Step 3Cutting the hole...
Now begin the cutting, cork is actually allot tougher than it looks so i recommend carving out a small groove on the top inside the line you drew and then just shredding at the cork and emptying out the shavings every so often ( very careful with your fingers here , high risk of severing)
Also be careful not to cut the sides too much otherwise it will all fall apart.
when cutting every so often shove the usb in the hole to see if you've cut enough out.
comment
Add Comment
=SMART= (author)
says:
Add Comment
