So whats a Floyd Rose?!
A Floyd Rose is a system on some guitar that let you do some big dive with the whammy bar without detuning the strings because of his strings locking system.(Strings are locked on the bridge and on the head part of the guitar) The bridge on the guitar is support by spring locate inside the body on the guitar and the tension of them need to be equal to the strings tension or else the bridge will dive in or out of the body.The Floyd rose let the guitar player make a variety of other sounds with the tremolo!
*VIDEO SOON!*
Remove these ads by
Signing UpStep 1Material
- Your guitar with Floyd Rose
- The string(s) you want to change
- Cutter or Multi-tool
- Allen key the size of your Floyd's screws
- Guitar/Bass/Violin Tuner
- Not Show - Something able to hold your bridge
I like to use part of a deck of cards to hold the bridge up. It's a nice fit, and fully adjustable.
I find that the way you tune your strings.... doesn't work. It takes forever, and doesn't stay in tune.
I tighten the springs up, support the bridge level with the body (with the cards) then tune up (the other strings shouldn't go flat!), then loosten tue screws until the cards fall out.
Then just adjust a little with the fine tuners....
