Okay, basically, I making pretty much every thing spicy but found that chili sauce can be a bit intrusive with certain dishes (for example it makes the milk go funny with your cornflakes). I also had a bit of time on my hands and had ordered to many scotch bonnet chillies than it was reasonably safe to use in one dish.
This is very straight forward but very effective. Great for using up a glut harvest of chillies.
Anyhows, here you go.
Remove these ads by
Signing UpStep 1: Its Chili time
Get yourself some good quality sea salt. This will work with normal salt but I like to think we are doing something a little special here. Your ratio of chili to salt is up to you. I would say though that you want this to be chili flavoured salt rather than the other way round. To much chili could result in too much caking. If you want more heat get hotter chillies or use dried.
Visit Our Store »
Go Pro Today »
Try it though, it may just work!
If you want principally the heat, you could try extracting the chilis with very high proof (higher is better, something like Everclear would work best), and let it slowly evaporate over time. If you're lucky, you'll end up with crystals of relatively pure Capsaicin and other Capsaicinoids.
Actually, be VERY careful if you attempt that last bit. Capsaicinoids, when isolated, are extremely noxious. http://answers.google.com/answers/threadview/id/540637.html
I've done the extraction in chem class, but now that I think about it, we were working with sub-miligram quantities.
A safer bet would be to extract with ethanol, add your salt, and concentrate down, stirring occasionally so it doesn't stick. You'd end up with a similar paste as in your 'ible, but depending on how many peppers you started with, you could really dial up the heat if you were so incline.
But you are correct, stick to non-stick where possible. The only problem I have at the moment with using non-stick is that I only have access to an induction hob at the moment. All the pans that I can use on it are non-stick. I think iw ill stick to oven infusion.
Cheers man, any other readers - Listen to this guy. A
However if you check my next version Chalt 2 the rice method will probably be a great help.
Thanks for the suggestion
But it sounds amazing. :D
Prepare at own risk and in a well ventilated area.
A x
I think the ratio was 5 tbs to 1/2 cup of sea salt. But I guess thats up to you!
I think your ( My next iteration of Chalt is going to be dissolving salt in a heavy chili solution and then re-crystalising it ) is the way to go though, IMHO
One of the reasons I say that is , you really don't know if you are removing all the moisture. and if you keep it out in the grinder might not be that great in a week or two.
If you find a dehydrator at a yard sale that might be something to look into but an upside down bowl and a desiccant pack should work. I just think if you have infused Salt crystals it would have a much longer shelf life. But then again it sounds so good it might not last.
I like it.
Next mission Chilli Salt. Will get on it tomorrow. Chilli solution salt, re-crystalisied, on it. Will report back. Thanks for comment. :)
I am not scared of a little tear gas chilli and will keep using a pan (I am an idiot). What your suggestion does raise though is perhaps the addition of a hickory chip layer to add a smokey dimension to the flavour. This would work well at a slow bake.
I will get back to you on my results, thanks for your comment.
Anyone worried about searing sinus pain or red eyed pets and children, listen to this guy.
