3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert Belkin FM Transmitter from Battery Power to Car Power
Step 7Cut hole to accomodate power cable
Once you've tested it, use a dremel or drill to cut a hole in the end of your transmitter casing that is slightly smaller than the cable that will be running through it. You want this to be really tight so it holds the cable in place with tension from the casing screws instead of having to glue it in place (but you can if you want). The easiest way to get this hole right is to put the pieces of the casing back together and then drill the hole at the seam.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:darc
Just a geek with a soldering iron...
