There is an update in the mill post section. The post clamps now have bolt pins to secure the mill to the bar.
There are details in the pictures so mouse over the yellow image notes to get a clearer explanation.
Remove these ads by
Signing UpStep 1Measure & Cut
Materials:
(4) 8 in square stock
(2) 12 in pipe
(1) 3 in wide by 8 in long sheet steel
(4) 2 by .75 by .25 in bar stock
(4) 4 in bolt, (4) nuts, (8) washers , (4) lock washers
Guide bed:
(2) 9 in square stock
(2) 14.5 in square stock
(1) 6.6 in square stock
(1) 5 in pipe
(1) 1.25 in square stock
(1) 2.5 in square stock
(2) .5 in nut and bolt
Note:
Square stock is (1.25 by 1.25 in)
Pipe is (1 in) outer diameter
Tools:
MIG welder
Vice grips
Grinder
Chop saw
Drill press and drill bits
Ruler and wax pencil
Safety:
Goggles
Gloves
Ear plugs
Clothing to cover entire body (closed toe shoes)
Welding jacket
Welding mask
If you have a 20" bar in this trusty mill, and you need to cut only the outer sides to make a square beam, how large would the beam be, and how large can the tree diameter be at the large end?
Adding a wedge seems like a good idea to me. That Stihl will last if you don't abuse it. A wedge and manual chain oiling should do the trick. Oil will help cool the chain. The devil will be in the details, but with some practice, I'm sure you'll have lots of tips for our hands-on, knowledge-thirsty souls..
Oh, and buying a warranty for that beautiful saw might not be a bad idea too, just in case!!! ;o))
Here's a site for a bigger version
http://www.procutportablesawmills.com/index.html
It is a commercial site, but they have some good info. Note, especially on sharpening your chain for rip cuts.
Thanks
This is an "Alaskan" type mill because it cuts parallel to the rails and attaches to the bar at both ends.
Granberg also sells a "small log mill" which is like the Alaskan, but only attaches to the motor end of the bar.
Hope this helps.
Let Down ;(
Thanx
Good luck with your timber framed buildings!
I have the cheapest welder of the market, I do only little works. My weldings are rough, I am still learning. I like to weld.
Im also considering an auxiliary oiler to keep the chain from getting overheated.
You've got a problem with overheating?
It appears to me that you'll have weight on the blade, adding a wedge behind the blade, like a bit of steel-bar on the frame might help.
But I don't see throwing a lot of oil at it as the solution.
L
