I have one of the original Belkin Tunecast FM transmitters for my iPod. After I fed it one pair of AA batteries I decided I needed a better way. So, here's how I converted a car cigarette lighter cell phone charger into a method of powering my transmitter. This instructable is with a Belkin, but it will work for any transmitter, or even any battery powered thing-a-majiggy that you want to change from battery power to car/cigarette lighter power.
A bit of electrical explanation :
AA batteries put out 1.5 volts, since my FM transmitter uses two AA batteries: 2 * 1.5v = 3 volts
I used a LM317 variable output voltage regulator so I had to rig up some resistors to get the right output. If you use an LM317, the formula to determine the output is :
(Voltage out) = 1.25 * (1 + (R2/R1))
Where R1 and R2 are connected as shown later.
Step 1Disassemble cigarette lighter adapter
Disassemble your cell phone charger and pull out the circuit board, desoldering as needed. You typically start by unscrewing the metal tip and shaking out the fuse and spring. Then, pry the two plastic halves apart. Be careful when you pull the pieces apart as there is sometimes more than one spring inside and it can go flying. Make sure you keep the fuse, spring, and connecting wires.
I opened the case, turned my home stereo on one channel, and carefully touched the end of a 10 ft. (3 m.) piece of thin (about 24 ga.) insulated wire to different places inside 'til I found the place which gave me the best signal level on the stereo. Turns out to be one of the battery leads. I then cut a little notch in the case for the wire to exit and tucked it behind the inside edge trim of my windshield (my radio antenna is on the passenger-side front fender). No more swamp-outs when driving downtown. :)
I would have done an 'ible on it, but it's simple enough. Besides I plan on making a much better signal coupler later at the same time I make a semi-permanent installation with the power adapter.
http://www.pricebat.ca/Belkin-MP3-CD-MD-FM-Transmitter-3-5mm-Plug-2-AAA-Batteries.p_10049603/
...oooooops
