Chalieplexing 4 RGB-LEDs With 4 Wires on Arduino
Published
Introduction: Chalieplexing 4 RGB-LEDs With 4 Wires on Arduino
Did you every need many LEDs, but only few wires? Then Charlieplexing is a great thing to try. With only 4 wires you can drive 12 LED with only 4 resistors as an optional protection and without any "intelligen" component like a 74595 or similar. - This example will show how to use 4 RGB LEDs to test this very nice concept. The generic code allows to control any number of lines very easy:
  // A 4 wire setup
  #define CHARLIE_PINS  4
  // Arduino Pins 9 - 12 control the LEDs
  #define CHARLIE_FIRST 9
  // Sample 1: First LED(0,1) "On"
  charlieClear();                                  // Clear all LED levels
  charlieWrite(0,1,CHARLIE_MAX); // Set LED(0->1) to maximal level
  charliePlex();                                     // Generate the output pattern
Step 1: Materials and Tools
The example will use 4 RGB LEDs which happend to lay in my drawer, but you may use any spare LEDs you want to sacrify.
Required Materials
- 4 RGB LEDs (or 12 single Color LEDs)
- Arduino whatever you have
Recommended Materials
- 4 Resistors, e.g. 3k3
- Small piece of perforated circuit board (or breadboard)
- 4 PIN male headers
Recommended Tools
- Boardmarker
- Grippers
- Wire cutter
- Soldering iron
Step 2: Prepare the Stripboard
We will add a resistor to each strip, so just leave two rows in the beginning of the strips empty: One for the headers, one for the start of the resistor, cut (= isolate) on the third row of holes, the LED will be plugged starting from the forth row (sorry, the picture is after soldering).
Step 3: Bend & Plug It Like Charlie
To simplify the bending, we mark the Stripboard distance on every pin all LEDs. This way it is very easy to bend the pin the required strip. Please be aware to keep always the same "orientation" of your LEDs. In this case Pin 3 is always the anode.
So the bending pattern is:
  1. LED
    • Pin 1, Strip 1
    • Pin 2, Strip 2
    • Pin 3, Strip 3
    • Pin 4, Strip 4
  2. LED
    • Pin 1, Strip 2
    • Pin 2, Strip 3
    • Pin 3, Strip 4
    • Pin 4, Strip 1
  3. LED
    • Pin 1, Strip 3
    • Pin 2, Strip 4
    • Pin 3, Strip 1
    • Pin 4, Strip 2
  4. LED
    • Pin 1, Strip 4
    • Pin 2, Strip 1
    • Pin 3, Strip 2
    • Pin 4, Strip 3
Then plug the LEDs in the stripboard.
Step 4: Solder 28 Times
Now comes the easy part: Just solder all the LED-PINs, then the 4 resistors (I first used 3k3 throughholes and then 0k5 SMDs) and the 4 header pins. Keep a sharp eye on any shortcircuit on the front and back side of the board.
Step 5: Plug and Play With the Software
Now everything is ready to test the system. Take out your beloved Arduino (or if you're scard your Ruggduino), copy-paste the code in your Arduino sketch and modify it as required. Any improvements are welcome
  CharliePlexing Library
  (c) by Olivier Chatelain 2014
  This code is CC-BY-SA-3.0
// Setup the memory
#define CHARLIE_COUNT CHARLIE_PINS*(CHARLIE_PINS-1)
// Charlie Level (0 = off, 255 = max)
#define CHARLIE_LOW    0
#define CHARLIE_HIGH 255
#define CHARLIE_OFF     0
#define CHARLIE_MAX   255
// Charlie Levels for anode/cathode pin-pairs
uint8_t charliePins[CHARLIE_PINS][CHARLIE_PINS];
#define CHARLIE_GREEN 0
#define CHARLIE_BLUE  1
#define CHARLIE_RED   2
int charlieRGB[CHARLIE_PINS][3] = {{1, 2, 3}, {2, 3, 0}, {3, 0, 1}, {0, 1, 2}};
void charlieClear() {
  for(int i = 0; i < CHARLIE_PINS; i++) {
    for(int j = 0; j < CHARLIE_PINS; j++) {
      charliePins[i][j] = CHARLIE_OFF;
void charlieSetAll() {
      charliePins[i][j] = CHARLIE_MAX;
void charlieSetAllLevel(uint8_t level) {
      charliePins[i][j] = level;
void charlieWrite(int src, int dst, uint8_t level) {
  charliePins[src%CHARLIE_PINS][dst%CHARLIE_PINS] = level;
// current line displayed
int charlie_line = CHARLIE_PINS-1;
void charliePlexLine(uint8_t level) {
  // Disable last line displayed
  pinMode(CHARLIE_FIRST+charlie_line, INPUT);
  if(++charlie_line >= CHARLIE_PINS) charlie_line = 0;
  int i = charlie_line;
  int MasterPin = CHARLIE_FIRST+i;
  // Use others as follow pins (HIGH or INPUT)
    int SlavePin = CHARLIE_FIRST+j;
    if(MasterPin != SlavePin) {
      if(charliePins[i][j] > level) {
        pinMode(SlavePin, OUTPUT);
        digitalWrite(SlavePin, LOW);
      } else {
        pinMode(SlavePin, INPUT);
  pinMode(MasterPin, OUTPUT);
  digitalWrite(MasterPin, HIGH);
void charliePlex() {
  // Set one leadpin (LOW)
    for(int j = 0; j < CHARLIE_MAX; j++) {
      charliePlexLine(j);
      delayMicroseconds(10);
// the setup routine runs once when you press reset:
void setup() {
void loop() {
  charlieClear();
  charliePlex();
  // Sample 2: Dimm White
  for(int i = 0; i < 8; i++) {
    charlieSetAllLevel(1<<i);
    charliePlex();
  for(int i = 7; i > -1; i--) {
    CHARLIE_PINS(1<<i);
    charliePlex();
  // Sample 3: Alternate the COLORS
  charlieClear();
    charlieWrite(i, charlieRGB[i][CHARLIE_RED], CHARLIE_MAX);
  charliePlex();
  charlieClear();
    charlieWrite(i, charlieRGB[i][CHARLIE_GREEN], CHARLIE_MAX);
  charliePlex();
  charlieClear();
    charlieWrite(i, charlieRGB[i][CHARLIE_BLUE], CHARLIE_MAX);
  charliePlex();
Enjoy it!
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    9 Comments
    Hi, does it display only 3 individual colour either red, green and blue? is it possible to make a combination of them?
    Can you show a working video of this project?
    Thanks.
    Hi,
    You may light as many LED together as you want. The code is designed to have 255 Levels for each LED.
    Here is a basic video, unfortunatly without any color combinations:
    Hi! Is this the same code as in Sample 3?
    Thanks and you may even vote for the Arduino competition
    What do I have to change to use common cathode RGB LED?
    Either in the programm or in soldering.
    Hi is it possible to get a complete description of your library?
    So I know what do with each new command. Not just doing much try and error.
    Thanks
    Recently created an LED clock using charlieplexed LEDs: http://dushyant.ahuja.ws/2014/04/led-clock/
