loading
loading
Picture of Change Images in Ikea Erikslund Frames
Ikea sells several really inexpensive shadow-box picture frames that look good, but which are "preloaded" with images suitable for a very calm, beige-colored life in a zen world. But what if you like the frame, but your tastes don't  mesh so well with the with the day-spa sensibilities of the Ikea photographers?
Well it only takes a few moments to take the frames apart and swap in your own images.
Step 1: Step 1: Make and trim replacement prints
Picture of Step 1: Make and trim replacement prints
These frames take images that are 6.85 x 6.85 inches, but you don't want to trim your replacement images to that dimension because it is pretty darned hard to adhere your image with perfect registration when the back is covered with glue.
The trick is sizing your prints to that dimension, and then adding white canvas space around the images, turning the digital image file into a 6.85" square image, with a white border extending to 8x8 inches.  Then add more space on the sides of your digitial image (say with photoshop?), turning it into an 8x10 standard print size. * Then send your images to the local online photo printer as 8x10 prints.
When you are ready to hack your Ikea frame, simply trim the prints to the 8x8 inch size.
*I usually add the extra width space in the last step as pure black, to balance the white border around the print. That way the photo printers wont darken my photo if they auto adjust the printing to mid-tone grey.
Step 2: Step 2: Remove the frame backing
Picture of Step 2: Remove the frame backing
The staples holding the frame together are pretty easy to lift with a screwdriver. You might need a pair of pliers to yank out any staples that pop up on only one side.
Step 3: Step3: Separate the image backing from the frame
Picture of Step3: Separate the image backing from the frame
At this point, run your hands along the edges to get rid of the cruft of particle board dust that inevitably ends up dropping in when you open the frame.  The glass in these cheep frames is usually dirty on the inside, so I also give it a wipe with some glass cleaner
