3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chaise Lounge from scratch.
Towards the end of last Winter we had a heat wave where I live, with temps. in the upper 90s for a couple weeks, and I really wanted to take advantage by laying out in the sun with my coffee and sudoku; sounds like a great plan right?
Unfortionately, the way the house is shaped and oriented and the locations of all the trees make it so that the only place that has sun throughout the day is in the middle of the lawn. So, despite the fact that we have two nice decks, I was relagated to laying a towel out on our lumpy uneven lawn, and I decided that this just wouldn't do.
I set about trying to find some resources online; I know there are at least a couple other chaise ibles on here but they weren't quite what I was looking for; and much to my dismay, the only info. I could find came in the form of plans for sale on woodworking sites.
Well, being an ibler at heart, I wasn't about to pay for instructions, and set out to figure it out for myself. After all, I did have one ace up my sleeve in the form of an aging, decrepit chaise that was probably built before I was born which I could examine for ideas.
It turned out that the ace was more of a joker though, because it used this strange support system for the cushion involving woven, flat metal strips attached to the frame with dozens of springs, and although it would probably have been comfortable, I was trying to get this done without spending too much money.
After sitting in the garage, looking around and scratching my head for a while I gave up and went to play a Mass Effect for a few hours. At some point, all the bits and pieces I had seen laying around must have wormed their way into my idea of what the chaise should end up like, because the next morning I woke up, got some coffee and just started building.
Step 1I kinda just built the frame and went from there.
I failed to take any pictures while I was building it months ago since I didn't really know exactly how the finished product would work while I was building. Recently, however; I was finally able to find a pad for it (silly seasonal products) so I took it apart to give it a coat of weatherproofing, and that's when I took all the pics so I will do my best to explain as I go.
To get started, all that is really needed is lots of lumber and  decking screws, which I had plenty of around. The basic proportions are that the whole thing should be about six feet long and about two feet wide and I used the height of the crook of my knee when seated as the basic height measurement.
If you are buying lumber for this project, you would need about 30 ft. of 2x4 and four cedar, dog-ear fence boards, but I just used what I had, most of which was left over from rebuilding the deck last summer.
The base of this project is a 6ft. by about 22" frame because I wanted the seat part to hang over some. Cut the fence boards into thirds, roughly 2ft. each, and use the square pieces to cover 2/3 of the frame, leaving the dog-eared tops for the seat back.
The seat back is just a smaller frame that fits inside the larger frame that is essentially square save for the little feet that stick out the bottom for the hinge mechanism. (see pic five) Sorry, I don't remember the dimensions for the seat back frame, but it just has to be wide enough to fit inside the larger frame, not snugly, but there shouldn't be gaps either; and, it should be a bit longer than the uncovered portion of the base frame.
17 comments
Sep 15, 2011. 6:24 AMLDW says:
Just for the record, it's chaise longue, not lounge. It means 'long chair' in French.
Sep 17, 2011. 5:57 PMLDW says:
OK, but what does the 'lounge' part mean in that case?
Sep 18, 2011. 3:56 AMLDW says:
Oh, I see.
Should it not be 'chair lounge' then? Or perhaps ' lounge chair'? Or even maybe 'lounger'?
Mixing up the French and English makes the meaning sound very odd.
Sep 18, 2011. 2:44 PMLDW says:
That's funny: I thought there was a difference between right and wrong.
Most people put a capital letter on English, French etc as well. But perhaps you're just illiterate :-)
Aug 12, 2011. 2:48 AMfriger says:
Nice job. Here are a few pics of one I built from the plans in a magazine. It was not cheap to build but worked out very well.
Aug 16, 2011. 5:51 AMfriger says:
Here are a few pictures of the back mechanism.
Aug 17, 2011. 3:26 AMfriger says:
Your system looks like it works just fine. This was fun to build and I have started a second one but as with many things time is the missing resource.
Aug 19, 2011. 3:19 PMfriger says:
I used a Wagner power sprayer on mine and I'll tell you, you saved alot of heart ache. It was a pain.
Aug 15, 2011. 4:31 AMfriger says:
I'll take a few pics and post them as soon as I get a chance.
Aug 8, 2011. 1:53 AMKiteman says:
What we really need to see is somebody actually lounging in the sun.
Or possibly a cat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:siamonsez
