3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chalkboard sphere
Chalkboard sphere
This instructable will show you how to build a blackboard sphere to write on. Because sometimes a flat area is not enought!
Step 1Assemble the polysyrene sphere
You have to glue the two pieces together. Pay attention to use a glue intended for polystyrene (some glues can dissolve/liquify it)
12 comments
Oct 14, 2011. 1:05 PMfreakyqwerty says:
Using glue to dissolve polystyrene is a way to make simple once-use molds, you simply carve the polystyrene use it as a mold when the model is set use the glue or even better ethyl acetate to dissove the polystyrene to release the model.
Oct 19, 2011. 8:57 PMelectfire says:
You can also use plain old acetone (sold in most box stores and hardware store to cleaning) - this is also a cool way to "melt" (Doesn't technically melt it) Styrofoam... you can then use the liquified plastic to make things with...
Oct 20, 2011. 9:29 AMelectfire says:
-oops! I forgot to add that in - Once the acetone is removed (usually just let it evaporate) It will solidify.... I wish I had heard of this method before I tried to melt Styrofoam over and open flame (a lighter)... not only did the Styrofoam not melt but in caught on fire and Styrofoam burns in an irregular way - the flame will worm it's way through the foam, all the while creating a nasty smelling smoke, which I am sure shouldn't be breathed in.
Oct 22, 2011. 10:10 AMfreakyqwerty says:
What were you trying to melt styrofoam for? Also I'm pretty sure most types of smoke is bad to breath in...
Oct 22, 2011. 4:24 PMelectfire says:
I was trying to melt Styrofoam to make it into usable plastic... as for smoke inhalation - some types of smoke smell good... like wood smoke, incense etc...
Oct 23, 2011. 9:45 AMfreakyqwerty says:
Yeah I like the smell of wood...
Oct 14, 2011. 12:36 PMzazenergy says:
this is a really fun project! what do you find yourself using this for?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:derte84(Genteautoreggente!)
