3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Change an Ignition Switch without Removing the Dashboard
This Instructable will show how I replaced the ignition switch in my car without removing the dashboard.
In a recent Instructable I discussed problems with the instrument cluster on my 1999 Oldsmobile Alero. In that previous Instructable I had believed my ignition switch tested good and I soldered some metal-on-metal connections to by-pass oxidation that may have added a critical amount of resistance to the circuit. Still, the same difficulties returned a few days later. I read articles like this one to see if my 12 year old car with 110,000 miles could be suffering from an ignition switch in the early stages of failure. I decided I wanted to remove the ignition switch from my car for examination and possible replacement, but do it without removing the dashboard.
The Oldsmobile Alero has some "cousins," like the Chevrolet Malibu. But, the dashboard trim in the Malibu is different from that in the Alero. In the Malibu the bezel around the radio simply pries off, and when it is removed the two bolts that hold the ignition switch in place are fully accessible. The Alero is different, though. The same two bolts are hidden behind the dashboard.
For this Instructable I needed:
A 10mm open end and box end combination wrench that I could sacrifice.
A couple of screwdrivers.
A nut driver with a 7mm wrench socket attached.
A torch for heating and bending the wrench as needed (I used a carbon arc torch on an electric welder.).
A vise (for holding the wrench while heating it for bending).
A hammer for making the bend in the wrench as sharp as possible.
A Dremel tool with a cylindrical grinding bit and a burr bit.
A mechanic's inspection mirror.
Auxiliary lighing (flashlight or a mechanic's trouble light)
A Haynes manual for my car.
A multi-meter.
A new ignition switch.
Step 1Ignition switch bezel
Before beginning it is a good idea to disconnect the negative lead from the battery to keep the air bags from deploying accidentally. If your car has an anti-theft code set for the radio, deactivate that first.
The ignition switch bezel lifts off when pried around its perimeter with a common screwdriver. I will trim away some of the dashboard behind the ignition switch bezel and use the extra space to access the bolts.
36 comments
Oct 19, 2011. 11:43 PMmaggiemcstout says:
Could you have used magnets on the bolts attached to something metal in case they fell?
Oct 14, 2011. 3:13 PMknife141 says:
Great instructable! Your making of a specialized wrench reminded me of growing up working in my Dad automobile repair shop. When we would run into needing a specially shaped wrench to save having to remove a lot of unnecessary parts, we'd grab a wrench, saw it up, and weld it to the shape we needed. All of these "custom wrenches" were stored in a drawer in the middle of the shop so that any mechanic that needed such a thing would know to look there first. One of my contributions to the process was making a custom tool that allowed you to replace the clutch on a 1970 Toyota Corolla without having to first pull the engine. Yep, the book said you had to pull the engine on this car back then simply because of two bolts located in a really bad place on the bell housing. Specialized tools are great.
Oct 11, 2011. 12:55 AMarkangel1975 says:
Great job, I know a friend who is having similar problems with the same model of car, this might just help!
Also a word of warning don't do this in the middle of the night in a parking lot while wearing a ski mask.... you might just get a nasty surprise haha
Oct 11, 2011. 11:28 AMarkangel1975 says:
oh god, don't remind me about the BCM, I have a Saturn sl2 2001 and the bcm has been an utter nightmare. (it was problematic in that series anyway)...
Oct 10, 2011. 4:31 PMWesley666 says:
Haha! My around town beater is a 1999 Olds Intrigue, it has the exact same problem. Design flaw maybe? Will have to bookmark this page for future reference! :D
Oct 8, 2011. 9:06 AMspitfire2323 says:
I have similar symptoms. I have a 2001 Alero. What happens with mine is. Once i run the car and turn the engine off and remove the key and close the door. The car still "dings" as if the keys are still in the ignition or I left the headlights on. Also, my power doorlocks do not work. I have at times experienced the same problem with my instrument cluster not giving readings right away. My trunk will also pop open on it's own. Now in order to drive it and keep the battery from going dead I have to pull the negative terminal whenever I park the car which is not very practical. I was told by 2 mechanics to start with the ignition switch and you just gave me the final go ahead and change it with your instructable.
Oct 9, 2011. 10:02 PMprestux says:
Great job Phil!
Oct 9, 2011. 12:06 PMron.rakesh.mandal says:
Nice work
Oct 9, 2011. 2:28 PMron.rakesh.mandal says:
Oct 9, 2011. 9:06 AMsmallenginetech says:
I have a full set of wrenches bent like that that I bought with a toolbox you might find a lot of uses for this. I know I have found them handy in the past.
Oct 9, 2011. 12:00 PMsmallenginetech says:
I am a mechanic and I not have bought them at the store, I just got a good price on a used set of tools that I could not pass up. I found a guy selling tool box full of snap on tools, box and all for $150
Oct 7, 2011. 4:46 PMDIY Dave says:
Great job. You find solutions for everything
Oct 7, 2011. 6:25 AMrimar2000 says:
Awesome work, Phil!
I usually see in TV series entitled "Impossible repairs." This could be a chapter.
You remember me an uncle, that did repairs like this, things that no one else dared to try.
Oct 7, 2011. 4:38 PMrimar2000 says:
I always complained about the argentine TV, until hired DirecTV and started to watch TV from other countries. I realized that there are many worse. But documentaries I usually watch are not made here, they come from USA, Europe, Asia, etc. I look NatGeo, Discovery, Animal Planet, Encuentro (argentine), History Channel, Biography, Films&Arts (sometimes), Infinito and news.
Oct 7, 2011. 8:54 AMmikeasaurus says:
wow, awesome job modifying that wrench!
Oct 7, 2011. 10:02 AMmikeasaurus says:
Modifying or making your own tool is way more satisfying anyway.
Oct 7, 2011. 1:09 PMRobot Lover says:
This would have been the best instructable to explain the wiring to the keyswitch and perhaps how to hotwire a car in an emergency. Great Instructable!
Oct 7, 2011. 11:12 AMzazenergy says:
nice work, featured!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
474
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
