Step 6Alternative Coiling Method: Wire-winding Jig
mum says: "I went to a jewelry class and didn't want to spend a fortune on a wire-winding jig that I might only use once, so I made my own."
Items for jig & mandrel:
2 L-shaped shelf supports (about 3inches in this jig, possibly with a bit sawed off the length)
G-Clamp (known as a C-Clamp on the States' side of the pond)
Knitting needle as your mandrel
Assembly:
Clamp the L-supports to the table to form a U shape (if you set them very close, you'll need to have sawn at least one L-support short)*
Bend knitting needle so you can get a bit of leverage to coil your wire (see photo)
Insert needle through L-supports
Wrap a bit of wire on the mandrel (probably at your lever)
Start coiling!
Note: hollow needles will deform in cross-section when bent, so some of your coil may not be perfectly round. Don't use these rings for projects requiring consistent ring size/shape.
mum also says: Knitting needles go up to a very large size so you would have to make sure the knitting needle would fit though the hole in the shelf support! Or you could drill a bigger hole in the support itself.
**I would suggest getting one clamp for each L-support and secure them sufficiently far apart that you can coil between the supports. This way you can also skip having to shorten the L-supports. You'll have to figure out how to start the coil, if you want to conserve wire: maybe a very small hole drilled through one side of the needle? Insert a bit of wire, and start coiling.
If anyone gets the wider set up to work, I can put your photos up, here.
comments
Add Comment
Add Comment
