Microsoft's SideWinder X4 is a low-cost, backlit, gaming keyboard, and one of the very few to feature anti-ghosting technology that isn't limited to some small region of the keyboard. Typically, this feature has only been available on very high-end keyboards. This has made the X4 a hit with budget-minded gamers.
Unfortunately, not everyone loves the color of the backlighting. The X4 features a brilliant red backlight. But many people prefer blue, or even green. In this Instructable, I will show you how easy and inexpensive it is to change the backlighting to a different color. Please note that doing this will void your warranty.
Remove these ads by
Signing UpStep 1Gather Materials
http://www.hebeiltd.com.cn/?p=leds.1.8mm
They also have a U.S. distributor:
http://leading-leds.com/1.8mm.html
Shipping will probably cost far more than the handful of LEDs, so you might want to stock up, or do a joint buy with firends. You will need at least 10 LEDs of your choosen color. I would buy some extra in case you break or lose some.
(5V-2V)/100 ohms = .03A = 30mA
White LEDs typically drop about 3V. If you don't change the resistors, this would give a current of 20mA. But if you want to take full advantage of the available current, you want to up this to 30mA. That is:
(5V-3V)/.03A = 66 2/3 ohms
There nearest standard value is 68 ohms. This should be about 50% brighter. However, because the human eye is logarithmic in it's response, you will probably only perceive it as being a little brighter. I'd suggest you try doing one first to see if you think it's worth the effort. In fact, if you can simply hold a 200 ohm resistor in parallel with one of the resistors (100 in parallel with 200 gives 66 2/3 ohms) to see if it makes much of a difference.
The purists will note that these LEDs really are meant to be run at 20mA. Again, if memory serves, these are pulse width modulated, and I don't recall the duty cycle. But presumably, this works out to an average current of 20mA or less, even if the peak is higher.
I dont have any 200ohm resistors around to test that out^ or 68ohm ones for that matter.
Would these carbon film 1/4 W ones do the job?
http://www.ebay.co.uk/itm/100-X-68-OHM-68R-CARBON-FILM-RESISTORS-1-4W-0-25W-68OHM-/160517023335?pt=LH_DefaultDomain_3&hash=item255f8f6667
Cheers for the help.
W = V * I = I^2 * R
(.03A)^2 * 68ohms = .0612W which is way less than 0.25W
So these can easily handle the power dissipation. 1/8W resistors would also work fine, and might be easier to fit mechanically...
Just to add.. I also changed the LEDs for the Num, Caps Lock etc. and the macro lights. Looks awesome!
This is a great mod. I had a broken notebook LCD and I took out the WLEDs from it for modding. I followed your guide and here's how the thing looks. I love the dim white glow now. Its definitely better than how it was earlier.
I know what you mean, I was able to cut out 2 LEDs from a 3 LED lamp and use them as a bulb replacement on a 50 year old radio :)
Recently, I found an Samsung LCD monitor lying on the stairs and I was able to replace the burst capacitors with those from an old TV circuit board. The thing still works!
Thanks for the excellent writeup. Very impressive.
could you helpme?
Thank you so much for you Time and your atention...
