If you're a beader, or do wirework, then you probably have most of these items already.
Items needed:
- Wire: 20 to 24 gauge wire (preferably half-hard if you intend on wearing the items you make, but full-soft is okay if you're just teaching yourself some weaves
- Mandrel: 1/2" to 1/16" (I recommend 3/16"), preferably metal, but in a pinch, you can get away with wood. (Please see step 4 for some additional information on aspect ratios and selecting a mandrel.)
- Nail clippers, unless you have specialty wire cutters ( ~Stained-Glass~ says that Fiskars Micro Tip Pruning Shears work well for wire thicknesses up to 18 gauge.)
- Vise-grip (you don't have to use lockable pliers, but they make life much easier)
Note: If you have a power drill, you could use that to power your winding. I generally don't power-wind wire unless I have a hole drilled (or notch cut into one end) through my mandrel to secure the wire, and for most of my small diameter mandrels, I don't have such a hole.
Power-winding will be discussed in an upcoming instructable on making armor-sized rings.
A clever wire winding jig was constructed by mum, and is explained on step 6. Go on and take a look at the alternative method for coiling.
To actually weave your rings into chainmail, you'll need Pliers: two pairs to start with. Teeth will mark the rings*, but that's okay if you're just practicing weaves. However, weaving is not within the purview of this instructable. Please see instructables on European 4-in-1, and Byzantine chain for weaves.
- Not entirely true, but if you're good enough at weaving chainmail that you can avoid marking the rings with toothed pliers, then you probably don't need this instructable, eh?
Remove these ads by
Signing UpStep 1Starting your coil
Cut approximately 1 yard of wire (begin with 3', you can increase the length later)
Find one end of your wire, and line it up perpendicularly with the mandrel.
Clamp wire down with Vise-Grip, also perpendicular to the mandrel.
Note that the clamped down portion of the wire will be wasted. Adjust this length according to frugal you need to be with your wire.
(I've only ever ordered online.)
& I know none of my friends've heard of it before, but they're not beaders/jewelers, so that's not all that informative.
Hopefully someone else will have a better answer for you.
their site is
www.theringlord.com
I've used rings 'n' things online, I'm not sure if its the same store though?
Go here. Great tutorials on a lot. Ive only tried a few thing but its the best place Ive been. I really only seriously made 4-1 mail, but they have some cool stuff.
I recommend 20-24 gauge. If you want like a chain, smaller gauge. If you want micro, larger gauge. I wouldnt recommend micro if you are just starting. It can be irritating at first figuring out stuff, but its fun.
Also, I would recommend making the rings yourself. Its fun,cheaper,and easy. I used a long screwdriver as a mandrel, locking pliers to hold the wire, and wire cutters to cut it. And a vice to hold the screwdriver. And some random wire from somthing in the garage...
Yes, I MANUALLY TURN THE WIRE MYSELF!!! AND IM PROUD OF IT!!!
Is the "+" for wire diameter or gauge #? (i.e. for 18 gauges and thicker, or for 18-24 gauge)?
Could you provide a model #, photo, link to product or some other specific identifying info on these shears? I'm not finding any Micro Shears, but I'm seeing at least two Fiskars items that have Micro in their item name.
(I personally have a Xuron micro flush-cutter (9200) and a hefty pair of Wiss aviation snips (M6RS), and have to divide my wires between those.)
Here's a pic of them, they're sold in hardware store to trim and prune shrubs:
http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/c8e08f63-76fe-44f4-a5ac-c7a76c2da0ad_4.jpg
Their actual name is Fiskars Micro Tip Pruning Shears
I've been learning weaves with pre-made rings for several months now, and finally wanted to start winding my own rings; thanks for the tutorial!
cheers, dusky
An addendum to ring-cutting-methods is forthcoming, and I'll be sure to mention score&break.
http://mailleartisans.org/gallery/subcat.cgi?mode=cat&key=8
And here's another showing a cutting tool/design using a dremel and gravity:
http://mailleartisans.org/gallery/pics/15597ringcutt2.jpg
