKayjay says:
well i know the one here sells... well rings and things but they have beeds and all that stuff too
Nov 27, 2011. 5:53 PMsokamiwohali says:
you know that The Ring Lord is in canada right?...they make some really good rings for the price. their selection is great, and your not limited my just rings. they sell wire too!!
their site is
www.theringlord.com
Aug 3, 2007. 9:00 PMKayjay says:
no here is swift current, saskatchewan (canada) 4 me
Aug 3, 2007. 9:20 PMKayjay says:
good point sadly i've never been to the U.S.A before
Mar 20, 2009. 4:59 PMSpeedmite says:
USA is pretty nice. Ive been to Toronto. Canada is nice to. THE FALLS ARE BEAST!!!! And you guys have the better view.
Aug 17, 2007. 11:10 AMel.numbre says:
try the ring lord for all chain maille related things :) their prices are very reasonable for wire, rings, accesories, premade everything really :p the only thing is postage for me as live in the UK but they're situated in canada so the p+p should be reasonable for you :)
I've used rings 'n' things online, I'm not sure if its the same store though?
Aug 9, 2011. 3:55 PMLuziviech says:
Dude, there's an easy way to make clean and fast rings from using a drill and mandrels - just use a tool like this (got it from a friend, dunno if the idea of it existed even earlier): http://i762.photobucket.com/albums/xx267/Luziviech/CIMG6633.jpg - It's just a piece of solid metal with a screw/cylinder in the middle, the difference between the screw and the several holes is the same as the wire's diameter i use. To use the tool i make sum rounds from my wire and put the tool over the mandrel using the certain fitting hole and can run the drill at full speed, if i want: the screw fastens the wire to the mandrel and forces it into rings...
Jun 29, 2009. 5:44 PMjoen says:
Great tutorial. I liked it but when I tried to go to "Derakon's Library", in step 5 the link didn't work. When I Googled the name it sent me to "http://theringlord.org/derakoninstructions/index.html". Is this the right place?
Nov 30, 2007. 12:32 PMbqbowden says:
(removed by author or community request)
Mar 20, 2009. 5:15 PMSpeedmite says:
http://cgmaille.com/tutorials.shtml
Go here. Great tutorials on a lot. Ive only tried a few thing but its the best place Ive been. I really only seriously made 4-1 mail, but they have some cool stuff.
I recommend 20-24 gauge. If you want like a chain, smaller gauge. If you want micro, larger gauge. I wouldnt recommend micro if you are just starting. It can be irritating at first figuring out stuff, but its fun.
Also, I would recommend making the rings yourself. Its fun,cheaper,and easy. I used a long screwdriver as a mandrel, locking pliers to hold the wire, and wire cutters to cut it. And a vice to hold the screwdriver. And some random wire from somthing in the garage...
Yes, I MANUALLY TURN THE WIRE MYSELF!!! AND IM PROUD OF IT!!!
Dec 3, 2007. 1:03 PMJ_SCAP says:
ok if i where you i would just make it a 4 in 1 knight mail
Mar 20, 2009. 5:17 PMSpeedmite says:
Homonym usage! Its "were" not "where". and its European mail, not knight mail. All mail can be considered "knight mail". There are many more different types of mail than 4-1
Aug 2, 2007. 4:17 PM~StainedGlass~ says:
For cutting 18+ gauges of copper, aluminum and silver, try out a pair of $14.95 Fiskars MicroShears... they work great and give incredible cuts!!
Mar 20, 2009. 4:57 PMSpeedmite says:
I think he means 18 gauge and thicker. Thats how I see It.
Aug 3, 2007. 12:32 AM~StainedGlass~ says:
I meant 18 gauge and thinner, so, 20 gauge, 22 gauge, 24 gauge, etc. I have also used them to cut some 16 gauge, but the cuts aren't as smooth and shear then.
Here's a pic of them, they're sold in hardware store to trim and prune shrubs:
http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/c8e08f63-76fe-44f4-a5ac-c7a76c2da0ad_4.jpg
Their actual name is Fiskars Micro Tip Pruning Shears
Oct 12, 2008. 6:42 PMDusky says:
Great links; I have been pleased buying from The Ring Lord. Their selection is a blessing and a curse...way too many shiny things to spend money on. .
I've been learning weaves with pre-made rings for several months now, and finally wanted to start winding my own rings; thanks for the tutorial!
cheers, dusky
Mar 10, 2008. 7:07 PMBARBARIANROCKER says:
My wife loves making this stuff. Great work.
Dec 9, 2007. 9:02 AMJ_SCAP says:
my toe nail clipper go splode from this but i used wire cutters and it was ok
Nov 12, 2007. 11:44 AMpsykosteel says:
Nice job, try using your mandrel in a cordless drill if available. They are cheap enough and a lot of them come in two speeds, set it to slow. Mount one end of the wire in a bench vice and the other end in the mandrel and drill. Pull back from the vice to add tension then squeeze the drill trigger slowly as you walk toward the vice. A few times and you will get the hang of it with minimal waste. You will also notice much tighter and consistent ring sizes. Happy winding.
Sep 11, 2007. 12:04 PMandy60 says:
i usually attatch one end of the madrel to a drill at a low speed and this has proved a lot quicker in most cases
Sep 12, 2007. 8:44 AMandy60 says:
sos bout that, busy life at the moment :( and yer i'd love to add some pics soon as i get my camera... (hopefully shouldn't be long) lol
Aug 2, 2007. 4:15 PMbeckinacea says:
Holy in-depth instructable, Batman! I've been meaning to get a whole load of new links lately, but a friend of mine made them and I wasn't sure how. Thanks for sharing. :)
Aug 1, 2007. 1:35 AMSkip says:
ryzellon, I seem to be pouncing on your instructables alot :P Noticed some people talking about the AR. The AR is is useful when determining the rings you want for the weave you're going to do. The AR is worked out by Dividing the ID (inner diameter) of the ring (or the mandrel size) by the thickness of the wire. For example 20g wire (0.8mm) on a 5mm mandrel will give you an AR of 5.8. Some weaves will only work within a certain AR range. Uhm, another way of getting a relatively flush cut using your nailclippers would be to use the score and break method. The score and break method is when you cut only a small way into the metal (score) then bending the ring up untill it breaks. Softer metals will require a deeper score than harder metals.
Jul 28, 2007. 7:43 PMatelier-sol says:
I find I get better (flush) cuts with a jeweler's saw and a wooden mandrel so I can use one end to guide the saw. What type of cutter do you use? Do you get perfectly flush cuts? If so, please share the brand and model of the cutter. Thanks.
Jul 30, 2007. 6:42 PMatelier-sol says:
I'd love to collaborate, and I think it makes sense to have the one instructable with two cutting methods. I'll take some photos and upload them or send them to you. Oh, and I don't know how I missed that you were using nail clippers -- it's right there at the top! I'll have to get a straight pair and try it. It's great when a cheap little tool ends up working best!
Jul 29, 2007. 11:13 PMFrenchCrawler says:
Here's a chainmaille group link:
http://mailleartisans.org/gallery/subcat.cgi?mode=cat&key=8
And here's another showing a cutting tool/design using a dremel and gravity:
http://mailleartisans.org/gallery/pics/15597ringcutt2.jpg
Jul 28, 2007. 6:51 PMjtobako says:
Could you add something about aspect ratio when choosing a mandrel for a particular wire? Thanks : )
Jul 28, 2007. 11:24 PMxenobiologista says:
One question - could you describe what kind of wire would be "half-hard"? I guess "full soft" would be metals like copper or silver, but how hard is half hard? Nice Instructable, by the way.
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:ryzellon
