Chair and Table
Introduction: Chair and Table
For a technology project, you maybe asked to use 123d design and randomly your scholarly, educated, highly praised technology teacher, who should have already taught you techniques on how to use 123d design will ask you to create a table and chair. This a quick and fast tutorial for an easy chair and table.
Step 1: Step 1: Make a Base for Your Table
In order to have a base so the top of your table can stand on, you need to create one. I used circular pattern skills where you can take a basic line. Then that line, you give a round circle at the end of the line which has to be exerted. So you can later on use the sweep tool, to create a skinny cylinder rood. It can be curved in order to give a better effect. Later you make a round circle, the circle needs to be exerted. Then you can subtract whats inside, but only leave a metallic circle on the outside. so you place the cylindrical rod and create a circular pattern around it and voila you have your base. You can shape the size, at the top. So its tight at the top and it expands at the bottom. It should look like this:
Step 2: Step 2: the Top
The top is really easy, just exert a circle shape which should be larger than you. Although do not exert to much, or it will be too thick. Then change your material to glass or anything that you want. Also on the previous step, change the material of the base to anything you want just to make it look pretty.
Step 3: Step 3: Starting the Chair
For the chair, you need to create a sort of curved line, and using a cylinder as a base, you can sweep that to create your legs.Then you need to combine four circles which have been thinly exerted and on the sides they are rounded, you can using the rounding tool and they need to be combined with a think exerted square. Now the circles and the square combined equals to a place to sit. The same type of idea needs to be applied so you can lay your back on it. and there needs to be a small rectangle connecting those two parts.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    Looks good, thanks for sharing your design ideas.
