3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Change a lightbulb, Save Electricity and money!
video Change a lightbulb, Save Electricity and money!
The hall bulbs in my apartment (which I maintain) are old incandescent, and as they die I replace them with CFL bulbs to save power - a big difference since they're on 24/7.
You'll Need:
Safety Glasses
Something sturdy to stand on
Backup light - to see what you're doing.
Replacement bulb - match the original in 'wattage' to get similar lighting results.
Suggestions:
Turn off the power first. I can't access the switch/breaker for this bulb since it's locked in the boiler room.
Notes:
I had to recalibrate my camera for the new light bulbs so they looked their natural colour - warm white - hence why the light changes colour from start to finish!
It's really that easy! (No, REALLY, it is!)
Please vote! (and don't forget to vote for everybody!)
23 comments
Sep 22, 2011. 3:49 PMjrosen3 says:
I have just started replacing my CFLs with LEDs. They are much more expensive but use even LESS electricity: a 6-watt LED replaces a 13-watt CFL with the same light output as a 60 watt incandescent (the ideal level for a normal household lamp). Slightly less than 1/2 the power consumption, but they last about 5 times as long as a CFL and about 40 times as long as an incandescent (20,000 hours vs. 4,000 hours vs. 500 hours). They also radiate about 1/10th the heat as incandescent (heat roughly = to power consumption). Cost is about $10-12 a bulb, compared to about $.50/bulb for incandescents, so the life/cost ratio is still 2:1 in favor. GO LEDs!
Aug 19, 2011. 10:25 PMmcowdrick says:
allso may i add that the quality control for foresents are worse then incandescent (trust me on that one i've seen quight a few) and the are dimmer then incandescent and it takes more time for them to reach the max of ther fule efishensy so if you turned off the light and left the room you would have to come back for in less then a second for it to save electricity while you were gone wial incandescent always save electricity while your gone because the have a very short amount of time to get to max efishensy
May 11, 2011. 11:50 AMVinsu says:
How many people does it take to change a lightbulb? Just one.
Well, well... It was about time someone posted an instructable about changing a lightbulb. Really. Everyone doing this could make so much difference. These things can give light for so much longer than those old ones with corporation-reduced lifetime.
In some countries it is these times forbidden to produce any "normal" lightbulbs and recommended not to buy ones either anymore. This is progress, people.
Without a bit of sarcasm; 4 stars.
Apr 20, 2010. 6:42 PMiworkalot says:
Saving energy is where we should be aiming, but don't forget the mercury content in the CFL's. Saving energy versus a poison encased in incredibly sharp glass. I question the merits of the CFL being pushed in the public eye with the LED's being developed for the same purpose and lower energy consumption. Use them if you think the risk is worth it, but keep them away from kids and don't drop them!!
Apr 26, 2010. 4:01 AMiworkalot says:
I am originally from Alberta as well, so I have a lengthy history with energy production and consumption.
Unfortunately, I do not believe the majority of people swayed into buying CFL's will treat these properly, especially now that governments are forcing them to. I am a cynic I guess.
Get the word out about the recycling and I can commend that.
Sep 24, 2009. 6:40 PMmadrang says:
There is some problem with this. 1 CFL cost more. 2 are almost not recyclable and light bulb are 100 % recycled 3 Watt differences between CFL and Light bulb dosnt worth it (could save more by using thermal energy to control room themp as colling unit reach easy 2000W so as the heating ones)
Nov 1, 2009. 9:01 PMdjpc47 says:
CFL cost will go down as more people use them.... I question how many people truly recycle regular lightbulbs; don't get me wrong I understand recycling pop cans, glass bottles, paper. However I doubt lightbulbs are high in the list of things most people think of to recycle....about watt difference, yes its true the watt diff will not make that much a diff if you replace one bulb; however the key is to change all bulbs to cfl as required(not 100watt equivalent lights everywhere:P).... another thing that I dunno if it makes much of a diff, with the cfl's I've toyed with they seem to use one phase out of the 2 provided(internal diode's I guess; yes I think this means they generally run on DC current:P) on regular 115v-120v.....
Aug 12, 2009. 9:22 AMjessyratfink says:
"so that when we pull this glass out, we don't dump bugs in our eyes" Hahaha! Or dust, for that matter. I normally just look down as I take the globe off. Glasses are a better idea, though!
Aug 22, 2009. 10:38 AMcowscankill says:
I don't take off my glass cover. I am tall enough to stand on my bed and just reach over it...It is probably full of some gross stuff by now D:
Aug 13, 2009. 10:28 AMcaitlinsdad says:
trivia: NYC subway station lightbulbs have a left hand screw thread to prevent vandalism by people stealing them to use at home
Aug 13, 2009. 10:13 AMcaitlinsdad says:
You shoulda used the Instructables PRO brand of lightbulbs, then you can see all steps.
Aug 10, 2009. 9:09 AMKush_Slayer says:
cfls are nice, to bad they dont work well in the cold
Aug 10, 2009. 2:28 PMgeekazoid says:
go canada!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:frollard
In a world where the blind leads the blind, who do you follow?
